10-13-2012, 09:07 AM | #57 | |
The lower run is just with an exhaust. The 200whp run, is I/E/Tune. All I did was load the run files into WinPEP and screenshot it. |
10-13-2012, 07:32 PM | #58 |
I'm not going to keep arguing this with you... but this is what I mean. The new green lines are a trace of the blue run, shifted over to start at the same RPM as the red run. That plot looks much more like I would've expected, especially the torque curve around the dip. It starts later than stock and ends earlier and doesn't dip as much.
10-13-2012, 07:47 PM | #59 | |
Here are the dyno files. |
10-13-2012, 09:50 PM | #60 | |
10-14-2012, 01:44 AM | #61 |
Drives: Attitude
I base lined at 172whp with just an axleback at a few hundred above sea level.
10-14-2012, 08:22 AM | #62 | |
For what it's worth, I did follow the manufacturers break-in to a T and changed my oil at 1000 miles. Unfortunately, until one of these shops actually steps up and releases a good header... I think this is the max we are going to see NA, without cracking the motor open. It's amusing. A couple shops immediately came out with "ohh we made like 187whp on a header" and then never released them. Kinda lame if you ask me. Last edited by 2forme; 10-14-2012 at 08:34 AM. |
10-14-2012, 12:16 PM | #63 |
A few hundred above sea level? Where were you? I thought most of Mass is at sea level...
With regards to the header, it's tough because of the cat in the factory header. If you remove that, you're gonna have some emissions problems. I know some people go cat-less and can find ways to fool the emissions tester into thinking there's no CEL, but I'm not about to do that; too much of a closet tree-hugger. I really hope someone steps up to the plate and offers a quality catted header that's 50-state friendly.
Current: 2005 Porsche 911 Carrera S 6MT Previous: 2 BRZ's, 997 C2S, C5 RS6, C4 S6, B8 S4, GDB STi, S30 240Z, FC3S RX-7 TII, AW11/SW20 MR2, E30 318is/325i, etc. |
10-14-2012, 12:51 PM | #64 | |
Drives: Attitude
You're not going to get a 50-state header; California just makes it too hard. Just keep a high flow cat downstream of the header. |
10-14-2012, 12:57 PM | #65 |
Not an option. I have a header back exhaust.
10-14-2012, 01:12 PM | #66 |
Drives: Attitude
Not an option FOR YOU. I knew I'd want a header without a cat so I opted for a high flow cat in the front pipe I purchased (it's in the garage, not on the car). Anyone who does research should come to a similar conclusion; header is worst placement of the cat, front pipe is better. Buying a front pipe without a cat is just a poor decision IMO. I wouldn't run catless, but I opt to have the cat in the less intrusive place.
10-20-2012, 10:21 PM | #67 |
Here's my numbers on Visconti's stg1 93 tune and aFe intake.
Asphalt FR-S: EcuTek Visconti STG2 tune, MAPerformance turbo kit, MAPerformance 3" exhaust, Hotchkis springs, Mach-V 17x9 Awesomes.
Build thread: http://www.ft86club.com/forums/showthread.php?t=30703 |
10-21-2012, 11:06 AM | #68 |
Drives: Attitude
Got a winpep file for that?
10-21-2012, 11:20 AM | #69 |
Im sorry, I do not. This was a dyno day with over 30 cars, they just gave me a print out. I may be able to have them email me a winpep file.
10-21-2012, 11:26 AM | #70 |
Drives: Attitude
Yeah see if they have the run saved. Download winpep from dynojet's site and play around with it once you receive the run file.
Similar Threads | ||||
Fuel pump and speed sensor | Tt3Sheppard | Issues | Warranty | Recalls / TSB | 28 | 04-20-2017 01:54 PM |
Which gas station(s) do you OR folks pump at? | m.box.design | Northwest | 41 | 05-12-2013 01:01 AM |
Dynosty Pushing the Limits... Fuel Pump and Clutch | Dustin@Dynosty | Engine, Exhaust, Transmission | 29 | 08-15-2012 06:53 PM |
Be careful at the pump with E15 | Thunderchicken | Scion FR-S / Toyota 86 GT86 General Forum | 9 | 08-10-2012 10:33 PM |
Legacy low-mounted turbo oil pump | aspera | Engine, Exhaust, Transmission | 0 | 06-16-2010 03:41 PM |
