02-07-2012, 09:09 AM | #631 |
Wiring Nerd
Drives: 1994 Supra
Does anything like this exist?
Variable runner length, using solenoids with a 0-XX VDC output from an ECU source, to tune the runner length? What about a similar concept for exhaust runners? Just drew this up this morning and when it was fresh in my head. The idea is to have infinitely variable runner length so that you can maintain the Helmholtz resonance. Last edited by bambbrose; 02-07-2012 at 09:38 AM. |
02-07-2012, 10:06 AM | #632 |
Rocket Surgeon
Drives: PSM GGA OMG
Yep, that's usually referred to as a telescoping intake runner. The Mazda 787B had them, but that's the only example that comes to mind. The main issue is getting them to move fast enough to keep up with the engine.
02-07-2012, 10:19 AM | #633 | |
Wiring Nerd
Drives: 1994 Supra
hahah wow that is eerily similar to what I had in my head and drew down I think with modern linear actuators, the proper response time could be met, but cost is $$$$. The 787B looks to be hydraulic? |
02-07-2012, 10:35 AM | #634 |
Hot Dog
Drives: quicker than arghx7
FYI the current Yamaha R1 motorcycle has variable tuning velocity stacks. It's a great idea!
"Wisdom is a not a function of age, but a function of experience."
Just Say No to unqualified aftermarket products. |
02-07-2012, 10:57 AM | #635 |
Pro Subie Engine Nerd
Drives: BRZ has a reserved space
yup nothing new. Already mentioned two examples I was going to site, as well as dozens of Formula SAE cars.
02-07-2012, 11:05 AM | #636 |
Wiring Nerd
Drives: 1994 Supra
What about the exhaust side? Too much heat to deal with?
02-07-2012, 12:32 PM | #637 |
sealing issues would seem more the thought.
02-07-2012, 01:13 PM | #638 |
Kuruma Otaku
What do the butterfly valves in bike exhaust/collectors do?
Because titanium. |
02-07-2012, 03:52 PM | #639 |
Drives: '06 AM V8V Coupe
Don't know if this was exactly correct but I think they increase pressure in the exhaust manifold (slightly) to change the speed of the exhaust waves.
02-07-2012, 04:36 PM | #640 |
^^^my thoughts too. Only reason I could see it being useful. With such a broad powerband, opening and closing an extra tube would change effective diameter of the runner.
02-07-2012, 05:24 PM | #641 |
Drives: 2010 Evo X MR-T
02-07-2012, 05:32 PM | #642 | |
Kuruma Otaku
It sounds like it's in the middle of the collector on a 4-1 setup. If it can increase return wave strength for better scavenging at low rpm, it shouldn't matter if it chokes off some of the exhaust, as flow is minimal anyways, right? Going to look for some with/without dyno charts now... (EXUP, go Yamaha!)
Because titanium. |
02-07-2012, 06:56 PM | #643 |
Okay yea so I got it wrong, it's not to increase the overall pressure, but to change the way the exhaust wave reflects back.
So I have a question since I'm too lazy to crunch a few numbers, exhaust scavenging effect on a 4 cylinder comes from the cylinder firing 180 degrees after right? So with a twin scroll turbo you essentially eliminate exhaust pulse interference effects? |
02-07-2012, 07:28 PM | #644 | |
Kuruma Otaku
Edit: Found Yamaha's explanation on their site: http://www.yamaha-motor.ca/technolog...oup=M&tech=EUP
Because titanium. Last edited by Dimman; 02-07-2012 at 08:37 PM. Reason: Edit |
Similar Threads | ||||
Joke Thread | VenomRush | Off-Topic Lounge [WARNING: NO POLITICS] | 27 | 07-09-2011 12:44 AM |
The Music Thread | aliphian | Off-Topic Lounge [WARNING: NO POLITICS] | 13 | 03-28-2011 11:35 AM |
engine swap thread | aspera | Engine Swaps | 231 | 03-15-2011 05:10 PM |
FT-86 to debut new GPS-track day technology for use on track and GT5! | Hachiroku | Scion FR-S / Toyota 86 GT86 General Forum | 17 | 01-30-2010 11:30 AM |
Official MMA Thread | zigzagz94 | Off-Topic Lounge [WARNING: NO POLITICS] | 11 | 12-15-2009 10:59 PM |
