04-03-2015, 10:32 PM | #6203 |
DrivinginDreams...Cloud86
Drives: Toyota GT86
My only issue upon inspection is to find that one of the side mounts is cracked. When I arrived home to find the box outside my door, the bottom of the box was split open and I am under the impression my package was not handled as well as it could have been by the shipping company.
Anyone else run into this? What should I do? The one side is perfect, but as you can see the other is not. On the positive side of things, from the top, the damage does not seem to go very deep. |
04-03-2015, 10:48 PM | #6204 | |
Drives: JDL Turbo FRS, 335SC BRZ (ret)
The Following User Says Thank You to Xero-Limit For This Useful Post: | Chad86 (04-03-2015) |
04-03-2015, 10:51 PM | #6205 | |
Drives: Raven FR-S
UPS sort facilities are not friendly places. My brother worked at one part time and he said they literally just threw packages around....fragile ones too.
Raven FR-S mods: Unichip, Ground Control street coilovers with camber plates and strut tower brace, SPC Lca's, Drag DR-38 wheels with Dunlop Direzza DZ101s, Perrin CAI and silicone inlet tube, Perrin 3" resonated catback, Perrin high flow catted front pipe, Rev Works UEL header.
The Following User Says Thank You to CK_Bladesmith For This Useful Post: | Ultramaroon (04-04-2015) |
04-03-2015, 11:25 PM | #6206 | |
Drives: Toyota GT86
04-03-2015, 11:55 PM | #6207 |
Super 86
Drives: Red 86 GTS
Anyone have the gates part numbers for the idler pulley and 75mm belt? Got some squeaking and want to stamp it out.
230rwhp/184ftlb on 98RON/93AKI
Build thread Red 86 GTS MT | Sprintex Intercooled Twin Screw SC | Invidia N1 | Mocal 10 row | Invidia Front Pipe | Motiv Overpipe| Enkei RPF01 with Bridgestone RE002s | MCA Blue Coilovers | Radium Catch Can |
04-04-2015, 12:05 AM | #6208 | |
chicken tonight
That thing was dropped hard. |
04-04-2015, 01:26 AM | #6209 |
Drives: 2013 FR-S/C
Snapped a stock belt. Scouring the thread for replacement part that works on my 70mm pulley
04-04-2015, 01:38 AM | #6210 |
Drives: 13 BRZ Limited, 2000 Impreza Sport
K061015 is the p/n I am running. Stock size works fine on the 70mm. I keep a spare one under the trunk mat with a 14mm wrench in case it snaps on the highway, but have not had any issues after 8,000 miles on the 70mm
Innovate powered- Corn fed- FBM tuned
The Following User Says Thank You to poorsche For This Useful Post: | R3NIK (04-04-2015) |
04-04-2015, 01:55 AM | #6211 |
Drives: 2013 FR-S/C
Trying the k061010 from my search. Gotta love Amazon next day delivery. The supplied belt had a bit more slack than I like when twisting it.
04-04-2015, 02:13 AM | #6212 | |
Drives: Smells like tires when I drive
04-04-2015, 02:41 AM | #6213 |
chicken tonight
Respectfully, I recommend a more supportive packaging process. With the sensitivity of the compressor internals the whole thing should be better padded. I'd bolt the intake manifold to a slightly oversized wooden beam to prevent buckling and use bags of that expanding foam stuff all around. Rough handling and drops during shipment are a given no matter who the carrier.
04-05-2015, 10:43 PM | #6214 |
Drives: Toyota GT86
Anyone run a vented hood for their supercharger? Looking at the RKSport hood to pull more air.
04-06-2015, 10:07 AM | #6215 |
Did you get a blue belt?
04-06-2015, 11:24 AM | #6216 |
Drives: 2013 FR-S/C
Similar Threads | ||||
Innovative ideas to increase interior storage capacity? | swift996 | Cosmetic Modification (Interior/Exterior/Lighting) | 0 | 01-30-2013 10:45 PM |
AVO vs Innovative | diss7 | Forced Induction | 32 | 01-21-2013 06:15 PM |
Not another need to drive topic | Sargy | Mid-Atlantic | 5 | 11-27-2012 12:18 PM |
Technical topic sub-forums | OrbitalEllipses | Site Announcements / Questions / Issues | 1 | 07-17-2012 11:38 PM |
Can you close the topic please? | Standardsuspension | Brakes, Suspension, Chassis | 14 | 06-26-2012 05:14 PM |
