go_a_way1
Old 09-27-2023, 11:20 AM   #5993
Breadman
Breadman's Avatar
Drives: 2017 BRZ w/PP
The shock of slamming into your limiter can definitely caused the belt to skip, as the tensioner won't be able to keep up with that.
It's also really, really unhealthy for the supercharger's main shaft, so do try to avoid hitting the limiter!
Skill issue, I thought I had the rpm and I didn't
Breadman is offline   Reply With Quote
Old 12-02-2023, 06:01 AM   #5994
Yonany
Originally Posted by johnnyeisu View Post
After consulting with a highly reputable mechanic, I've decided to get my C38 warrantied and hopefully replaced with a less noisy unit.
Do you guys think I should ask for a C32 unit as they are known to make no noise? If so, would my current flex fuel tune work on a C32 or would I have to get that done again?
Did you get another unit?
was is silent?
I have two friends with the JRSC.
One owned it for 1-2 years and is pretty silent.
The other one installed it recently and has the "crickets" sound.
I have just installed mine and yeap, very loud crickets sound.
like this.
is it possible that the belt pushes the pulley a little bit too hard to the point it moves the internal shaft enough to make the blades contact the housing?
how harmful is it?
will it just wear out? if so, would it affect performance?
Yonany is offline   Reply With Quote
Old 12-02-2023, 03:31 PM   #5995
PulsarBeeerz
Drives: JRSC BRZ SOLD
was is silent?
like this.
how harmful is it?
Looks like 2 C38s vs one C30? I would expect the c30 unit to be quieter as it is smaller.
PulsarBeeerz is offline   Reply With Quote
Old 12-04-2023, 02:22 PM   #5996
johnnyeisu
was is silent?
like this.
how harmful is it?
Here's how mines turned out after the warranty:
With the hood open I can hear the crickets, but it's waaaaay quieter. You'd have to really listen for it while driving to hear it over all the vroom vroom noises.
johnnyeisu is offline   Reply With Quote
The Following User Says Thank You to johnnyeisu For This Useful Post:
CSG Mike (12-04-2023)
Old 12-08-2023, 12:39 PM   #5997
Yonany
Me and my friends all have the C30.
Wow! what a difference, yours is basically silent.
The crickets noise from my unit is much lower now.
Mic didn't pick up the sound 100%, but you can tell its still there.
Here is a video of my setup:
Old 12-08-2023, 02:19 PM   #5998
jbailey8748
jbailey8748's Avatar
Drives: 2013 Satin White Pearl BRZ
I need to replace one of the idlers that came with the kit. What are y'all doing for those. I'm not seeing anything on the jrsc website.
Sent from my SM-S908U using Tapatalk
jbailey8748 is offline   Reply With Quote
Old 12-11-2023, 10:10 AM   #5999
Breadman
Breadman's Avatar
You can call them and ask for the part and they will sell it to you.
Old 01-30-2024, 02:23 AM   #6000
BatStig
Some say.....
BatStig's Avatar
Drives: 2007 Subaru Impreza 2.5i
Does anyone have an ACE Radiator and Intake Scoop installed with your JRSC?
If so, how did it turn out? How was the installation around all the JRSC piping? Was it helpful, specifically at the track?
Thanks!
BatStig is offline   Reply With Quote
Old 01-30-2024, 03:55 PM   #6001
Thanks!
You can accomplish virtually the same result by trimming your original factory side air guides.
Make sure all the foam around the top of your radiator is intact.
Venting your hood will have a much larger effect. Also, make sure your fender liners are fully intact. If you are not running liners, the Ace shroud will help more by band-aiding the lack of liners.
BatStig (01-30-2024)
Old 01-31-2024, 11:49 PM   #6002
BatStig
Some say.....
BatStig's Avatar
I already have the Trackspec vents. Fender liners will be fully intact once I remove the brake ducts I no longer need thanks to my lovey CSG pads. I am upgrading my radiator and I will make sure that all stock foam and air guides are in place. I am just trying to get as much air to get through the stack as possible.
While searching for anyone who had used the Ace Scoop, I found a post from you from 2021:
The intake ducting is fantastic. Most folks use it as a base, and trim as needed to clear their water pump hoses, oil cooler lines, etc.
That sounded exactly like what I was looking for. Unfortunately, this turning into a waste of time as I can't get a response from Ace. It looks like a JDL Bash Bar and some DIY ducting will be a part of my winter plans.
Thank you @CSG Mike!
Old 02-01-2024, 12:12 AM   #6003
It's easier than it may seem, as really, you only need to do the pieces on the sides and one at the top of the radiator.
The JDL bash bar will make mounting the intercooler more challenging, but can be done.
BatStig (02-01-2024)
Old 03-19-2024, 02:42 AM   #6004
exgladous
Drives: 2017 BRZ PP
This is the first time I've heard of this. Logically makes sense though. Is this a problem with stock pulley cars?
exgladous is offline   Reply With Quote
Old 03-19-2024, 02:16 PM   #6005
M0nk3y
FWIW I have an ACE Shroud Installed.
Shows pretty easily what you need to do for install and drilling for IC Piping, this is Harrop Install.
The hoses are now wrapped with 1" Heater Hose so they don't chafe
Kyle H. - #89 STX
The Following 2 Users Say Thank You to M0nk3y For This Useful Post:
BatStig (03-19-2024), RT-BRZ (03-20-2024)
Old 05-18-2024, 08:55 AM   #6006
mrg666
pessimistic skeptic
mrg666's Avatar
I just replaced the traction fluid second time in seven years with JRSC. Everything is still running fine.
I use the following straight through exhaust system to reduce the stress on the engine with JR stock tune.Works great.
2019 86 header
HKS Hi Performance SpecL exhaust
HKS dual resonator front pipe
I also have the JR dual radiator installed to help with heat.
The only big problem I had was because of the failed valve springs that is a known problem but I had to pay out of pocket to replace them since installing JRSC voided the warranty. While doing the replacement, the service left two of the ignition coils loose and I had to figure out the problem myself after that. With those done, car is back to normal.
No regrets, and still very much satisfied.
Jackson Racing Rotrex Supercharger System Info and Discussion Jackson Racing Forced Induction 827 04-06-2020 04:56 PM
Jackson Racing Supercharger Press Release and Info CounterSpace Garage Forced Induction 110 01-03-2017 09:04 PM
jackson Racing engine oil cooler - modular to fit the Jackson Racing Supercharger! CSG Mike Forced Induction 24 04-27-2016 12:59 PM
Jackson Racing supercharger NoppyNop Forced Induction 241 06-26-2014 03:05 PM
Jackson Racing Supercharger Pre-Order Sale, $200 off! Xero-Limit Forced Induction 2 03-05-2014 04:14 PM
