go_a_way1, MisterSheep, Sarlacc, Tcoat
Old 01-05-2016, 11:46 AM   #43
wise345
Slow I am, boost I must..
wise345's Avatar
Drives: Whiteout 2013 FRS
Originally Posted by Andew727 View Post
i wasnt boosted very long before an intake valve went. they arent expensive and they are very brittle stock. build your heads! i was making around 280-300 whp with the base v1 kit supporting fuel mods and ran e85. the best part is the power curve. its a solid line no dip, no big boost curve. once she gets up around 4,000 rpm... she gone. i would also replace rods if you are going to introduce any boost over 12 psi at 12.5 to 1 CR. i used a cosworth head gasket to lower compression about .08-1.0
my motor is sitting in the garage waiting for my connecting rods to finish being made currently*
my best advice is to make sure you keep an extra budget for the possibility of something going wrong after you boost your car. that or buy once and cry once. strengthen your heads and run 9-10 psi. the car should be what you're looking for with a conservative tune
How much would you estimate for heads and rods?
wise345 is offline   Reply With Quote
Old 01-05-2016, 11:48 AM   #44
FRSCanuck
Drives: Scion FRS
Originally Posted by wise345 View Post
No issues on that setup?
none whatsoever
FRSCanuck is offline   Reply With Quote
Old 01-05-2016, 11:51 AM   #45
Andew727
Drives: Scion FR-S
my valve springs were $250 and connecting rods are being built by skunk2 were a little less than $400 for all 4 (forged H beams) but i am letting a shop take care of the block.
edit* i think map performance will build heads to 1000hp for $1800-1900 if you supply your own core.
Andew727 is offline   Reply With Quote
Old 01-05-2016, 11:54 AM   #46
Andew727
Drives: Scion FR-S
Originally Posted by FRSCanuck View Post
I have the HKS kit for about a year now and I highly recommend it. Currently pushing 290whp on 93octane, more than enough power for the street and fun on the track as well.
Here's the dyno chart below along with my current setup. Car is tuned with ECUtek.
- HKS injector upgrade
- HKS oil cooler
- Tomei EL headers
- Tomei front pipe
- Tomei over pipe
- Greddy CS GTS V2 catback
id really like to hear how that sounds dude. any videos? also what is your peak boost? bored 42mm restrictor?
Old 01-05-2016, 02:34 PM   #47
FRSCanuck
Drives: Scion FRS
I don't have any videos but I like the setup. The only downside is it does get a bit loud when you open up the throttle, makes it hard to have a conversation with a passenger when your on the highway/expressway.
peak boost is around 8psi.
The Following User Says Thank You to FRSCanuck For This Useful Post:
Andew727 (01-05-2016)
Old 01-06-2016, 12:07 AM   #48
wise345
wise345's Avatar
id love to hear it let me know if you grab a vid sometime
Old 01-06-2016, 03:35 AM   #49
Yobiwan
Yobiwan's Avatar
Drives: Toyota 86 Turbo, Lexus NX300H
- HKS oil cooler
- Tomei EL headers
- Tomei front pipe
- Tomei over pipe
nice number.
Did you enlarge inlet diameter of restrictor? if then , how much?
I'm using Tomei UEL, HKS V2 SC with 41.5mm restrictor now.
Yobiwan is offline   Reply With Quote
The Following User Says Thank You to Yobiwan For This Useful Post:
BRZ_F (01-06-2016)
Old 01-06-2016, 11:06 AM   #50
wise345
wise345's Avatar
Does the V3 come with a restrictor?
Old 01-07-2016, 10:53 AM   #51
FRSCanuck
Drives: Scion FRS
Originally Posted by Yobiwan View Post
nice number.
I used the restrictor plate that came with the fuel injector upgrade.
Yobiwan (01-10-2016)
Old 01-07-2016, 04:38 PM   #52
kidgogeta
Drives: FRS
- HKS oil cooler
- Tomei EL headers
- Tomei front pipe
- Tomei over pipe
[IMG]http://i.imgur.com/6Y
where are you getting your fuel from in canada?
kidgogeta is offline   Reply With Quote
Old 01-08-2016, 09:31 AM   #53
Scott@HKSUSA
Scott@HKSUSA's Avatar
Drives: 2013 FR-S, HKS V2 S/C
Negative. v3 is wide open!
Scott@HKSUSA is offline   Reply With Quote
The Following 2 Users Say Thank You to Scott@HKSUSA For This Useful Post:
CSG Mike (01-08-2016), wise345 (01-08-2016)
Old 01-08-2016, 10:48 AM   #54
wise345
wise345's Avatar
Alright awesome awesome. Would you think someone who hasn't installed a supercharger system could figure it out over a weekend with your kit?
Old 01-08-2016, 11:39 AM   #55
FRSCanuck
Drives: Scion FRS
Petro Canada
Old 01-08-2016, 01:33 PM   #56
Yoda
Drives: Crystal Black BRZ(Sophia)
My vote is for SBD. You will miss the torque.
Yoda is offline   Reply With Quote
:popcorn:, why not?
HKS Supercharger V2 vs. Greddy Turbo Kit vs. Crawford Turbo Kit Ogremair Forced Induction 27 09-10-2015 04:39 AM
Supercharger vs Turbo MPG ? LoCo Forced Induction 23 06-27-2015 05:24 PM
Which is better turbo or supercharger? Ryan_FRS86 Forced Induction 94 05-18-2015 12:26 PM
Looking for a turbo or supercharger kit!! Anthony7515 Want-To-Buy Requests 11 05-16-2014 08:25 AM
HKS Supercharger / Avo Turbo Kit / Greddy Turbo Kit - All Available at Import DPS!! rickspecd Forced Induction 4 07-12-2013 11:50 AM
