08-07-2015, 05:17 PM | #43 | |
( ͡° ͜ʖ ͡°)
Drives: '13 Whiteout FR-S A/T
Sent from my A0001 using Tapatalk |
08-07-2015, 06:18 PM | #44 | |
Drives: 2005 Toyota Camry
The static weight distribution part is just pure marketing. If you see professional race teams and what they talk about when it comes to car setup, they never talk about this because it's only a minor part of what they are trying to keep secret. Static weight distribution is only useful when you have a car sitting there, not moving. You're so stuck on the static weight distribution that you're missing one large part of weight distribution: actual weight distribution when you factor in downforce front/rear. The car's tires, contact patch, and alignment need to consider weight distribution when aero comes into play. You can armchair weights all day but ultimately it may be completely counterproductive given your driving style and habits. As is already mentioned, work on items you can adjust easily on the car before you go about reducing weight. I think you'll find much better improvements. -alex |
The Following 2 Users Say Thank You to mav1178 For This Useful Post: | strat61caster (08-07-2015), why? (08-06-2018) |
08-07-2015, 06:28 PM | #45 | |
BOXER FR
Drives: WRB BRZ Limited
Andy
Build Thread of the "STI theme BRZ"http://www.ft86club.com/forums/showthread.php?t=61522
The Following User Says Thank You to mokinbird87 For This Useful Post: | mav1178 (08-07-2015) |
08-07-2015, 06:40 PM | #46 | |
Weight savings is easily accomplished. Changing weight distribution is better achieved on our cars by moving weight (ballast) around. Weight savings AND improving weight distribution is incredibly hard to do on a lightweight car like ours with not much to take out. -alex |
The Following User Says Thank You to mav1178 For This Useful Post: | strat61caster (08-07-2015) |
08-07-2015, 06:52 PM | #47 |
Drives: FR-S Whiteout
^ dude... you guys must be bored. lmao I'll see y'all at Autoclub.
Intent > Content
cowardice is the mother of cruelty. |
The Following User Says Thank You to solidONE For This Useful Post: | mav1178 (08-07-2015) |
08-07-2015, 08:00 PM | #48 | |
Drives: '23 BRZ Limited
Do you have a rolling road wind tunnel with which to test? |
08-07-2015, 08:25 PM | #49 | |
Now, we can extrapolate out downforce generated, and force at each corner. Conveniently, 86CUP runs at ACS tomorrow. What great luck! |
08-07-2015, 09:57 PM | #50 |
i'm sorry, what?
Drives: Canada
how much downforce is a stock FRS generating though?
08-07-2015, 10:06 PM | #51 |
That is computed by comparing a photo of the car sitting, vs the car at ACS at 100mph on the front straight. Based on the height change (if any) and the known spring rates....
You get the idea (A 100% stock car is pretty darn close to zero-lift) |
08-08-2015, 10:58 AM | #52 |
Drives: 2015 BRZ
Practically zero. If anything, there's a little bit of lift at higher speeds. Here's a plot showing ride height vs. speed at three separate track days.
Green- Stock Suspension, RE71Rs Orange- Tarmac 2s, lowered 1" with 3/8" of rake Blue- Same as orange, but with swaybars. Included for reference. As you can see, there's definitely a tendency for ride height to increase at higher speeds on the stock suspension. By lowering the car and adding a little bit of rake, that tendency has been reduced. We will be testing the Velox splitter and diffuser in a few weeks to see how much of a different it makes. |
08-08-2015, 11:37 AM | #53 |
I'm not sure what method C&D used to calculate lift, but they found @ 70mph, a stock BRZ had 25 lbs. lift F / 35 lbs. lift R:
http://media.caranddriver.com/files/...lete-specs.pdf
2022 BRZ Build 2013 FR-S Build |
08-08-2015, 11:47 AM | #54 | ||
That's pretty damn impressive considering how many cars start to get light with speed. |
The Following User Says Thank You to OkieSnuffBox For This Useful Post: | DAEMANO (08-08-2015) |
08-08-2015, 12:28 PM | #55 | |
Drives: 2015 BRZ
http://www.ft86club.com/forums/showthread.php?t=26661 Looks like we saw 34 lbs of lift at 70 mph, averaged across the car. I'm nerding out so hard right now. Jake |
The Following 10 Users Say Thank You to GSpeed For This Useful Post: | CSG Mike (08-09-2015), DAEMANO (08-08-2015), DarkSunrise (08-08-2015), drewbot (08-08-2015), fstlane (08-08-2015), mokinbird87 (08-08-2015), NLSP (08-08-2015), philooo (08-09-2015), solidONE (08-08-2015), Ultramaroon (08-08-2015) |
08-08-2015, 12:45 PM | #56 | |
The Following User Says Thank You to DarkSunrise For This Useful Post: | GSpeed (08-08-2015) |
Similar Threads | ||||
Making the BRZ ever lighter | Alabang BRZ | Cosmetic Modification (Interior/Exterior/Lighting) | 10 | 04-16-2014 08:57 AM |
Are dry carbon fiber front 1/4 panels lighter than OEM? | Superhatch | Cosmetic Modification (Interior/Exterior/Lighting) | 5 | 05-27-2013 03:47 AM |
Better to go wider or lighter? | BRAWL | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 21 | 08-02-2012 09:48 PM |
Increased whp by having lighter wheels | mechaghost | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 26 | 07-03-2012 12:46 AM |
What return from going with lighter wheels? | bazguitarman | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 30 | 06-01-2012 09:35 AM |
