11-14-2013, 01:34 PM | #43 | |
Any race/drift teams running EJ engines are more than likely running full standalones with partially tube framed cars so it's not nearly the same as running the same swap in a streetable car. Add to the fact that you're gambling with a used engine that you don't know the accurate history of and it's really not a winning proposition. Sure some engines are great, but some are total junk. PLUS, if you're in Ontario it's illegal to swap in an older engine.
11-14-2013, 01:45 PM | #44 |
Mark @ STILLEN
Drives: 2015 Subaru BRZ
I've done custom wiring on engine swaps...it can be a PITA. Also the stock turbo system on the EJ won't work on the FT86. Greddy did a EJ25 swap with custom turbo kit and they had to route the turbo system the same way their kit does to make it fit. I really don't think this would be a cost effective option. Tuning an EJ swap would obviously be easier and cheaper but I feel like the cost will just be too great and you'd basically have to get the FT86 turbo tuner kit anyways.
11-14-2013, 02:14 PM | #45 |
Drives: FRS :D
How would you go about this and keep the car legal? Can't swap in a older engine to the car since its illegal unless your car is going to be a track only car.
Out of the FRS game
11-14-2013, 02:18 PM | #46 |
It depends where you live. Virtually everything you do to a car is illegal in California, whereas you can do just about anything you want here in florida.
The Following User Says Thank You to jamesm For This Useful Post: | Sportsguy83 (11-14-2013) |
11-14-2013, 02:22 PM | #47 |
Drives: Attitude
You guys do realize the engine pickups are different between the two architectures? Custom subframe/cradle work going to required for, what is in my opinion, an inferior engine.
The Following 4 Users Say Thank You to OrbitalEllipses For This Useful Post: |
11-14-2013, 02:57 PM | #48 |
Drives: FRS :D
you crazy Americans In Canada you aren't allowed to swap older engines into newer chassis as far as I know
Out of the FRS game
11-14-2013, 04:26 PM | #49 | |
Cone basher
Drives: 2017 Subaru BRZ Series.Yellow
If you throw enough money at it you can put any motor you want into the FT86 chassis, but if we're talking about cost effectiveness. I think just low compression pistons in the FA20 would be the smarter choice. Plus a great example would be crawford's car. I've never heard of any Impreza making that kind of power on a stock turbo. |
11-14-2013, 07:55 PM | #50 |
Mark @ STILLEN
Ken Gushi's Greddy/Cosworth EJ25 Drift Car...
Cosworth CS600 EJ25-based powerplant Cosworth dry sump system GReddy TD06SH-25G turbo Not sure if they have a custom subframe to fit the motor. Also, did anyone talk about the Transmission for an EJ20 swap yet?
11-14-2013, 07:59 PM | #51 |
Site Moderator
Drives: ichi 86 Project
I've heard a rumor that, some shop (I'll keep it unknown) is trying to make turbo 86 AWD.
Similar Threads | ||||
2JZ swap? | jordydiaz | Engine Swaps | 44 | 05-21-2015 10:19 PM |
2UR-GSE Swap | czar07 | Engine Swaps | 9 | 08-29-2012 01:43 PM |
Should I swap? | michaelahess | BRZ First-Gen (2012+) -- General Topics | 8 | 06-12-2012 07:32 PM |
Trunk Swap? | Coconut | Cosmetic Modification (Interior/Exterior/Lighting) | 1 | 04-25-2012 09:47 PM |
swap brz front end with fr-s? | koyv90 | Scion FR-S / Toyota 86 GT86 General Forum | 17 | 02-07-2012 03:23 AM |
