Old 09-20-2015, 01:31 AM   #43
strat61caster
strat61caster's Avatar
Originally Posted by Locust View Post
Hyman GTR is like 740whp and 800 for pros I think.
I also think the OP checked out of this long ago and decided he hates autocross because it "isn't real racing".
Nah he doesn't hate it, just doesn't think it's worth pouring the money into.
And I totally agree with his point, if I'm going to spend tens of thousands of dollars I'd rather bang fenders with other drivers in wheel to wheel racing than hit cones. IMO if I'm going to trailer a car to an event it's because there's a not insignificant chance it won't be drivable at the end of the day. But that's entirely personal preference and choice.
Don't get me wrong, I love autocross as much or more than HPDE at this point and am seriously considering an STX build, but I've got another second to find in my driving before I drop a good $10k on building a car I could take to nationals...
ineedyourdiddly
Old 09-21-2015, 01:57 PM   #44
whataboutbob
AutoX-10/10ths every run
whataboutbob's Avatar
I haven't checked out of this thread.
[ Delicioustuning | Counterspacegarage | RS-R USA | Cusco USA | SPL Parts | ACE Header | Stark Performance | Infinite Motion | Ciro Racing | Build thread:Here ]
[ GR Corolla Core in White w/LSDs on wish list ]
whataboutbob is online now   Reply With Quote
The Following 2 Users Say Thank You to whataboutbob For This Useful Post:
mitch t (03-31-2016), strat61caster (09-21-2015)
Old 09-21-2015, 06:22 PM   #45
Locust
Custom User Title
Locust's Avatar
Drives: 2015 Scion FR-S, 2012 OB Evo X MR
Send a message via AIM to Locust
Woops! Confused it for the other thread that was a total train wreck. My apologies Bob!
LOCUST
2015 FR-S (STX) and 2012 Evo X MR
Instagram:
LocustAutoX
Sponsors:
DSGPerformance Drift Office Evil Apex Racing
Locust is offline   Reply With Quote
The Following 3 Users Say Thank You to Locust For This Useful Post:
e1_griego (09-21-2015), strat61caster (09-21-2015), whataboutbob (09-21-2015)
Old 09-21-2015, 07:17 PM   #46
whataboutbob
I know which thread you were talking about.
The Following User Says Thank You to whataboutbob For This Useful Post:
Old 02-01-2016, 04:21 PM   #47
whataboutbob
2015 San Diego SCCA Street Modified Champion Jacket.
Hyper4mance2k (03-02-2016)
Old 03-10-2016, 06:43 AM   #48
Thorpedo
The SquadWhisperer
Drives: '13 Ultramarine FR-S (STX)
Any of you SM folks care to share what size hoosiers you're fitting under the stock bodywork? Wheel specs too if you're feeling generous?
I've given up on being pax competitive, but I'm going FI so I may as well make the most of it.
2013+14+15 Atlantic Region Motor Sports Autocross STX Champion
2013+14+15 Atlantic Region Motor Sports Overall Autocross Champion
2017 Bluenose Autosport Club Overall Rallycross Champion
Powered by Great North Performance, Jani-King Canada, and OK Tire.
Thorpedo is offline   Reply With Quote
Old 03-23-2016, 01:33 PM   #49
itzmik3
DBC Racing
itzmik3's Avatar
We fit a 285/30/18 A6 mounted on a ZE40 18x10 +40 in the rear if i remember correctly....
it has been a while since the car has ran so i apologize in advance if im off
we didn't run a stock front fender, so can't help you on the front specs
#194 SM
itzmik3 is offline   Reply With Quote
The Following User Says Thank You to itzmik3 For This Useful Post:
Thorpedo (03-23-2016)
Old 03-24-2016, 10:26 AM   #50
xwd
I test fit a 275/40/17 on a 17x9 wheel spaced out to +40 and it fit in the front and rear. That's with -2.8 degrees in front and -2 in the rear. The front you start to get near suspension components on full lock though so spacing it slightly further out might be advantageous. I'd just do bolt-on flares in the front if you are going that route anyways. They fit fine in the rear.
Old 03-29-2016, 11:49 AM   #51
Thorpedo
The SquadWhisperer
Thanks for the help. I'm surprised they fit that well as those are over an inch taller than stock. I run a lot more negative camber so I might go just a tad skinnier than that if they are available. 265/35 would be my preference but I don't see them on tire rack. They do have 275/35 though....
Old 07-15-2019, 09:28 PM   #52
BRZ RN
BRZ RN's Avatar
Drives: Blue BRZ
based on the discussion looks like SM should at least use hoosiers. i will be having a 245/40/17 re71r and eventually an extra set of wheels for hoosiers.
BRZ RN is offline   Reply With Quote
Old 07-15-2019, 09:48 PM   #53
xwd
Timely bump, I'm at least for now putting my SM build up for sale.
http://www.ft86club.com/forums/showthread.php?t=135807
Old 07-16-2019, 01:10 PM   #54
strat61caster
How did the 285/315 Hoosiers fit up front with stock fenders?
I love my STX build right now but I know once the frz86s go out of style I was thinking an sm-lite build would be fun with a Street legal super charger and just slap some Hoosiers onto it for giggles. I figured even 245/40/17 Hoosiers would be a tight fit on 17x9 STX wheels...
ineedyourdiddly
Old 07-16-2019, 05:27 PM   #55
xwd
285s fit without a lot of drama with the right offset, mine ended up at 38mm. In my case I have the racerx front arms and the design isn't indented so the tire barely hits the control arm at full lock. Everything is close but they don't get closer under compression. The rear depending on the offset you run close to where the body opening is for the shock, there is a lip there which kind of sticks out.
315 is an entirely different story. I bought the wheels with the tires on them. The 315s are not only wide they are also very tall. The easy button is just space it out till things fit and cut the body/add flares but it's not ideal for autox. It would require relocating some things and cutting stuff to keep from doing that.
Old 07-16-2019, 06:30 PM   #56
strat61caster
wut
that's kind of the basic starting point required for building a competitive Street Prepared/Street Mod/Prepared car, anything less is leaving speed on the table.
Cheers for the 285's fitting though, gives me the confidence to gamble on the 275/35/17 A7's when I decide to hit the purple crack pipe again.
ineedyourdiddly
SCCA Solo C Street Discussion Kido1986 Tracking / Autocross / HPDE / Drifting 4833 07-08-2020 03:52 PM
2014 SCCA Solo Nationals/Pro Solo Finale thread edj Tracking / Autocross / HPDE / Drifting 206 09-19-2014 11:34 AM
Henry's C Street (SCCA Solo) progression Kido1986 Tracking / Autocross / HPDE / Drifting 74 05-04-2014 08:20 PM
2013 Preliminary SCCA SOLO and PRO SOLO National Schedule Scooby South Tracking / Autocross / HPDE / Drifting 13 12-05-2012 08:08 AM
Houston SCCA Solo #9 - 5 FRS, 1 BRZ hankster Tracking / Autocross / HPDE / Drifting 0 10-09-2012 01:35 PM
