Engine, Exhaust, Transmission Discuss the FR-S | 86 | BRZ engine, exhaust and drivetrain. |
02-10-2015, 03:53 PM | #43 | |
Shadetree Project Ratchet
Drives: series.Blue
It's like Darigold saying skim milk has all the flavor of whole milk... But, now we're entirely off topic. Obviously any header needs a tune to make the most power out of it, but you have to admit, a tune for an EL manifold should out perform a tune optimized for an UEL manifold, and that's where I find fault. Back on topic. This header rocks for the price, and we need some more people who have it to get tunes to see how it compares accross the market.
The Shadetree Project: I turn wrenches
02-10-2015, 04:02 PM | #44 | |
Drives: rocketship
02-10-2015, 04:12 PM | #45 | |
Drives: The silvertrooper 10 series
We will have one of the local cars tuned very very shortly with his Skunk2 EL header.. Unfortunately.... or Fortunately depending on how you look at it, a Kraftwerks C30 blower will be added at the same time as the tuning lol. BUT he has had the header for the last month and he loves it. His setup sounds really good, and is currently the only EL setup i personally like the sound of, Skunk2 header, MXP overpipe, OEM front pipe and Perrin 3" catback. Mike from Moto-East will be setting up the tune, but the base canned tune he sent felt great. We do have 2 cars running the same kits, just different headers and we will be getting dynos. we know it wont be a perfect scenario but both will be on the same fuel, SC kits, and mapped from the same tuner. only difference will be the 2 exhaust setups. -Thomas P.S. out of the 4 cars here in Vegas, not one has had a CEL at this time |
The Following User Says Thank You to 86SPEED For This Useful Post: | Hyper4mance2k (02-10-2015) |
02-10-2015, 04:49 PM | #46 |
Drives: series.Blue
My car gets a CEL with the header, but I'm still on the stock tune, so obviously it should. I even tried the spacer trick and it only delays the CEL for about 800 miles.
Has anyone ever successfully tried one of those mini cats (spacer with a tiny chunk of "Catalyst")?
02-10-2015, 05:04 PM | #47 |
Drives: rocketship
I went back to stock tune as my tuner wanted to do some more homework based on what we learned from the OFT UEL tune specifically.
My tuner's original tune still did the best up top (but laggy and choked in the bottom) but the OFT UEL tune gives some ideas about waht to do on the bottom end in the torque dip area. Till he comes up with a few solutions to try later this weekend I am back on the stock tune. No CEL so far. I do like the osund of this header, there is some rasp with the stock tune past 4k RPM. Swapped my 3 inch perrin resonated catback to a 2.5 inch perrin resonated. Loving it so much more as there is minimal drone. The sound was brilliant with the UEL OFT tune I must say. |
The Following User Says Thank You to sachu For This Useful Post: | Hyper4mance2k (02-10-2015) |
02-11-2015, 05:31 PM | #48 |
Ultimate Member
Drives: 2014 Satin White BRZ
I don't have dyno numbers but I I am running
OFT stage 2 EL tune Skunk2 Header Tomei Overpipe @MAPerformance 3" front pipe and catback I have noticed that where the header meets the tomei over pipe has a small leak at the bottom. I am going to try and replace the gasket that came with the Skunk2 header with the tomei overpipe gasket that I have and see if that fixes it. Installed pic: Cold Start Video: [ame]http://youtu.be/HjUKvCqqyNg[/ame] About 70% Acceleration Video: (yes I changed my wheels while it was in the air) [ame]http://youtu.be/8Qq3oxRRnUM[/ame] |
The Following 2 Users Say Thank You to limitedblkwrx For This Useful Post: | Hyper4mance2k (02-13-2015), MAPerformance (02-11-2015) |
02-11-2015, 05:38 PM | #49 |
Drives: '14 981CS, '99 NB1
02-12-2015, 09:00 PM | #50 | |
The shop car has well over 1000 miles with the skunk2 header with no CEL at all. |
02-13-2015, 01:10 AM | #51 |
Drives: series.Blue
I have a Skunk2 header. Just wait... I've put on over 2500 miles and I've had a check engine light 3 times. There's no cat and on the stock tune you're going to get a CEL.
02-13-2015, 01:49 PM | #52 | |
Drives: rocketship
Try running the OFT UEL tune..let me know how it feels from 2k-5k RPM compared to the EL tune. Also, the sound between the two tunes. Hearing that rasp with the EL tune i noticed in mine. |
02-13-2015, 04:31 PM | #53 | |
Drives: series.Blue
The Following User Says Thank You to Hyper4mance2k For This Useful Post: | limitedblkwrx (02-15-2015) |
03-01-2015, 12:43 AM | #54 |
Drives: rocketship
Here's my current tune with thefollowing mods.
Skunk2 header Skunk2 intake (with insert) Nameless overpipe/front pipe with cat Perrin 2.5 inch resonated catback Stock car versus modded tuned car. The insert on the intake needs to be removed and the MAF rescaled again. SO more gains to be had likely. I might go back to the stock overpipe and front pipe and see if that gives me more torque as well. Want to give a shout out to Wryaan at VIP performance for working on the tune.
The Following User Says Thank You to sachu For This Useful Post: | Hyper4mance2k (03-01-2015) |
03-01-2015, 01:49 PM | #55 |
Drives: series.Blue
Love it! And here I thought you needed e85 to make 200+ who NA.
03-01-2015, 03:27 PM | #56 |
Drives: Neptune GR86
His stock run was at 180whp which is unusually high though.
Similar Threads | ||||
Skunk2 Lowering Springs NOW AVAILABLE! | KraftWerks | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 23 | 01-10-2015 09:22 PM |
Skunk2 BRZ Intake Results! | Xero-Limit | Engine, Exhaust, Transmission | 21 | 10-20-2014 01:43 PM |
New skunk2 frs brz cold air intake | 831GT86 | Engine, Exhaust, Transmission | 17 | 09-09-2014 04:09 PM |
Skunk2 Garage Sale: 06.28.14 | KraftWerks | Southern California | 4 | 06-24-2014 08:53 PM |
FS: Skunk2 Racing 1.3 kg/cm Rad Cap ***SOLD*** | JPxM0Dz | Canada Classifieds | 0 | 10-01-2013 01:25 PM |
