01-11-2015, 10:00 AM | #43 |
Apparently the stock flywheel is dampening some drive-train vibrations (probably occurring in the transmission and provoked by the fact that the engine deceleration forces are varying). Not all cars get it but it appears to be common with other Subaru models too. http://forums.nasioc.com/forums/showthread.php?t=942273
Since this noise is occurring when there's no significant load on the transmission, I doubt it is harmful. It's not that bad, for instance, if you'd install a differential brace, you'll get more and permanent noise (not something you'd want as a highway commuter). |
The Following User Says Thank You to rx3 For This Useful Post: | GT86_PRAGUE (01-11-2015) |
01-11-2015, 10:16 AM | #44 |
The LW driveshaft won't add any noise as this is after the transmission.
(The vibration is occurring in the engine and transmitted to the clutch and transmission. The lighter flywheel does transmit more vibration to the transmission and probably depending on some tolerances in the transmission, the deceleration noise will be more or less noticeable). |
01-11-2015, 12:22 PM | #45 |
Drives: FR-S 10 #103 AT
Does anyone know offhand what ratio will get an A/T the closest to matching the overall final ratio of a factory M/T?
“Sex is like Bridge. If you don't have a good partner, you'd better have a good hand.” - Mae West Papa said, "son there's a lot of evil temptations out there. Best to try 'em all so you know which ones to avoid." |
01-11-2015, 03:09 PM | #46 |
Drives: 86
F it...do the 4.88 on a MT. Let us know how it is on the highway
4.67 would be a nice and DD-realistic middle ground though ..too bad there's no inexpensive/affordable option and I think the only one avail (MFactory) is noisy straight cut teeth and a bit more expensive than Weir. Wish Weir made an affordable 4.67 option. |
The Following User Says Thank You to M23 For This Useful Post: | GT86_PRAGUE (01-12-2015) |
01-11-2015, 03:27 PM | #47 |
Drives: Scion FR-S
01-11-2015, 03:47 PM | #48 | |
Drives: 2013 Scion FRS 6 Speed Raven Black
The Following User Says Thank You to ohnoitsthefuzz For This Useful Post: | jcw99 (03-06-2016) |
01-11-2015, 07:37 PM | #50 | |
Manual transmissions I=3.626, II=2.188, III=1.541, IV=1.213, V=1.000, VI=0.767 6th gear ratio, Differential ratio, and engine RPM's at 60MPH. 0.767 @ 4.10 = 2575 RPM's @ 60MPH 0.767 @ 4.30 = 2701 RPM's @ 60MPH 0.767 @ 4.55 = 2858 RPM's @ 60MPH 0.767 @ 4.77 = 2996 RPM's @ 60MPH 0.767 @ 4.88 = 3065 RPM's @ 60MPH Automatic transmissions I=3.538, II=2.060, III=1.104, IV=1.00, V=0.713, VI=0.582 0.582 @ 4.10 = 1954 RPM's @ 60MPH 0.582 @ 4.30 = 2049 RPM's @ 60MPH 0.582 @ 4.55 = 2168 RPM's @ 60MPH 0.582 @ 4.77 = 2273 RPM's @ 60MPH 0.582 @ 4.88 = 2326 RPM's @ 60MPH 0.582 @ 5.29 = 2521 RPM's @ 60MPH 0.582 @ 5.404 = 2575 RPM's @ 60MPH 0.582 @ 5.71 = 2721 RPM's @ 60MPH An A/T 4th gear is 1:1, running 3357 RPM's @ 60 MPH. 5th gear w/5.71 FD @ 60 MPH runs @ 3334 RPM's, so 5th gear is still overdrive, barely, even with the highest FD you can get. They don't make a 5.404 to 1 ring and pinion, so you can't match a manual's final drive. You can totally out-launch a manual though! First gear, (launch!) comparisons; 3.626 M/T 1st 4.10 FD = 7101 RPM @ 35 MPH 3.538 A/T 1st 4.56 FD = 7046 RPM @ 32 MPH 3.538 A/T 1st 4.88 FD = 7069 RPM @ 30 MPH 3.538 A/T 1st 5.29 FD = 7152 RPM @ 28 MPH 3.538 A/T 1st 5.71 FD = 7168 RPM @ 26 MPH Showing approximate redline speeds with each FD. I'm getting the complete rebuild package with 4.88 gears delivered TOMORROW! I just ordered the entire kit, bearings, seals, shims, solid spacer, and etc. from Spence @ Weir Performance and it got shipped Friday. Here's the price I'm paying for all the parts; FRS/BRZ 4.88 final $268.70 includes pinion depth shims Install kit $313.94 (includes all diff bearings, solid spacer with shims, axle seals, pinion seal, pinion nut, gear marker) ship $20.55 Total $603.19 Installation should be about half that, so roughly $900 - $1000 for everything replaced with all-new parts. I'm getting this installed Thursday the 15th. I'll post here and let you know it turns out. Tire height for stock size tires, 24.62". Gear calculator website - http://www.csgnetwork.com/multirpmcalc.html |
The Following 10 Users Say Thank You to KoolBRZ For This Useful Post: | 8686 (01-11-2015), avishenoy1 (03-29-2016), cameronjones239 (01-14-2015), drewbot (05-18-2015), flippy (01-12-2015), GT86_PRAGUE (01-12-2015), jcw99 (03-06-2016), kodyo (01-11-2015), nguyen_er (01-11-2015), trigger happy (02-24-2017) |
01-11-2015, 08:31 PM | #51 | |||
01-11-2015, 08:39 PM | #52 |
Drives: 2015 Raven FRS
I said it before and I'll say it again, couldn't be happier with my AT 4.88 gearing. It's perfect for the AT.
The Following User Says Thank You to Lunatic For This Useful Post: | Wayno (06-12-2016) |
01-11-2015, 08:46 PM | #53 | |
01-11-2015, 09:05 PM | #54 |
...and we can't reprogram the transmission's computer, so no changing that.
01-11-2015, 09:09 PM | #55 |
01-11-2015, 09:54 PM | #56 |
Drives: frs
Similar Threads | ||||
4.8 final drive | drift86 | Engine, Exhaust, Transmission | 29 | 11-28-2022 12:49 PM |
CUSCO 4.55 FINAL DRIVE installed. | Racecomp Engineering | Engine, Exhaust, Transmission | 489 | 06-17-2018 12:14 AM |
Final Drive Discussion | JimmyMac | Engine, Exhaust, Transmission | 118 | 08-07-2017 10:18 PM |
Final Drive Calculations | wootwoot | Engine, Exhaust, Transmission | 34 | 12-19-2014 04:06 AM |
Anyone w/ 3.727/3.909 Final Drive Post Boost? | Staf00 | Engine, Exhaust, Transmission | 12 | 05-02-2013 08:38 PM |
