05-10-2014, 03:53 AM | #43 |
The Following User Says Thank You to steve99 For This Useful Post: | Turdinator (05-10-2014) |
05-11-2014, 12:14 PM | #44 |
Sorry for the delay, car's been in the shop after being vandalized. Took some time to clean up the code and added OL scaling too:
https://github.com/scalablecory/scalemaf
2013 Whiteout 6AT FR-S | Perrin Inlet Tube + 2.75" CAI | OpenFlash Header | P&L Catback | 4.88 Final Drive | Dialed in OFT 2.0x Stage 2 E85 | 18x8 Enkei Raijin + 225/40 Michelin Pilot Super Sport | 17x7 Stock + 215/45 Michelin X-Ice Xi-2
05-11-2014, 10:50 PM | #45 | |
Drives: FR-S Whiteout
05-11-2014, 11:18 PM | #46 |
Drives: frs
fyi, updated proggie is now posted.
05-11-2014, 11:45 PM | #47 |
We have the compensation tables... it seems like we should be able to anti-compensate to get more accurate corrections.
05-12-2014, 12:23 AM | #48 |
05-12-2014, 12:40 AM | #49 |
I would think so, but the compensation tables are a bit strange. It is zeroed at 68 degrees and at 11.23 g/s. At temps of 104 or above the compensations below 11.23 g/s is negative, but anything over 11.23 g/s it goes to positive. The inverse is true for temps below 68 degrees. Not sure of the logic behind this. I'd like to learn more about why it is done this way before making any changes.
05-12-2014, 02:36 AM | #50 | |
Drives: UK GT86
As for zeroing out the IAT comp, just do it while doing the MAF and then put them back as stock would be my recommendation.
.: Stealth 86 :.
05-12-2014, 07:07 AM | #51 | |
I suspect the table is correcting for errors in the maf sensor behaviour due to temperature rarther than trying to compensate for air density changes, i suspect that calculation is done in ecu code somewhere using iat. Last edited by steve99; 05-12-2014 at 07:37 AM. |
05-12-2014, 08:25 AM | #53 |
Seņor Member
I noticed a while ago that the car felt the nicest to drive when the outside temps were around 20c. If we could tweak the table for more performance when cold and a tad safer when warm I'd be very happy.
1974 TA22 Celica
2013 86 GT |
05-12-2014, 04:50 PM | #54 |
If there is a temp compensation table for ignition advance, it can be done. The nicer feeling you're getting at 20c is probably just the increased power from cooler iat. Though, this engine seems more knock prone when temps are higher. The iat compensation for maf scale will only dictate how much or little fueling correction the computer will make to hit your target afr.
05-12-2014, 05:30 PM | #55 | |
Drives: UK GT86
There are 2 ignition timing vs IAT tables, one that changes timing depending on IAT and the other determines the % of that applied depending on RPM and load.
.: Stealth 86 :.
The Following User Says Thank You to Kodename47 For This Useful Post: | solidONE (05-12-2014) |
05-12-2014, 08:04 PM | #56 |
Really? So it's the load that gets adjusted... that would explain the relatively low % of adjustment in the table, I guess. I've decreased the entire IAT compensation table by .4%. I'll see if it has the desired result.
Similar Threads | ||||
AFR in Closed Loop | Toyota John | Software Tuning | 39 | 07-07-2019 08:26 AM |
BRZedit Fuel Trims, Closed to Open loop transiton | mad_sb | Engine, Exhaust, Transmission | 32 | 08-06-2015 03:14 AM |
Notes on injector / maf scalining using full time open loop | mad_sb | Software Tuning | 40 | 03-03-2014 05:49 PM |
Screencast: closed loop boost control with RaceRom | jamesm | Software Tuning | 2 | 02-10-2014 02:23 PM |
Screencast: experimenting with full-time closed loop fueling | jamesm | Software Tuning | 2 | 12-27-2013 10:19 AM |
