03-05-2014, 06:00 PM | #43 | |
Drives: 2013 White BRZ / 2014 White GT86
Sorry, I meant my Dealer who deals with all my aftermarket parts, not a Subaru dealership haha Got the set for about $1800. |
03-05-2014, 06:10 PM | #44 | |
03-05-2014, 06:14 PM | #45 | |
Lurker
If you're on stock height, you might be able to but under heavy suspension compression the tires will hit the body of the car which will mangle them and could also cause extensive body damage. If you're lowered already, I promise you that WILL happen. Basically the lower the number the further it sticks out. Why can't you just not run the wheels until you go widebody? lol. I promise you it'll look way worse than stock wheels so run those in the meantime.
The Following User Says Thank You to xDJ DUBx For This Useful Post: | JayDee (03-09-2014) |
03-05-2014, 11:15 PM | #46 | |
Drives: 2013 SWP BRZ
This reduces your offset by 15mm... 22-15 = +7 offset. Plus, what xDJ DUBx said about mangling your tires and fender Edit: but seriously, this discussion belongs in a different thread. |
The Following User Says Thank You to Assunta For This Useful Post: | JayDee (03-09-2014) |
03-11-2014, 10:00 PM | #47 |
Drives: 2014 Scion FR-S
Enkei RS055RR Square set-up opinions?
I'm planning on getting RS05RR from work for about 420$ each.
18x9.5 +42 all around. I was wondering why I can't run this stock, just curious. Sorry if its a dumb question. And yes, I'll be lowering my car before I put this on. I'll be using FA500. And I'm wondering what tires to get. Michelin Pilot Super Sport, Federal RS-R, or Dunlop Star Specs. I will be using the car as a DD, mostly commute and some occasional backroad runs. |
03-11-2014, 10:58 PM | #48 |
Drives: Firestorm FR-S
Inboard clearance. I'd imagine you will hit struts or springs with that high of an offset. I think they're +43 btw
03-12-2014, 12:11 AM | #49 | |
Drives: '24 GR86
With stock springs, you'll rub on the spring perch. With Coilovers, I THINK you'll be okay. You might need a 3mm spacer but I'm not sure. People are running 18x9.5 +40 on Coilovers with no issues for reference.
03-12-2014, 02:37 AM | #50 |
Drives: 2013 FR-S Whiteout MT
I want a set!!! Hook it up!!
When in doubt, throttle out!
03-12-2014, 03:49 PM | #51 |
The Following User Says Thank You to einrejosh For This Useful Post: | FRS Johnny (03-12-2014) |
03-12-2014, 03:52 PM | #52 |
How do you guy's feel about a Square set up of 18x9.5 all around?
I was talking to the SpeedElement people, and they told me its just user preference. I also decided not to go staggered because 8.5 was back ordered, and 8.5 had a flat face also. But yeah, whats your opinion on a squared set up of 18x9.5 5x100 +42 |
03-12-2014, 03:56 PM | #53 |
There are 18x9.5 and 18x10.5 in stock right now. Nobody has asked for them on our end...LOL.
03-12-2014, 04:05 PM | #54 |
Drives: 2003 Subaru Outback
They come in 18x10.5 with a 5x100 bolt pattern?
" I know a lot about cars, man. I can look at any car's headlights and tell you exactly which way it's coming. "
03-12-2014, 04:18 PM | #55 |
03-12-2014, 04:28 PM | #56 |
You got my so hyped for a second.
Similar Threads | ||||
Wheel Directory: Enkei Raijin 18x8.5 +45 / 18x9.5 +45 | GuerillaRacing | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 221 | 08-01-2019 10:30 AM |
Wheel Directory: Enkei RS05RR 18x8.5 +42 | dabocx | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 206 | 03-02-2018 05:23 AM |
Wheel Directory: Enkei RPF1 18x9.5 +38 | FRS8SIX | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 297 | 02-15-2018 03:50 PM |
Gauging interest Enkei RS05RR 18x9+40/18x8.5+50/18x8.5+42 | THMotorsports.com | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 0 | 09-19-2013 04:33 PM |
