03-02-2012, 01:45 PM | #43 |
Drives: Argento MT Scion FR-S
Boxers are so ugly. I'm going to miss the simplicity of the 4A-GE
03-02-2012, 01:54 PM | #44 |
here, there, any where
Drives: FR-S SOON!!!
With the headers so close to the oil pan aren't they worried about coking.... basicly boiling and charing the oil in the pan....which causes rings to fail, and carbon buildup through the motor.
03-02-2012, 02:00 PM | #45 | ||
Corner Junkie
Drives: 13 BRZ, 11 STI, 99 RS
I'm happy with a steel pan. Considering how often I see cast aluminum pans with stripped oil drain plugs, I'm happy with steel. I still think that can't hold very much oil. Not with proper heat shielding. The STI header is very close to the pan also and there aren't issues with cooking the oil. |
03-02-2012, 02:19 PM | #46 |
MODERATOR-SAMA
Drives: Swagtron Scooter
boxer engines do see higher oil temps than other engines but not significant enough to burn and boil oil in the pan. As long as the headers retain its heat shielding (ie paneling or texture materials) there shouldn't be any worry about the higher ambient heat effecting durability of the boxer engine.
03-02-2012, 02:21 PM | #47 |
Yes, Toyota fr-s
Drives: 1991 MR2 Turbo T-Top, Gen3 3SGTE
how much benefit would there be in replacing the two-piece drive shaft with a single-piece carbon fiber drive shaft?
03-02-2012, 02:28 PM | #48 | |
MODERATOR-SAMA
When we talk about wheel HP, power from the engine is lost through the drivetrain. In this case roughly 15% of power is lost through the drivetrain from the crank to the wheels. A lightweight and rigid drive-shaft would improve this. Giving you more play with the power your already making.
03-02-2012, 02:31 PM | #49 | |
03-02-2012, 02:33 PM | #50 | |
03-02-2012, 02:36 PM | #51 |
The end links look as long as my tC's end links.
03-02-2012, 02:59 PM | #52 |
Drives: Attitude
The benefits are more akin to a lightweight flywheel than anything else, if you have any experience with those. Essentially, as WoW stated, you don't make more power, rather you put what's already being made down to the pavement more efficiently. Throttle response and engine revolutions will be snappier.
03-02-2012, 03:02 PM | #53 | |
Opinionated
Drives: Something Red
There probably are some galley plugs that will be available to facilitate an OC install...but I don't see them in these pix
Most of the cars I drive have nets for windows.
03-02-2012, 03:05 PM | #54 | |
Corner Junkie
As for the driveshaft, it'll definitely be a benefit. I think the BRZ will really like lightened driveline parts; pulley, flywheel, driveshaft. |
03-02-2012, 03:22 PM | #55 | |
Corner Junkie
But on another thought... It looks like the oil is routed THROUGH the timing cover. That's really interesting. Belt replacement is going to be a PITA. |
03-02-2012, 03:27 PM | #56 |
Drives: '13 CBS BRZ
It all looks reassuringly similar to my WRX's (01 and 04). I feel comfortable already.
Does that look like a catalytic converter at the end of the exhaust headers? The WRX had a similar, pre-turbo cat, that many of us replaced with a straight pipe. (The WRX had 3 catalytic converters stock.) I wasn't considering any engine/exhaust mods till I saw that, provided it's what I think it is. As for questions about the spark plugs, yes my 2.0 WRX's had them on the side. If you have bigger hands like I do, it could be a bit painstaking to replace them yourself. But from pics I've seen there appears to be more space in the engine bay of the BRZ/FR-S. |
Similar Threads | ||||
Scion FR-S Concept First Official Pics/Videos + NYIAS Pics and Press Conference | Hachiroku | Scion FR-S / Toyota 86 GT86 General Forum | 856 | 06-14-2018 02:53 PM |
Subframe/Drivetrain Thoughts.... | TrackDog | Scion FR-S / Toyota 86 GT86 General Forum | 12 | 11-10-2011 10:53 PM |
Dyno testing and "drivetrain loss" | serialk11r | Other Vehicles & General Automotive Discussions | 5 | 11-03-2011 08:55 AM |
Drivetrain experts! Name this car! :) | aspera | Engine, Exhaust, Transmission | 200 | 08-15-2010 11:41 PM |
