Scion FR-S / Toyota 86 GT86 General Forum The place to start for the Scion FR-S / Toyota 86 | GT86 |
#43 |
Wannabe JDM Type S
Drives: 2013 BRZ Limited
The problem with flat 4s is that the timing component is down low. an FR car has it up high, and a FF has it usually aimed at a wheel well, so not all OHC belt driven engines have that issue.
My Wannabe JDM Type S build: http://www.ft86club.com/forums/showthread.php?t=24702
#44 | |
Drives: whiteout FRS
??? wut? ..
Dude they all wrap around the CRANK.. that's down low. .. there's no discernable difference in damage in a hard front end collision between a Inline engine and a boxer. Where did you hear of this? Here are pics of a I4 engine ![]() ![]() ![]() Here's a boxer engine ![]() Now that ^ is an EJ25 series engine.. our FA motors have timing chains and are much better protected/compact out front. The only difference between the scoobie engine in the pic and the 2.3L ford engine pics above it is that I didn't re-install the timing covers on my engine. Most front end impacts are rear-enders.. as in, the car doing the hitting takes it on the nose. Nose DOWN so the damage is usually above the crash support and shoving the radiator support and hood into the front of the engine. Which engine would be susceptible to damage up high? I understand the point you're trying to make man but its a weak one. OEM's dont care much about repair costs, they care about production costs. Quote:
dunno I've always had a love for engines in general.. all different engine types. Certain ones are just better at certain jobs and applications. |
#45 | |
Drives: Ultramarine FR-S 6MT
We benefit. A lower cg, any distance lower, results in a shorter moment arm from roll center to cg for the cars weight to pivot around when cornering hard. This means we can use softer springs than something like a mustang while achieving better body control per spring rate, and consequently lower rates for a nicer ride. It also allows more latitude in damper selection, which is why the 86 handles like a beast but doesn't ride like a torture device. Lower cg also leads to less dive in braking, and the lowered cornering forces and spring rates also allow for thinner suspension components and less body reinforcement. The downsides are a car where you need an engine crane to change plugs, and a skid plate to protect the BLOCK rather than the oil pan. For performance folks? Not too much to pay. But you won't see joe everybody lining up for an frs, because not everyone drives hard enough to care. Edit: that aside, saying the sound of an engine is a reason to avoid its use is ridiculous. And manufactures use inline 4 most often because it is proven technology with little r&d investment required, and because they are narrow. Narrow engine mounted transverse allows more longitudinal space for the engineers. More cabin leg room, more room for bumper crumple zones. And less effort achieving both. You get your 5 star safety rating, consumer reports tells everyone shaq could go planking in the font seat of the car, and a million people buy one because they want an appliance for moving the,selves and not a sports car. Sent from iPad via iTypo
The Following 3 Users Say Thank You to Ingen For This Useful Post: |
#46 | |
![]() Naw, many light aircraft use horizontally-opposed four cylinders manufactured by Lycoming or Continental. But yeah, any type of engine offers some plusses and minusses over any other type. That's what makes it fun! |
#47 | |
Driver of FR-S 1467
Drives: 2013 scion frs 001467
#48 |
Drives: E92
The GT3 is probably the best sounding 911 there is, the normal 911 just sound so... normal. As for 4 cylinders I think I prefer the high revving metallic mechanical induction noise of inline 4 VTEC from Honda.
2013 Scion FR-S 6AT
#49 | |
Drives: waiting on a 2021...
http://www.mighty6.com/
2016 4Runner Tail edition
2020 Camry 2020 RAV4 2013 Chevy 3500 4x4 Duramax 1999 Ford F250 Powerstroke, the tow rig 1969 Mustang, the fast car....(: |
The Following User Says Thank You to zooki For This Useful Post: | mrlewistan (05-20-2013) |
#50 |
Drives: Toyota Corolla SR5
its all preference personally I like a high pitch sound from a I6 or I4 with an open ITBs or sidedraft carbs, the boxer sound Tiff Needell calls it the drum roll its not bad. but for me the best sounding stock V6 is still the VQ35 from a nissan 350Z, sad the 370Z didnt have that same sound.
#51 |
Drives: RX8
As mentioned by others - the horizontal space the boxer engine takes up is quite a bit more than other engine configurations. It's a trade-off for the lower center of gravity.
One problem with the space it takes up is that you often get less room for the suspension components and end up having to settle with a simpler suspension design like macpherson strut (instead of a double-wishbone or multi-link). A lot of Porsches end up having struts in the rear because of the engine as well but lately their cars have actually grown in dimensions which allows them to work in a multi-link rear. As for the sound... it's kind of like the rotary. Some love it, some hate it. Personally I don't find the boxer engine sound too great =\ |
#52 | |
Drives: 450 awhp twin turbo vr4
[ame="http://www.youtube.com/watch?v=nkp3Tp5CZBI"]http://www.youtube.com/watch?v=nkp3Tp5CZBI[/ame] |
#53 |
What happens on a Boxer engine when there's too much Oil? | @Art_Mighty | Engine, Exhaust, Transmission | 29 | 06-15-2014 04:36 PM |
What makes the Boxer engine so special | ZakD | Scion FR-S / Toyota 86 GT86 General Forum | 111 | 11-02-2012 09:54 PM |
total noob with boxer engine | NickDude84 | Engine, Exhaust, Transmission | 35 | 04-27-2012 08:51 PM |
Next Gen Boxer Engine 4U-GSE | WingsofWar | Engine, Exhaust, Transmission | 33 | 12-10-2011 12:04 AM |
Could this be the base FT-86 boxer engine? | iff2mastamatt | Engine, Exhaust, Transmission | 2 | 02-10-2011 10:55 PM |
