12-12-2012, 04:27 PM | #43 | |
Drives: '12 C63 P31, '23 GRC
For the RP2s I used new rotors. Same squealing noise, no real difference.
Current: 2023 GRC Circuit Edition, 2012 C63 AMG P31
Past: (2) 2000 MR2 Spyder, 2017 GTI Sport, 2006 Porsche Cayman S, Supercharged 2013 BRZ-L, 2007 Honda S2000, 1992 Integra GS-R |
12-12-2012, 05:28 PM | #44 | |
12-12-2012, 06:52 PM | #45 | |
Drives: Nissan 350Z (sold) 13' Whiteout FRS
The Following User Says Thank You to Aznsky For This Useful Post: | amram (03-28-2014) |
12-13-2012, 08:03 AM | #46 |
Good to know for the future. However I don't leave my track pads on for daily driving so the noise isn't a big deal for me.
01-02-2013, 02:04 AM | #47 |
Drives: Some rust bucket
When replacing OEM pads with track pads, should one resurface the OEM rotors before installing the track pads?
01-02-2013, 02:55 AM | #48 | |
Drives: Nevermorange FRS
The long and short of it is... Just slap them on and go. You'll be fine.
SCCA T4 - FRS
01-02-2013, 04:18 PM | #49 |
01-02-2013, 04:39 PM | #50 |
Brake Pad Manufacturer (F/R): Hawk/OEM
Caliper (F/R): Essex AP Racing Sprint Kit(AP Racing CP8350)/OEM Compound (F/R): HPS/OEM Tires: 215/45/17 OEM Michelin Primacy Feedback: Characteristics seem very close to the OEM pads. Very low dust, great cold initial bite and zero squealing. Have not notice any wheel or paint damage due to dust. These pads will only be used for street use so it will be incomplete for track usa.. The pads do have a little movement but i'm guessing that is more to do with the calipers being designed for track use only. These are basically perfect for the Essex AP Racing kits when you want to run on the streets that won't see any hard usage. Will update later with extra info on pad lifespan and other info. |
01-11-2013, 01:43 AM | #51 |
Drives: SWP BRZ
Brake Pad Manufacturer (F/R): Porterfield/OEM
Caliper (F/R): OEM/OEM Rotor Size (F/R - IE OEM or specify): OEM/OEM Compound (F/R): R4S/OEM Tires: 245/40-17 RS3 Feedback: Feels similar to stock brakes but does noticeably dust more. I never took the stock brakes to the track, but running a 1:33 pace at SOW CW in 50F weather this setup held up well(haven't been on a track on 4 wheels in almost 10 years). Never noticed any fade at all, and braking was very consistent and easily modulated. On the street, I get no noise whatsoever and braking is effective even when fully cold. Although SOW CW isn't a brake intensive track IMO, I feel these would be a good alternative to stock pads for those looking for an occasional track day. Scores: Dusting (1=high-10=low): 3 Cold bite (1=low-10=high): 5 Hot bite (1=low-10=high): 6 Modulation (1=low-10=high): 6 Noise (1=extremely loud-10=quiet): 10 Pad Lifespan (1=short-10=long): est 10 track days Does the brake dust with this combination damage the wheels/paint if not cleaned immediately? (Y/N) Not that I know of. Brake ducts: (Y/N) No. Note: My ratings are based comparisons from vehicles with CCM setups that never shown fade, JFYI. Last edited by zkubidu; 01-11-2013 at 01:47 AM. Reason: Added a note. |
01-17-2013, 04:30 PM | #52 |
Drives: 2013 Black FR-S
Not many talking about the F/R: HP+/HPS combo.
Are Hawks not good? I will be on RCE yellows and am wondering if I should stagger or just get one pad for all 4 corners. |
01-17-2013, 04:40 PM | #53 |
Site Moderator
Drives: Stuff
HPS aren't a track pad, HP+ is a lighter duty track pad. Most of us use heavier duty (higher MOT) pads.
-Dave
Track cars: 2013 Scion FRS, 1998 Acura Integra Type-R, 1993 Honda Civic Hatchback DD: 2005 Acura TSX Tow: 2022 F-450 Toys: 2001 Chevrolet Corvette Z06, 1993 Toyota MR2 Turbo, 1994 Toyota MR2 Turbo, 1991 Mitsubishi Galant VR-4 Parts: 2015 Subaru BRZ Limited, 2005 Acura TSX Projects: 2013 Subaru BRZ Limited track car build FS: 2004 GMC Sierra 2500 LT CCSB 8.1/Allison with 99k miles |
01-18-2013, 11:58 AM | #54 | |
I want a pad that I can drive around on daily (noise and dust are an issue), that wont disintegrate at the track like the stockers. |
01-18-2013, 12:30 PM | #55 | |
Properly bedding *most* pads will reduce the noise to a minimum. |
01-21-2013, 10:15 AM | #56 |
Motor Sports slut
Drives: 13 FRS, 2011 f150eco boost,
Brake Pad Manufacturer (F/R): Stop Tech
Caliper (F/R): FACTORY FRONT AND REAR Compound (F/R): Street Performance Pad front and rear Tires: Michelin 245/35/18 on weds Feedback: I installed these pads along with some Motul 600 for my first track day. I noticed that pads worked much better than stock right off the bat. After three track days and 7500 miles the pads are done on the front. The rear how ever still look very good with at least 75% life left For the price you can beat it. I currently have a stillen big brake upgrade coming. I would like to point out that I notice a small crack appear on my rotor thats why I order the BBK. Other than that these brake felt great and never faded once. The Brake fluid has now changed colors(brown) too so I have a feeling it's been heated pretty high. Scores: Dusting (1=low-10=high): 7 Cold bite (1=low-10=high): 7 Hot bite (1=low-10=high): 7 Modulation (1=low-10=high): 7 Noise (1=quiet-10=extremely loud): 1 Pad Lifespan (1=short-10=long): (estimate/actual)front 4, rear 6 Does the brake dust with this combination damage the wheels/paint if not cleaned immediately? (Y/N) N |
The Following User Says Thank You to jdzumwalt For This Useful Post: | amram (03-28-2014) |
Similar Threads | ||||
Anime Discussion Thread | ERA | Off-Topic Lounge [WARNING: NO POLITICS] | 2701 | 02-14-2024 11:55 PM |
Gundam Universe - General All Discussion Thread | poormans_LFA | Off-Topic Lounge [WARNING: NO POLITICS] | 273 | 03-23-2014 11:45 PM |
S2000 vs BRZ at the track: track oriented discussion | CSG Mike | Tracking / Autocross / HPDE / Drifting | 33 | 01-13-2013 06:54 PM |
Track/Racing Discussion | Allch Chcar | Tracking / Autocross / HPDE / Drifting | 9 | 05-26-2012 04:39 PM |
Forza 3 vs. GT5 Discussion Thread | Snaps | Off-Topic Lounge [WARNING: NO POLITICS] | 386 | 03-06-2011 12:10 AM |
