Old 04-22-2013, 05:31 PM   #43
THEmailman
Drives: Raven 6MT
Originally Posted by CamryDS View Post
question about "air bubbles" Where exactly do we look for this? I understand the brakeline change as well as the bleeding part, but I'm not sure about looking for bubbles while bleeding the brake lines.
Figured I might attempt to do this on my own, once I get my car on a lift.
You'll see air bubbles coming out of the line you attach to the bleeder valve that drains into a bottle. They will start out bigger when you first open the valve to bleed but then they will get smaller. Brake fluid is relatively cheap and important to not have air in while I'm on the track so I let it bleed for 30 seconds to a minute with no air before I close the valve.
Goodridge SS brake lines//ProjectMu 999's//Motul DOT 5.1 brake fluid//GrimmSpeed master cylinder brace//Jackson Racing Oil Cooler//Whiteline camber bolts//Raceseng CamCas plates//Kosei K4R 17x8//BFGoodrich Rivals 225/45
THEmailman is offline   Reply With Quote
The Following 2 Users Say Thank You to THEmailman For This Useful Post:
amram (03-21-2014), BAOVAN (12-27-2016)
Old 04-22-2013, 06:28 PM   #44
CamryDS
Drives: 2003 Camry Blue | 2013 FR-S White
Sweet!!! thanks. I don't have to worry about the brake master cylinder then, just the brake lines! sweet deal!.
CamryDS is offline   Reply With Quote
Old 04-22-2013, 06:31 PM   #45
THEmailman
Drives: Raven 6MT
You will need to make sure there is ampke fluid left in the cylinder while you are bleeding, otherwise you will suck air in from there and will have to start the bleeding process all over.
The Following User Says Thank You to THEmailman For This Useful Post:
BAOVAN (12-27-2016)
Old 05-08-2013, 06:15 PM   #46
OrbitalEllipses
Drives: Attitude
Not sure if anyone else ran into this, but one of my brake lines just spun while I was trying to remove the flare nut. It appears as the though the stamped steel bracket with the retainer on the bottom that secures the soft brake line was incorrectly stamped or simply easily bent. I had to use a wrench on the flats of both brake lines in order to loosen and tighten the flare nut without spinning the line.
Old 07-19-2013, 01:12 AM   #47
stockysnail
Just the tip
stockysnail's Avatar
Drives: 2013 Lightning Red Subaru BRZ Mt Lt
Speed bleeders ordered with fluid and pads standing by until they arrive! I hope the new pads aren't too hard to get in. I don't have a pad removal tool thingy.
stockysnail is offline   Reply With Quote
Old 09-24-2013, 08:07 PM   #48
lazyluka
Drives: GT86
Originally Posted by F1point4 View Post
SB1010-SS for front and rear.
Fits like a charm.
I am 95% sure this same speed bleeder will work for the clutch too
Originally Posted by Amadeus View Post
There are two lengths offered - 31.35 and 34.44. Which length did you use or does it not matter?
Thank you for all of your great DIY write ups!
I figured it out - it's the longer threaded version with the part # you gave.
I looked at the part numbers closer and the short 31.35 is SB1010S-SS
My eyes skipped the extra "S" and I thought they both had the same #.
Just wondering how much does the speed bleeder stick out by and if the shorter version (31.35) would be better?
Also could someone link me to the part?
All I can find is this, not sure if it's the same though:
http://www.ebay.com/itm/Goodridge-Sp...ca7181&vxp=mtr
lazyluka is offline   Reply With Quote
Old 09-24-2013, 11:12 PM   #49
Amadeus
Amadeus's Avatar
Drives: White MT FR-S
http://www.speedbleeder.zoovy.com/pr...d-Bleeder.html Stainless Steel
I used the 34mm version to be sure it seated completely. Looking at the 34mm bleeder installed, it looks like there is 2-3mm of thread is exposed so if you went with the shorter version I don't know if it will seat completely.
It looks like the ebay version is not stainless and you'd want to verify the length.
Amadeus is offline   Reply With Quote
The Following 2 Users Say Thank You to Amadeus For This Useful Post:
amram (03-21-2014), lazyluka (09-25-2013)
Old 09-25-2013, 04:49 PM   #50
lazyluka
Drives: GT86
Thanks
Hmm, I like the idea of flush fitment. May wait a while and hopefully someone tries out the short version.
Old 10-15-2013, 08:43 PM   #51
ReThink
ReThink's Avatar
Drives: Sc10n FRS "DCLXIV"
Subbed. Thanks for the great write-up brotha!!
Sc10n FRS #0664
ReThink is offline   Reply With Quote
Old 11-01-2013, 10:40 AM   #52
ducky106
Drives: Scion FRS
Could anyone explain why stainless steel would be best? Would corrosion really be that much of an issue? I'm more thinking that at $35 for 5 standard bleeders versus $75 for 5 stainless steel it would be far better to go with the standard bleeders.
Also does anyone Know for sure they will fit the clutch.
ducky106 is offline   Reply With Quote
Old 11-03-2013, 09:41 PM   #53
Decay107
Turning is for Nerds
Decay107's Avatar
Drives: 35 characters is not enough
Not sure if SS is better for corrosion, but I purchased the standard SB1010 and had nothing but trouble. Going with the spec 71 in-lbf, 1/3 of the speedbleeders actually sealed (given my results I did not bother with the 4th at all). Basically they felt like they were sealed and there were no visible leaks, but if I would get in the car and really stand on the brakes a few times they would leak enough to pop off the included rubber cap and slightly wet the caliper. I increased the torque to 100 in-lbf (too scared to go higher) which still did not fix the issue. The stock bleeders are back on my car now.
I'll be doing some research into whether I want to double down and try the SS ones.
Decay107 is offline   Reply With Quote
Old 01-05-2014, 04:27 AM   #54
I<3Twisties
I<3Twisties's Avatar
Drives: SUBARWD
I installed a set of Goodridge lines and it did not come with new clips. But the stock clips no longer fit with the new lines. Any one experience this?
I<3Twisties is offline   Reply With Quote
Old 02-27-2014, 01:30 AM   #55
mfbmike
Drives: 2013 FRS, 2008 R32
What size hose? 1/4"?
mfbmike is offline   Reply With Quote
Old 02-28-2014, 09:45 AM   #56
smbstyle
smbstyle's Avatar
Drives: 2013 SWP BRZ
Great writeup!! Thanks!!
2013 SWP BRZ
Build Thread: http://www.ft86club.com/forums/showthread.php?t=38781
smbstyle is offline   Reply With Quote
brakes, fluid, motul, speed bleeders, stoptech
BC Racing Coilovers with Free Stainless Steel Brake Lines!!! Dustin@Dynosty Brakes, Suspension, Chassis 21 01-08-2013 10:34 AM
Dynosty Stainless Steel Brake Lines $99 Shipped Dustin@Dynosty Brakes, Suspension, Chassis 9 12-29-2012 09:56 AM
Stoptech stainless brake lines + Motul RBF600 fluid combo No Limit Motorsport Brakes, Suspension, Chassis 9 10-31-2012 07:36 PM
Stoptech Front Stainless Steel Brake Lines Pekingduck Brakes, Suspension, Chassis 1 10-21-2012 10:29 PM
Stainless steel brake lines taosracer Suspension | Chassis | Brakes -- Sponsored by 949 Racing 15 09-20-2012 04:09 AM
