Engine, Exhaust, Transmission Discuss the FR-S | 86 | BRZ engine, exhaust and drivetrain. |
08-31-2011, 04:19 PM | #43 |
Drives: Lexus IS-F
08-31-2011, 04:50 PM | #44 | |
Drives: 2010 Evo X MR-T
secondly, the boost is directly proportional to rpm on a roots. so at higher boost levels, you should be traveling faster. faster means more air over the heat exchanger of the water/air intercooler. thridly, the roots blowers have bypass valves. the engine may not even see boost at low load. the water pump is independent and can still circulate. so imo on a roots blower, water to air is perfect. compact and efficient. heat soak is overrated on a roots... |
08-31-2011, 05:01 PM | #45 |
Softparker
Drives: 2002 Mazda Miata
08-31-2011, 05:15 PM | #46 |
professional smartass
Drives: 16 speed mountain bike...
even though the embed doesn't seem to be working for me for some reason... That's one of my favorite youtube clips.
08-31-2011, 07:25 PM | #47 | |
hashiryu
Drives: Mk4 Supra
As din Said, it does have one. |
08-31-2011, 07:33 PM | #48 | |
4G63 & Rotary
If you're anything like me and you beat on it on your way to get some fast food and let it sit while you're eating, expect that water to be nice and toasty when you start her up again. If I really wanted to reduce intake temperatures I would just spray my A/A. |
08-31-2011, 07:42 PM | #49 | |
traffic jam over, road opens up. you let loose. the heat exchanger now is getting adequate air. efficiency goes way up. the only thing to worry about is how much heat the water soaked, and how fast you can get rid of it. with the independent pump circulating while you were standing still, just how much heat was soaked? i dunno if anybody has ever done an instrumented test, but from what i've read i dont hear too many people complaining about heat soak. and above all else, its not the end of the world. it only happens in certain conditions and it goes away. but something like turbo lag, now that is a problem that never goes away... |
08-31-2011, 07:45 PM | #50 | |
Kuruma Otaku
Because titanium. |
08-31-2011, 07:55 PM | #51 | |
it doesnt really matter anyways because if you go with a roots SC then you're almost stuck with water to air. if you rotrex or turbo, its basically standard to go air to air. you likely have no choice in the matter! |
08-31-2011, 08:53 PM | #52 | |
Kuruma Otaku
Because titanium. |
08-31-2011, 09:35 PM | #53 | |
Drives: '06 AM V8V Coupe
Now something I'd like to see is electric spool assist on a turbo...something like a starter motor producing like 4kW just to spin it up. We can get more complicated and do sequential twin (twin-scroll ideally) turbo with dual stage compression (with bypass valve for low rpm), and a valve to control exhaust gas flow to the second turbine, simpler than variable vane, very little lag |
09-01-2011, 02:22 AM | #54 | ||
its 1000% application specific. if i want response and no lag, no turbo will be better than a sc for that application. Quote:
09-01-2011, 06:33 AM | #55 |
Drives: Subaru Legacy
I always liked the Latham Supercharger...
Supost to be very effiecent, Low heat but very expensive to make. Axial brought the rights to building these http://www.axialflow.com/history.htm http://www.axialflow.com/products.htm
I'm sick of these mother f***ing earthquakes on these mother f***ing plains.
09-01-2011, 07:42 AM | #56 | |
Drives: Lexus IS-F
Good outside of the box thinking, but that design has essentially been around for centuries. It would be great to see this working in real life! |
Similar Threads | ||||
Roofline: Form over function. | ft86cbx | Scion FR-S / Toyota 86 GT86 General Forum | 15 | 04-24-2011 12:27 AM |
more pics form Geneva 2010 | Abflug | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 14 | 03-27-2010 08:03 PM |
