Old 03-27-2013, 04:05 PM   #43
cdo221
Drives: 2013 Ultramarine FR-S, 2015 RS 1.0
Originally Posted by oaroyale View Post
They are out now
Silver or black
+35 or +45
http://www.performanceplustire.com/b...milled-accents
any weight info?
cdo221 is offline   Reply With Quote
Old 03-27-2013, 05:59 PM   #44
MVJ1975
Automatic Hooligan
MVJ1975's Avatar
These are what I got.
They look just like 57Xtremes!
MVJ1975 is offline   Reply With Quote
Old 04-02-2013, 12:19 PM   #45
soulstice
Drives: SWP BRZ LTD
The bremmer one is a dead ringer. Thanks for the find. I'd be curious to see some specs but understand that it probably won't have the same build quality or lightness of the Gram Lights.
I think the 57xtremes are near perfection in terms of look on the FRS. I'd love to get the real deal of course but when you have a family, pretty wheels get low on the totem poll when they're almost $2k before tires.
soulstice is offline   Reply With Quote
Old 04-02-2013, 01:20 PM   #46
SkAsphalt
Ridge Racerrrrrrrrr
SkAsphalt's Avatar
Originally Posted by Brandon86 View Post
found out some info about these from Tire rack
The 18x8's have a 45mm offset and the 18x9's have a 42mm offset.
Old 04-03-2013, 10:20 PM   #47
OjiGeorge
OjiGeorge's Avatar
Drives: White 2013 FRS
Will be interesting to see if they are as aggressive looking when mounted up.
With those specs I think you could fit 18x9 all around with 245/35's without rubbing!
OjiGeorge is offline   Reply With Quote
The Following User Says Thank You to OjiGeorge For This Useful Post:
SkAsphalt (04-04-2013)
Old 04-11-2013, 04:21 PM   #48
OICU812
Just a dude
OICU812's Avatar
Drives: Scion FR-S 2013
Agree would like to see someone share some pics.
Old 05-14-2013, 08:53 PM   #49
yetiFR-S
Drives: 2013 SCION FRS
Try checking out konig torch. Hear they are pretty heavy though
yetiFR-S is offline   Reply With Quote
Old 05-15-2013, 10:31 AM   #50
SkAsphalt
Ridge Racerrrrrrrrr
SkAsphalt's Avatar
So far I have only found concave sizes in 19" rim options
Old 05-15-2013, 10:58 AM   #51
JoeBoxer
JoeBoxer's Avatar
Drives: Whiteout FR-S
I have some 18x9's in stock in 5x114.3 and they aren't heavy at all. Seems about the same as the 18x8.5 Enkei Raijin which is listed at 20.5, i'd say the Konig is no more than 21.5-22lbs.
Yep, they didn't account for 18's for the twins unless you want a 18x8 all around.
JoeBoxer is offline   Reply With Quote
The Following User Says Thank You to JoeBoxer For This Useful Post:
SkAsphalt (05-15-2013)
Old 05-29-2013, 11:03 AM   #52
joergasm
joergasm's Avatar
Drives: Subaru BRZ 2013 - SWP 6MT
Just ordered the bremmer kraft one's. I'll post pics when they arrive and when I get them on. I'll see if I can do a side by side with the bremmer krafts and rays.
joergasm is offline   Reply With Quote
The Following 4 Users Say Thank You to joergasm For This Useful Post:
camelflage (05-29-2013), djdnz (05-29-2013), OjiGeorge (05-29-2013), SkAsphalt (05-30-2013)
Old 05-29-2013, 11:34 AM   #53
camelflage
Drives: pinto power
yeah im interested how concave the 18x9 are, hard to find decent pics online other than the stock tirerack image.
camelflage is offline   Reply With Quote
Old 05-29-2013, 11:42 AM   #54
camelflage
Drives: pinto power
double post...
but here is the best picture i found so far of the 18x9 +42 (which tirerack lists as 22 lbs, so 2 lbs more than stock.
from NASIOC: http://forums.nasioc.com/forums/show...postcount=2264
The Following User Says Thank You to camelflage For This Useful Post:
Old 05-29-2013, 01:30 PM   #55
soulstice
Drives: SWP BRZ LTD
Does anyone know if the Bremmer 18x9 will fit on a BRZ up front. I'd like to do a square 18x9 all around.
Old 05-29-2013, 02:10 PM   #56
djdnz
1337
Drives: 2013 BRZ WRB S/C
It will fit, but it might take coilovers to do so. Not sure if the stock spring perch will clear or not.
We know the real thing fits, which is a 18x9.5 +40, these are 18x9+42. They will be approx 8mm more sucked in than the real thing on the outside. Not sure how flush they will be, depending on the camber you run they might be tucked a bit. On the inside of the wheel you are looking at 4mm more clearance than the real thing.
For reference, the real thing - Jive Turkey's car (hope he doesn't get offended by turning up in a replica thread lol)
This spec requires coilovers.
And here is what you're looking at with the Bremmers (green), compared to the real thing (Orange):
@joergasm I'm really interested to see them mounted. It's between the Bremmer's and the Raijin's for me. Tough decision. What size tires did you go with? I'd likely end up with 255's I think.
djdnz is offline   Reply With Quote
The Following User Says Thank You to djdnz For This Useful Post:
joergasm (05-29-2013)
Wheel Directory: Gram Lights 57Xtreme 19x8.5 +45 / 19x9.5 +45 Enjuku Racing Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 63 05-03-2013 02:38 AM
Wheel Directory: Gram Lights 57Xtreme 18x7.5 +40 quik1987 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 09-05-2012 12:44 PM
Rays Gram Lights 57Xtreme 19 x 9.5rear quik1987 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 16 08-15-2012 11:50 AM
Gram Lights 57Xtreme Wheels vividracing Wheels and Tires 32 07-31-2012 12:38 PM
Ray's Gram Light 57Xtreme Wheels - 19x8.5 / 19x9.5 (Set of 4) * IN STOCK * Enjuku Racing Wheels and Tires 1 07-20-2012 08:15 AM
