Tracking / Autocross / HPDE / Drifting What these cars were built for! |
01-20-2023, 11:18 AM | #43 | |
Drives: '23 BRZ
The 225 results appear to overachieve relative to 215 and 245 rather than just interpolating between them. Could be due to "better" gearing for this particular course? Seeing results for 235/45 and 235/40 could help clear that issue up. |
The Following User Says Thank You to ZDan For This Useful Post: | RT-BRZ (01-20-2023) |
01-20-2023, 01:03 PM | #44 |
Drives: 2022 BRZ
The TR test are better than nothing but still need to be taken with a grain of salt.
They do not adjust tire pressures for one. They run what the door says for psi. once that is changed and FSB is added to the mix like street class autox plus bump stop tuning and shocks, these results get thrown on their head. Don't get me wrong, this is all cool data but I would be careful pulling hard absolutes from it. |
The Following 2 Users Say Thank You to MacSpeed For This Useful Post: | strat61caster (01-20-2023), treedodger (01-21-2023) |
01-22-2023, 03:40 PM | #45 | |
Sent from my Pixel 6 using Tapatalk
2013 Series 10 FRS #553
02-21-2023, 12:23 PM | #46 | |
Drives: 1999 Miata
As with anything else, test as much as you can. Keep in mind that for some of us, $/run or lap weighs heavily on the tire and width choice. A friend of mine once said that the RA-1's suck compared to a Hoosier, but they suck for a LONG time.
DJ
1999 Miata VVT swap "Maggie" 2013 BRZ "Nancy-Drew BRZ" |
The Following 4 Users Say Thank You to MX-5RACER For This Useful Post: |
03-01-2023, 09:15 AM | #47 |
Drives: 13 Viper; 14 BRZ; 90 Miata; 18 AMG
edit: doh, wrong thread!
2014 BRZ: Full track car. Gutted, caged, coilovers, AP enduro, OMP, bolt ons, aero, etc,
2013 Viper GTS : Tractive Coilovers, ACR sway bars, aero, carbon, exhaust, etc. 1992 NA Spec Miata: 1.6 + 1999 NB Spec Miata: 1.8 w/ all the goodies. 2018 GLE 63 AMG: +800hp whistling AWD TT V8 grocery getter 2016 GX460: IDK. Too reliable to sell. Too boring to use. |
04-06-2023, 10:53 AM | #48 |
Track Day Junkie
Drives: 2022 BRZ Limited
255's, and when?
What I'm curious about, and don't see much about, is what horsepower does to our tire selection. I can only assume that people are stock unless they say otherwise.
Then you start gutting, lowering, adding aero. All that is not clear unless stated, which it seldom is, or perhaps you go digging for the poster's info. I've seen people talk about running 255's on road courses. I think some (most?) have turbo's. I get 230 HP from my 2022 BRZ. I've no rear interior, but I have a wing and splitter. I'd guess I'm under 2,800 with light 17" wheels, rotors, coilovers, lighter exhaust. I'm very happy with the performance of my 245 F1 Supercar's. Good lap times. So, could there be an advantage for me on tighter, shorter courses with 255's? If it's only 50-75°F will there be an issue getting them up to temp? Goodyear doesn't make an F1 Supercar tire in 255 though there are tires like Falken's and Kumho's, but is their lesser traction performance outweighed by their larger surface area? I'm not going to go to Hoosiers or similar that cost a lot for the laps.
Try this Jalapeno son! It ain't hot...
Scargo on IWSTI (Journal of STI track car) Scargod on NASIOC. Track Day Videos |
04-09-2023, 03:17 PM | #49 |
Drives: None
I have never had issues getting a 245 on a 10 or 255 on a 9, 9.5, or 10 to temp even in a car that weighed 2400lb with me in it and made 220whp (and I still don't with my current car at 2850 min / 205 avg whp). I'm more worried about the drop-off from heat after 1-3 laps depending on tire.
Assuming you're talking SC3R there isn't much faster other than going Hoosier. GRM did tests a while ago with a more narrow A052 vs another couple wider super 200tw tires, if you dig around though.
01-10-2024, 02:24 PM | #50 |
Drives: 2022 GR86
I love data.
Follow the build thread for my GR86!
The Following 2 Users Say Thank You to timurrrr For This Useful Post: | jflogerzi (01-13-2024), RedReplicant (01-10-2024) |
01-10-2024, 02:40 PM | #51 |
Drives: None
Andy also wrote another semi related article a few days ago too
https://grassrootsmotorsports.com/ar...ize-comparison
01-11-2024, 09:22 AM | #52 | |
If you can't get enough negative camber to get the tire flat, it really doesn't mattter how much tire is not touching the ground (or doesn't have significant load). So yeah, when you're only riding on the outside inch of tire around turns because these tires are so grippy these days, regardless of the tire width, the tire that is 10% lighter will be faster.
The Following User Says Thank You to GrandSport For This Useful Post: | Scargod (01-20-2024) |
01-11-2024, 12:13 PM | #53 | |
Drives: '23 BRZ
Similar Threads | ||||
New Hawk HP+ Compound | RayRay88 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 25 | 07-08-2019 10:04 AM |
Compound boost. | Jaden | Forced Induction | 218 | 09-26-2016 09:36 PM |
New Hawk HP + compound | Hyper4mance2k | Tracking / Autocross / HPDE / Drifting | 24 | 11-11-2014 11:05 AM |
help im really dumb i think!!! compound issue.. | nickmerronesucks | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 11 | 05-02-2014 03:53 PM |
new R compound from Maxxis | Matt Andrews | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 4 | 06-08-2012 02:27 PM |
