Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) Everything related to the mechanical maintenance of the FR-S and BRZ |
04-06-2022, 12:25 PM | #43 | |
Drives: 2018 Subaru BRZ
Upon further research, because the concept of 10W-50 was so new to me, there have been other recorded Forum cases of people using it, the more you know I guess. So I would agree is not actually experimenting. Though the option of an oil cooler might still make a little sense if not switching oils between track sessions, but that would be the prerogative of the owner. What I meant with checking other fluids, is the fact that OP made it sound like he lives on the edge and so does the car. If you're constantly hammering the car you should probably shorten, or keep in consideration, the time between other fluids such as brake and LSD or even transmission. But I hope OP does the common recommended items for when you start tracking the vehicle. |
The Following User Says Thank You to spcmafia For This Useful Post: | ZDan (04-06-2022) |
04-06-2022, 02:47 PM | #44 | ||
You use the oil the engine was designed for. Get a baseline, and go from there to optimize for your specific use and conditions. Even in the same region, oil that works well for me' my commute and event types, is very likely not going to be the most ideal brand/weight for the next guy. There's no one right answer here. Quote:
I agree, I see far more oil coolers installed on cars 'because racecar', few know what their oil temps are, and even fewer knew what they even were before installing it. If you really want to be 'because racecar', you only add complexity (DNF potential), weight, and costs, when it's necessary AND going to payback in measured performance and/or reliability improvements. |
The Following 4 Users Say Thank You to KillerBMotorsport For This Useful Post: |
04-06-2022, 03:51 PM | #45 | ||
Drives: '23 BRZ
At 220F, 0w20 is ~7.5 cSt. At 275F, it's below 5 cSt. Running a 40-weight oil you'll be back at close to 7.5 cSt at 275F. I've been running 5w30 in track season, may move to 5w40 this year... If running for decent amount of time at higher temps, probably a good idea to run something thicker than 0w20... But 10w50 may be overkill! Quote:
The Following 2 Users Say Thank You to ZDan For This Useful Post: | Capt Spaulding (04-07-2022), Tokay444 (04-06-2022) |
04-06-2022, 05:49 PM | #46 |
Anti stance.
What do they spec in this exact same engine in the cup car?
Holy FUCK! It’s 5w50! https://www.blauparts.com/blog/toyot...g-ravenol.html Last edited by Tokay444; 04-06-2022 at 06:31 PM. |
04-06-2022, 06:12 PM | #47 | |
Drives: '23 BRZ
However if you are running limited sessions on track in your street car and don't want to change oil before and after *every* track event, maybe 5w30 or 5w40 is a better choice... |
04-06-2022, 06:19 PM | #48 |
Anti stance.
It isn’t a surprise to me.
The Following User Says Thank You to Tokay444 For This Useful Post: | ZDan (04-06-2022) |
04-06-2022, 07:21 PM | #49 |
Drives: 2020 BRZ Final Edition, 1999 MX5 NB
04-06-2022, 08:54 PM | #50 | |
LMGTFY
Drives: 13 FRS, 91 Miata
Who made it? The only other place I can find it is subaruoutback.org in a single post. No reference to who came up with these numbers. I also can find no other info online backing any of these numbers up. Or for that matter, how thick any grade of oil should be above operating temps, let alone 270F. Until then I am of the thought, run what the manual says until an oil analysis says otherwise. |
The Following User Says Thank You to x808drifter For This Useful Post: | Tcoat (04-07-2022) |
04-07-2022, 12:01 AM | #51 | ||
Drives: '23 BRZ
What the manual specifies doesn't really apply if you're tracking at 270F+ oil temps. But some manuals still encourage use of thicker oils at higher operating temps... |
04-07-2022, 12:40 AM | #52 | |
Drives: 10 RX-8 Spt, 20 BRZ Ltd, 21 Rubicon
The Following User Says Thank You to DrinkenBRZ For This Useful Post: | Tokay444 (04-07-2022) |
04-07-2022, 05:48 AM | #53 | |
LMGTFY
I will take a look at the Widman site after I get Home from work and Update this post then. |
04-07-2022, 07:01 AM | #54 | |
Drives: '23 BRZ
FTR I don't think I've said "you NEED to run XwXX!". I've said that if you operate for extended periods at 270F+ as I do, it's probably good idea to run something thicker than 20-weight. I don't think this is a radical idea... The viscosity of a 20-weight oil at 270F is going to be a LOT less than it is at normal operating temps of 190-220F. Running 30- or 40-weight at 270F is going to get you closer to what the viscosity of the factory-fill 0w20 is at normal street oil temps. Personally, I've been running 5w30 during track season, may go to 0w40 or 5w40 this year. Feel free to run 0w20 at 270F while waiting for "actual proof" though! |
04-07-2022, 07:14 AM | #55 | |||
This is just another tool for thermal management. We have them in various places in the engine bay as well They came from McMaster-Carr, but you can probably find them in other places too. Quote:
I see people in here searching for the couple examples that fit the narrative they want to believe, but that's just not how science works. Blackstone Labs already has over 80 results for the BRZ FA24 and thousands of FA20 results from Gen 1. If you really want to know what oil to run. Talk to these people. Don't base your choice on 'because racecar'. Quote:
I see that graph and it shows STARK difference between the weights. Especially when targeting the ideal 210°-240° range. The 50 weight oil is going to be similar to COLD 20 weight. Which of course, explains why the pressure goes up; viscosity is a measure of resistance of a fluid to flow. You want to know how much less oil you're putting on the bearing when your flow resistance doubles? Do the math. It doesn't matter how hard you push on the oil (pressure), but it definitely does matter if you're getting enough on the load surfaces. I'm going to be doing a bunch of oiling system testing as we do more testing and development work with our mule. I hadn't planned on doing anything with changing viscosities, because it's such a pain to do. With the EJ engines (or any engine for that matter), you change grades and see measurable differences in power, pressure, and flow. |
The Following User Says Thank You to KillerBMotorsport For This Useful Post: | CSG Mike (04-07-2022) |
04-07-2022, 07:16 AM | #56 |
Tags |
oil, oil change, track build |
