09-10-2019, 07:00 PM | #43 |
45K miles on e85
Well, I have an issue from e85. It's a simple fix, but something did come up from using it. My downpipe gasket and manifold gaskets were compromised. I replaced, but will happen again? I run 60%+ E85. WIll reduce to 40-50% here forth.
END OF LINE |
09-11-2019, 12:16 PM | #44 | |
Drives: 2017 BRZ w/PP
what does this have to do with running e85? ethanol will never touch this. also got my last blackstone with 5k + autocrosses and it was super clean. |
The Following 2 Users Say Thank You to Breadman For This Useful Post: | Clutch Dog (09-11-2019), DaBoBo21 (09-11-2019) |
09-11-2019, 07:24 PM | #45 |
Drives: 2017 BRZ PP , 2005 Saab 97X
The only downside I heard of was possibly needing more frequent oil changes
but chances are most you hot shoes are already swapping oil every 10k, or once every three months or if you get bored. I did hear about one of our drivers blowing out his cat but im also positive that normal 91 oct or e85 woulda done that...(dude races in the 86 cup and his high flow catted header became a hi flow uncatted) |
09-11-2019, 10:21 PM | #46 |
Drives: 2013 frs red
I try to do my oil changes every 4k or so. Been on e85 tune for about 2 years give or take.
The Following 2 Users Say Thank You to Lantanafrs2 For This Useful Post: | Clutch Dog (09-11-2019), lextrueno (09-15-2019) |
09-12-2019, 08:32 PM | #48 | |
... I found a Lucas product for e85 stablization. Recommended for every fill-up (i'm going every other) and safe for all mixtures. Green bottle #10576, I believe. I don't have it with me, it's in the whip. Anyhow, looking at thicker (Grimspeed) gaskets made of steal to arrive. |
09-13-2019, 07:11 AM | #49 | |
i toss in a squirt of injector cleaner every tank since i fill up almost weekly |
09-13-2019, 07:16 AM | #50 |
Weight Weenie
Drives: 15 FR-S
What about 100% Ethanol. Does anyone have experience with this?
09-15-2019, 04:22 AM | #51 |
Drives: brz 2017 hksv2
doesnt exist, maximum is around 96% and I think is difficult to find?
and you need lot of boost and/or compression to take advantages of that |
09-15-2019, 07:38 AM | #52 |
09-15-2019, 08:18 AM | #53 |
Weight Weenie
Drives: 15 FR-S
Sorry to hear that. I would not recommend pure ethanol...
I would imagine ethanol for an engine would still have additives for lubrications and whatnot. I have a feeling this one will remain an unknown. You do see cars running on pure alcohol BUT I don’t know if it could be done long term without harming the engine. What’s the reason for the 15% gasoline? |
The Following User Says Thank You to new2subaru For This Useful Post: | Lantanafrs2 (09-15-2019) |
09-15-2019, 10:55 AM | #54 |
TRACKBREAD
09-15-2019, 12:59 PM | #55 | |
Weight Weenie
Drives: 15 FR-S
Enlightened me on the additives for an engine running on pure Ethanol. I’m assuming there’s additives anyways... |
09-15-2019, 10:18 PM | #56 |
Drives: 2013 Firestorm Frs
E85 is made unfit to drink because of the gasoline as the additive.
SO why not go with E97 or something equivalent that is still unsafe to drink and higher percentage? Because gasoline stabilizes ethanol, espcially in the cold. Gasoline can vaporize at very low temperatures which is why it is added. When there is 15% or more gasoline, there is enough vapors to spark at low temps.
Similar Threads | ||||
Long term E85 use | redrocket89 | Engine, Exhaust, Transmission | 92 | 06-28-2021 05:40 AM |
Long-term adverse effects of Whiteline chassis inserts? | ApexEight | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 18 | 09-07-2017 07:13 AM |
long term and short term | brichard0625 | Engine, Exhaust, Transmission | 7 | 08-26-2013 08:56 AM |
Fuel Trims - Long term and short term | victorb | Engine, Exhaust, Transmission | 6 | 03-27-2013 02:18 PM |
Short Term and Long Term Fuel Trims | naikaidriver | Engine, Exhaust, Transmission | 3 | 03-18-2013 09:55 PM |
