07-08-2015, 09:07 AM | #43 | |
Drives: Toyota GT86
A lot of guys run DTC-60 or equivalent on stock brakes because the stock rotors do not have sufficient thermal capacity, and therefore overheat the pads -- so you need to run a higher temp pad on stock rotors. With our 330mm rotors, that is not necessary unless you are doing more sustained endurance efforts on race rubber. Lets put it this way, we ran BP30s on the Element Time Attack FRS, we Phil was really impressed with the shear braking power of this setup. And keep in mind, Phil's car is just a bit on the extreme side:-) That said, BP30's run friction coefficient of about 0.62, and DTC60's are about 0.75 --- we had DTC60's with us to try, but it was pointless, we did not need that kind of friction, and using the DTC60s would reduce our pedal pressure too much. BP20's will feel like they lack bite until they get up to temp, otherwise they feel great. I would try BP20's first, I think you will be happy. The next incremental step up if you feel any fade is "Compound J," followed by BP30's. Rafi |
07-08-2015, 10:12 AM | #44 |
Replacement pads for the bp20 are only $86ish? Was just looking thru your website.
07-08-2015, 10:20 AM | #45 |
Has anyone tried fitting these under the stock wheels?
07-08-2015, 11:11 AM | #46 | |
Drives: 2015 ISM BRZ Premium
One of the earlier posts in this thread:
07-08-2015, 11:42 AM | #47 | |
Drives: Toyota GT86
That's one of the nice things with these pads. They are a very common pad configuration that fits many different Wilwood, AP, and other manufacturer's calipers. Don't be fooled by the relatively low price, these pads are really good. Rafi |
The Following User Says Thank You to Rafi@RR-racing For This Useful Post: | DAEMANO (07-09-2015) |
07-09-2015, 08:41 PM | #48 |
Drives: 86 GTS
@Rafi@RR-racing - You have email from me regarding my delivery.
07-10-2015, 01:20 PM | #49 |
Besides the caliper clearance/pad thickness, are there any differences the stage 1 vs stage 2? One caliper stronger than the other,one better at heat disipation, ect.
The Following 2 Users Say Thank You to ka-t_240 For This Useful Post: | endless_pain (07-10-2015), Pat (07-10-2015) |
07-10-2015, 06:09 PM | #50 | |
Drives: Toyota GT86
Both Stage I and II calipers use the same forged construction, and are the same except for: (1) Stage II calipers accommodate thicker pads. Stage II pads are 0.8" thick, and Stage I pads are 0.65" thick. Thicker pads reduce heat transfer and last longer. (2) Stage I calipers are powder coated red or black, Stage II are black anodized. Powder coating looks great, but is not as durable as anodizing for those who track their cars. (3) Stage I calipers require less wheel backspacing than Stage II calipers. -Rafi |
The Following User Says Thank You to Rafi@RR-racing For This Useful Post: | DAEMANO (07-10-2015) |
07-10-2015, 09:29 PM | #51 | |
Thank you, that was my assumptions in the differences between each. I was liking the thicker pads, as that is thicker than most pads for the OEM calipers. As someone who has had the joy of experiencing boiled fluid, I am all about preventing that. I would assume the extra clearance between the stage 1 and 2 would be thinning up the caliper in the center, thus the thinner pads and extra wheel clearance. The narrow version should see any negative impacts in the ability to handle stress or heat from being "narrow", should it? |
07-15-2015, 02:58 PM | #52 |
Drives: 2013 SCION FRS
We have special pricing on these, pm us for more information!
-Josh |
07-15-2015, 03:15 PM | #53 |
Time Traveller
07-15-2015, 08:20 PM | #54 | |
Drives: Toyota GT86
The narrow version was mainly designed for added wheel clearance, but I will tell you that it will easily handle ANY street application and MOST track applications. But if you happen to have wheels with sufficient backspacing, I recommend the wider Stage II/IV calipers, it will be that much better, not to mention that the pads will last much longer. Rafi |
07-17-2015, 01:45 PM | #55 |
07-18-2015, 06:48 AM | #56 |
Drives: 86 GTS
Rechecked my templates today for my Stage I kit - both my RPF-1 +35 and Desmond Regamaster 17x8 +35 will clear.
Tags |
big brake kit, competition, track |
Similar Threads | ||||
AP Racing brake systems in development | track_warrior | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 872 | 09-17-2017 07:43 PM |
Megan Racing Coilovers - Street / Track / EZ STREET - Starting at $699 Shipped | GuerillaRacing | Brakes, Suspension, Chassis | 149 | 05-12-2015 05:53 PM |
AP Racing Factory Big Brake Kit, NOT Competition | Lonergt | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 0 | 08-25-2013 04:51 PM |
Official street racing thread. All street racing goes here! | bkblitzed | Off-Topic Lounge [WARNING: NO POLITICS] | 8 | 07-19-2013 11:31 AM |
Essex/AP Racing Competition Brake System in Development | JRitt | Brakes, Suspension, Chassis | 1 | 06-14-2012 01:32 PM |
