Scion FR-S / Toyota 86 GT86 General Forum The place to start for the Scion FR-S / Toyota 86 | GT86 |
03-21-2015, 11:36 PM | #43 |
Drives: scion frs, 2012 Mustang
Aside from lots of practice.. check out a local sports car club?
Maybe get someone to ride with you, try your car, and see! My car.. I have no trouble with. I'm not ready to mod it until I see a problem. Could be variations car to car? Sports car club. |
03-22-2015, 12:21 AM | #44 |
Drives: '14 BRZ
This reminds of me of reading a bit up from Ranger over in the Corvette World. He's set most records for stock Corvettes and has a post about proper hand placement for shifting and how to practice it. Similar to Tcoat's recommendation's above.
03-22-2015, 12:39 AM | #45 |
Drives: 2015 FR-S Firestorm MT
The Following 3 Users Say Thank You to tekFRS234 For This Useful Post: |
03-22-2015, 01:10 AM | #46 |
chicken tonight
My mom taught me how to fly. I was doing loops & spins by the time I was 7. Total seat-of-the-pants deadstick landings in a crosswind were second nature but I never got my license.
03-22-2015, 01:41 AM | #47 | |
chicken tonight
03-22-2015, 02:13 AM | #48 |
Drives: 18 BRZ tS, 27 GRMN 86
Try shifting at 4000rpm or above, it should help.
The Following User Says Thank You to botbs For This Useful Post: | Koa (03-22-2015) |
03-22-2015, 02:27 AM | #49 | ||
(Sorry too many beers and getting crotchety)
The Following 2 Users Say Thank You to Tcoat For This Useful Post: | Koa (03-22-2015), Ultramaroon (03-22-2015) |
03-22-2015, 09:24 AM | #50 | |
Drives: 2014 BRZ Limited
[ame="https://www.youtube.com/watch?v=vOo3TLgL0kM"]Manual Transmission Operation - YouTube[/ame] Getting? |
The Following 4 Users Say Thank You to extrashaky For This Useful Post: |
03-22-2015, 10:30 AM | #51 |
Drives: 17 Alfa Romeo 4C
I believe it's been covered, but what about skip shifting and engine braking? Common sense would dictate that both are not ideal, but I tend to do both alot. Any comments?
03-22-2015, 10:54 AM | #52 | |
Drives: '11 Cayman , '14 Camry, '11 Tacoma
"Engine braking" is actually recommended as a safety practice. Some states actually have laws requiring you to use engine braking under certain circumstances. And the load/stresses on the engine and drivetrain under de-cel are far less than under accel conditions. BTW, anytime you lift, you are engine braking (unless you de-clutch/shift to neutral). Skip shifting? For many years, almost all MTs had 3 speeds (many early ATs were only 2 speeds. Just because there are 6 speeds available, you certainly don't need to use all 6 all the time. Last edited by billwot; 03-22-2015 at 11:13 AM. |
The Following 4 Users Say Thank You to billwot For This Useful Post: |
03-22-2015, 10:56 AM | #53 |
Sarcastic Bastard
Drives: '13 DGM BRZ, '13 Mini, 1999 Blazer
Change the Fluid. Sorry I did not have time to search for what kind for you.
03-22-2015, 11:42 AM | #54 | |
Drives: FRS-RS1, Triumph Speed Triple, Lola
With the advent of modern brakes, engine braking is no longer needed, or desired (it upsets the brake balance). Unless you're using it to set up a car at corner entry or to change it's attitude mid corner (this is another subject). The purpose of down shifting is to be in the correct gear to accelerate out of the corner. If you are trail braking deep into the corner you may be carrrying too much speed into the corner to be in the correct gear at or before turn in. You don't need to be be in the correct gear before the turn but rather before you accelerate. Down shifting at max Gs while braking without upsetting the car's balance is where the "Art" of driving come in. Engine braking sounds cool but it no longer needed. |
The Following 2 Users Say Thank You to Caspeed For This Useful Post: | Braces (03-22-2015), gramicci101 (03-22-2015) |
03-22-2015, 12:08 PM | #55 | |
When driving Formula cars I would often skip shift on down shifts. The reason being that the cars shed speed so fast under maximum braking that I wouldn't have enough time to work my way down thu the gears. Beacuse I left foot brake I would downshift without usiing the clutch. If you didn't match the RPM perfectly you'd spin out. Do not try this in our cars the shifting system is not the same. The Hewland gear boxes are non synchro using dog rings. On street cars it can also be handy skipping on down shifts but again you need to get the RPM matched properly to avoid upsetting the balance. |
The Following 2 Users Say Thank You to Caspeed For This Useful Post: | Braces (03-22-2015), Ultramaroon (03-22-2015) |
03-22-2015, 12:15 PM | #56 |
Off Topic
The Following User Says Thank You to gramicci101 For This Useful Post: | Ultramaroon (03-22-2015) |
Similar Threads | ||||
FRS/BRZ Questions, I am new. | Reason22 | FR-S / BRZ vs.... | 14 | 08-14-2014 11:42 AM |
Wax Sealant Pad Questions / Care Questions | l0aded | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 3 | 03-25-2014 11:19 AM |
HID / LED questions | RealShkillz | Cosmetic Modification (Interior/Exterior/Lighting) | 7 | 06-01-2013 05:15 AM |
Questions about a MT | official_george | Scion FR-S / Toyota 86 GT86 General Forum | 18 | 05-20-2013 10:36 PM |
E85 questions | Grishbok | Engine, Exhaust, Transmission | 17 | 08-08-2012 10:49 PM |
