Issues | Warranty | Recalls / TSB Problems, issues, recalls, TSBs |
View Poll Results: Do you have chirping (cricket) noise during idle once the car is warmed up? | |||
Yes (Please only vote after you have 300 miles or more on the odometer) | 3,100 | 85.21% | |
No (Please only vote after you have 300 miles or more on the odometer) | 538 | 14.79% | |
Voters: 3638. You may not vote on this poll |
07-27-2012, 08:37 PM | #519 | |
Drives: Attitude
"ticking" can be two things: injectors or the valvetrain. Both considered normal noise a Subaru flat engine; they're known for being kinda noisy. |
The Following User Says Thank You to OrbitalEllipses For This Useful Post: | Raven86 (07-27-2012) |
07-27-2012, 09:29 PM | #520 | |
Drives: Skoda Yeti DSG diesel 4x4
Sounds like an old clonker that's been around the clock and needs new drive belts or a new motor. That's a real shame with your new pride and joy when the engine is its heart and should sound the part, smooth and quiet under the bonnet. |
07-27-2012, 09:33 PM | #521 | |
07-27-2012, 09:48 PM | #522 | |
No ethanol quiet, E10 or E15 noisy. So the HPFP isn't happy with ethanol going through it and when it gets hot there's not enough lubrication and it starts to complain. The noise is a result of high friction causing at least one part in the pump to run under extreme conditions it wasn't designed for. How long it can endure those conditions is currently unknown. My educated opinion but I doubt it's far off the mark. |
The Following User Says Thank You to sierra For This Useful Post: | blu_ (07-27-2012) |
07-27-2012, 09:56 PM | #523 |
Drives: 2013 Scion FR-S (MT)
I used what was mentioned in the post earlier. I used the HI-Performance Upper Cylinder Lubricant and Injector Cleaner. I used one 5oz. with a full tank of gas 91 octane with 10% ethanol, but I am thinking after my next tank I am going to use the 91 that has no ethanol to see what might happen.
07-27-2012, 10:29 PM | #524 | |
If you can get ethanol free 91 octane that should also work but isn't it supposed to run on 93 octane? Our equivalent here is 98 octane. |
07-27-2012, 10:33 PM | #525 |
Drives: SWP BRZ LTD
In some areas of the US 91 is premium.
07-27-2012, 10:37 PM | #526 |
Yeah, unfortunately here in Colorado it is 91 and if I go to the race track and I think there is one more place besides the track I can get 93. The track is far from where I live and would be pointless to get it all the time.
07-27-2012, 10:50 PM | #527 |
Sounds the same as our premium 95 RON.
High octane is 98 RON. I'm sure running on US 91 is fine as the knock sensors will just retard the ignition timing and the only penalty will be lower power and mpg. It might be hard to pick, hopefully? In Oz the premium cost above standard is nearly 9% more and nearly 13% on top of standard for the high octane brew it's designed for! It's a shame the ethanol is causing problems because it should be a cheap way to get the high octane needed. Hopefully they will soon modify the pump to suit this fuel. |
07-28-2012, 02:04 AM | #529 |
Drives: Attitude
07-28-2012, 04:54 AM | #530 | |
Drives: Mazdaspeed 3
But whatever, people will come to their own conclusions based on their own circumstantial evidence. Funny how you don't see any professional mechanics or tuning shops commenting? They know better |
The Following 2 Users Say Thank You to Fenrir For This Useful Post: | BadCompany235 (07-30-2012), Marrk (07-28-2012) |
07-28-2012, 07:48 AM | #531 | |
Your conclusion is in the same category. Why have many pumps already been replaced in attempts to shut the chirping up if it's normal? Why does a tiny amount of fuel lubricant stop the noise instantly? Here's a bit more taken from a report carried out by Orbital Eng. in Perth WA http://www.environment.gov.au/atmosp...assessment.pdf Potential causes of failure specific to E20 fuel, in order of significance, were found to be the following: • Material degradation • Gumming • Lubrication deficiency • Altered combustion • Fuel properties Last edited by sierra; 07-28-2012 at 09:10 AM. |
07-28-2012, 10:04 AM | #532 |
Drives: Raven FR-S
But the Title of that report is:
A Technical Assessment of E10 and E20 Petrol Ethanol Blends Applied to Non-Automotive Engines. Last I checked, this is indeed an automotive engine....not saying it doesn't have some relevant points...just sayin |
Similar Threads | ||||
Is this idle noise normal? | robo_robb | Engine, Exhaust, Transmission | 288 | 01-25-2022 09:40 AM |
Squeak noise from engine. | Fish | Scion FR-S / Toyota 86 GT86 General Forum | 52 | 05-08-2014 01:06 PM |
Video of chirping at idle | Julio86 | Engine, Exhaust, Transmission | 15 | 02-01-2013 10:37 AM |
Starting to get worried - Engine noise | Laika | BRZ First-Gen (2012+) -- General Topics | 49 | 07-02-2012 03:45 PM |
Idle issue poll/role call | Hawaiian | Scion FR-S / Toyota 86 GT86 General Forum | 8 | 06-13-2012 12:00 PM |
