08-05-2022, 04:55 AM | #505 |
Drives: WR Blue Pearl 2022 Subaru BRZ
08-05-2022, 07:04 AM | #506 | |
Drives: 22 BRZ limited
The Following User Says Thank You to dragoontwo For This Useful Post: | Tcoat (08-05-2022) |
08-05-2022, 08:24 AM | #507 |
This^
And various other plates, accessories, etc, etc. Everybody is so fixated on what is found on the pickup they are ignoring all the other places sealant is used. If excess is breaking off other parts, especially after the filter, then the pickup, although the obvious choice may be meaningless. It would only take a piece the size of a pinhead to be lodged in the wrong oil passage to starve a single bearing to the point of spinning. You wouldn't even see a drop in oil pressure or have any other warning signs at all. This is EXACTLY what was found to be happening in many of the pre-recall FA20s that spun bearings. At that time everybody still wanted to find something else even with all the evidence at hand and I see that this is going to go the same route. See those other colours? How much of the post filter oil journals did they pass through before ending up back in the pan? One of about 30 pre recall failures involving sealant. https://www.ft86club.com/forums/show....php?p=2696906
08-05-2022, 10:39 AM | #508 | |
Drives: 2022 BRZ sport-tech
While i am not an engineer, I was looking at the design of the FA24's pickup and compared to the FA20, the FA24 is a much better design to handle blockages. It has more surface areas where it can draw oil from. Really makes me question if partial blockage is really that big of a concern, assuming the car was no low on oil.
Daijiro Katoh - Champion Forever!
Past: 92 EG w/JDM B18C, 00 EK w/JDM B18C, 04 600RR, 97 ITR #421, 10 Acura CSX-S, 17 BRZ Current: 22 BRZ, 00 S2K - #0220 |
The Following User Says Thank You to Petah78 For This Useful Post: | Tcoat (08-05-2022) |
08-05-2022, 11:21 AM | #509 | |
Professional Mechanic
Drives: 2017 86 6MT Oceanic
No way would my car EVER have the factory fill past 5000 miles, My factory oil got dumped at 1000km, and then at the 6000km "regular interval first oil change" it got drained again along with the gearbox and differential gear oils. So far oil has never stayed in there more than 6000km and the gear oils were changed again at 24000km and just now at 48000km. Further, no way would my car ever be tracked on 0W20. That's dish water meant for getting groceries. |
The Following User Says Thank You to RZNT4R For This Useful Post: | Tcoat (08-05-2022) |
08-05-2022, 11:22 AM | #510 | |
The coloured is more of a concern than the attention it is getting. Yes it was grabbed at the pickup but how much of the engine did it travel through before it made it to the pan? Even worse is how much of the engine did it NOT travel through? How small a piece does it take to plug the channels leading to this hole? For that matter if it is a plugged pickup reducing pressure why does only one bearing have damage? If pressure is reduced to the point of failure it should not be isolated to one singe part. Not saying plugged pickup didn't play a part. If small pieces are present then with full pressure they may be fine but even a slight reduction would have a greater impact.
08-05-2022, 11:52 AM | #511 |
Stiggasaurus Rex
Drives: '14 WRB Subaru BRZ 6MT
meh.
08-05-2022, 12:21 PM | #512 | |
HOWEVER. If you are using a low quality oil filter with a bypass valve that does not seal well, bad filter media design or assembly OR if the filter media is full (like after a long interval with break-in oil) and the bypass is forced to open under high pressure/high flow conditions (high RPM), then stuff can get past the filter. |
08-05-2022, 12:37 PM | #513 | |
Drives: Crapcan
The Following User Says Thank You to NoHaveMSG For This Useful Post: | timurrrr (08-05-2022) |
08-05-2022, 12:43 PM | #514 | |
08-05-2022, 01:00 PM | #515 |
I don't think so. There is some under the cam carrier so a REALLY sloppy application could send some in the VVT oil filter screens, but case-halves oil passages should use o-rings, like the timing cover oil passages, as any sort of RTV is typically not used in pressurized applications.
08-05-2022, 01:01 PM | #516 |
Interesting to see Subaru change the pickup, and it definitely has far more screen area (although not as free flowing as the wire) than the FA20.
Here's few pics of what happened to our 2015 FA20 WRX test mule... The pickup was pulled after a catastrophic failure, but there was some phantom knock leading up to this point (for a subtle split second at startup). The assumption was that a spun bearing was likely in our future. The pickup had mostly silicon stuck to it but also metal. The larger pump on the WRX FA20, higher weight oil, and abuse (450whp and higher redline) has its way with the brittle tack welds on the OEM pickup screen. The last morning it started, engine failure came nearly instantly, since the oil filter bypass is open when the oil is cold. All it takes is one small piece of metal to pop the fragile PM Oil Pump gears and then things go from bad to worse in very short order. |
The Following User Says Thank You to KillerBMotorsport For This Useful Post: | soundman98 (08-06-2022) |
08-05-2022, 01:16 PM | #517 | |
08-05-2022, 02:36 PM | #518 | |
Drives: 2015 FR-S
Bypass of the filter doing it’s job in cold cold starts is that it opens the filter like it should. Everything during that time won’t get filtered. Different filters all have different pressure range difference between input and output where it opens
Tags |
oh no not again |
Similar Threads | ||||
New stock GR86 '22 Dyno Runs: Twins packing more power than advertised!! | steel86gt | GR86 General Topics (2nd Gen 2022+ Toyota 86) | 14 | 03-09-2022 01:15 AM |
Driver's side window seal/door seal | KAB-FRS | Issues | Warranty | Recalls / TSB | 255 | 01-01-2021 06:09 PM |
Is my engine blown? | dallenj | Engine, Exhaust, Transmission | 39 | 01-30-2017 04:18 PM |
Blown engine due to 0W-20? | Benschneider06 | Engine, Exhaust, Transmission | 45 | 07-23-2015 02:33 AM |
Subaru BRZ complete engine gasket & seal kit 2.0L | JPxM0Dz | Engine, Exhaust, Transmission | 0 | 12-18-2012 11:11 AM |
