06-02-2015, 01:24 PM | #491 | |
Drives: Nevermorange FRS
Really looking forward to this.
SCCA T4 - FRS
06-02-2015, 03:59 PM | #492 | |
...Just add nauseum
Drives: 2003 (AP1) S2000
I was then going to calculate the bypass orifice diameter at initial bypass and full open From that you will have all the details you need to model flow, but I have an odd feeling setting it up to measure flow with actual oil will involve drilling tapping or welding a threaded orifice onto the upstream side of the pump cover. Fortunately, the bypass valve is located on the small oil pump cover on the back face of the timing chain cover. I will get a price for the part and see if I am willing to sacrifice one for science. I would also need an electric oil pump, t-fitting, mechanical pressure gauge, and a graduated oil reservoir... With a heating element and a thermometer. All of which I can make, but it costs time and money... And I have a cam oil plate, dual catch can, and gauges to buy. I am welcoming other suggestions though. P.S. - If I'm increasing oil pressure, I'm worried about causing oil pressure related damage to my turbo, which will be taking pressure off of the primary gallery before the filter like almost every other kit... It's a Mitsubishi 20G. Any suggestions? I know old DSM guys used to put restrictors in for the same turbo, but I have no experience with that. EDIT: I've been searching for all the parts diagrams, and it seems that none of the little bits on the back of the timing chain cover can be purchased individually. The whole cover is just north of $350. I talked to the parts manager at the local Toyotas-R-Us and he's going to try to dig up some more information, otherwise I'm just waiting for parts Last edited by Spartarus; 06-03-2015 at 05:36 PM. |
The Following 3 Users Say Thank You to Spartarus For This Useful Post: |
06-03-2015, 10:02 PM | #493 | |
Seņor Member
1974 TA22 Celica
2013 86 GT |
The Following User Says Thank You to Turdinator For This Useful Post: | Calum (06-04-2015) |
06-03-2015, 11:00 PM | #494 | |
Drives: Hydra EMS Powered FRS Raven Black
Send the gear and I can reimburse you the cost of the gear. Ok so I haven't read all posts but there was an assumption we hadn't tried shimming but we have. That however is the most misunderstood modification there is. Is doesn't increase pump volume so if you don't have enough volume it will only increase pressure briefly. The bypass pressure isn't the issue. Bearing surface area matters but width and diameter both need to be accounted for. We've already done the math eons ago and the main reason for using an RB bearing was cost and not because it was a magic fix. I highly doubt this Remax gear will be enough on its own but I'm hoping with everything else we've done it will cover most customers. We've been racing and building flat four engines for a very long time so we have a handle on what's needed. So far everything I thought would happen is and motor failure is absolute with pressure in the 50s on a 400 whp car. We're seeing about a 15-20 psi oil pressure drop under track conditions and that's the main issue. If anyone has seen our dyno video you can see we've got 80 psi to 9k rpm on our builds but we can't maintain that on track. As you start to increase power closer to 500 even 60 psi results in bearing skimming. 70+ psi is the magic number under racing conditions on the EJ but I thinK the FA needs a touch more because of the bearing diameter. As far as pickup starvation the FA is much, much better than the EJ and since we've been running the accumulator I haven't had a starvation issue. A dry sump will always be better but I think this wet sump will carry people pretty far. I was at Watkins Glen a week or so ago and our STI was pulling 1.6 G for about 7 seconds and peaking over 2.1 G. Yikes! Once we square away our aero I'm sure we can eclipse that with the FRS. I'll at least provide the info I see with the Remax gear but it will be based on our engine build but hopefully the delta increase will be useful. |
06-03-2015, 11:24 PM | #495 | |
Don't forget thicker oil is a given and I'm on 50w race, engine holds 10 quarts, Accumulator, , internal engine mods, and I run an oil cooler the size of Texas! Plenty for street guys but still not cutting it on the track for more than 400 whp. |
The Following User Says Thank You to Element Tuning For This Useful Post: | Lee (06-04-2015) |
06-04-2015, 12:31 AM | #496 | |
Drives: '06 AM V8V Coupe
Toyota's multi stage oil pump has relief valves plumbed into the inlet and outlet that open to reduce the displacement, but the pump gear itself is pretty standard. |
06-04-2015, 08:42 AM | #497 |
I said two stage gear but it's a standard type of pump.
Here is reminder of where our engine and oil system is at when run at street oil temps. https://instagram.com/p/xo1MIANvc_/ During competition it's a whole different level. Notice at very high rpm 8-9k that the pressure drops some. It would tank much earlier without the accumulator. |
06-04-2015, 12:20 PM | #498 | ||
...Just add nauseum
I was hoping to come up with some concrete data to be used as a reference for me and others. Otherwise there's little point in hanging around a forum. I plan to race this car, (translation:break it intentionally over and over) but only if I can fix it myself, and rely on it not catastrophically failing on a regular basis. If I can't make the stock drivetrain reliable, I'll jump on the LS/T56-swap bandwagon and use the massive wealth of knowledge that other people have compiled on that drivetrain combination instead. On a related note, [] I've got a line on a transmission fix that might actually work and be affordable for those of us not pushing insane amounts of power. That's the only reason I'm even bothering to try to save the stock drivetrain. Otherwise I'd have an engine and transmission in the members classifieds section by now. Don't expect any updates on that for a few months.[/ ] Last edited by Spartarus; 06-04-2015 at 12:31 PM. |
The Following User Says Thank You to Spartarus For This Useful Post: | BatStig (06-04-2015) |
06-05-2015, 08:55 AM | #499 |
@Spartarus thanks. We don't always share everything we've done, tested, or even evaluated but we've done everything possible with the pressure relief. It is a different design than the EJ pumps and while it has less initial spring rate, it has to travel farther before bleeding. So the actual pressure required to bypass is different since the spring rate, while it doesn't change, it will take more force to open the farther it has to compress.
As you add shims your cold pressure can go though the roof so you think it's promising but once up to temp we discovered that the pressure relief wasn't what was limiting the pressure. Hopefully the Remax gives the pressure a boost and holds longer. This data on our build would clearly be the extreme end in terms of build, mods, and race use and then hopefully someone else will fill in on a oem or more convention build. We will still be moving forward with a bolt on pump or dry sump as it will eventually be needed for serious race applications. |
06-06-2015, 01:41 PM | #500 | |
...Just add nauseum
I'll buy another set once you receive mine. I'm planning on getting "stock" and then "mild turbo" data for now. I've got my fingers crossed for this. In a perfect world, if this pump provides the boost we need, I'd like to run a scavenge only dry sump and rely on the engine pump for pressure. That would massively simplify the dry sump development. That's a next year kind of thing though. I have other projects too, and once I'm finshed with the the turbo and all associated mods, I'd like to put development on the back burner until at least winter. Have to take a break to actually enjoy the damn thing once in a while. I'm eyeing the battery area for the dry sump tank for a few reasons, and it sits right next to that cam plate that loves to leak. I know AVO runs that dinky-ass scavenge pump off of the camshaft at the plate location, but does anyone know what that camshaft accessory drive looks like? Or how strong it is? Could it turn a 2 stage scavenge-only pump? If so, there's your magic solution. That, plus a dry sump pan with two fittings for scavenge ports and one fitting for the engine driven pump inlet. Then, plumb the 2 PCV lines and the 2 crankcase vent lines to baffled chambers on opposite sides of the dry sump reservoir (at the top), add some condensing media and some drain holes to the resivoir, relocate the PCV check valve to the res->intake manifold line, and voila... Catch cans eliminated as well. Hold on, I'm on a roll here... Now you can add capacity to the reservoir and keep that Texas-sized accusump for extreme RPM pump cavitation or pressure drop (If it's still even necessary)... Without overflowing the crankcase or jamming oil into the intake, or running a big silly catch can. Also, having the reservoir above the pump will provide a pressure head that should help to eliminate pump cavitation if it's even happening. EDIT: I suppose you could eliminate one of the lines in that equation and connect the res and crankcase via only the single PCV hose, and block off the front crankcase vent. It wouldn't really matter. It takes time to visualize these things... But i have plenty of time to look out the window at the clouds and contemplate these things. Last edited by Spartarus; 06-06-2015 at 02:23 PM. |
06-08-2015, 10:20 AM | #501 |
Drives: 2013 STI
06-22-2015, 09:59 PM | #502 |
Drives: too many to list
bump
as someone that just spun a rod on a car with 15,000km (not cover under warranty cause I bolted a turbo to it 3km before) I just bought a stock engine for the remaining months of the summer, but would really like to see this dealt with before deciding on what to do with building the old motor. also a huge thanks to element tuning for all the info and sweat/funds invested and now spartarus reviving the possible light at the end of the tunnel for a reasonable priced hold over for people not wanting to build their engines right away keep up the great work!! |
The Following 2 Users Say Thank You to grant For This Useful Post: | Element Tuning (06-25-2015), Ultramaroon (06-22-2015) |
06-23-2015, 07:03 AM | #503 | |
Drives: 2015 BRZ
06-23-2015, 11:34 AM | #504 |
Stig's dark passenger
Hey guys
My Reimax gears arrived a few days ago and should be going in today or tomorrow. We didnt do any spring or shimming mods, hopefully it will hold up. |
Similar Threads | ||||
FA20 Engine component photos | Crawford | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 89 | 02-22-2016 02:31 AM |
FA20 Engine component photos | Crawford | Engine, Exhaust, Transmission | 46 | 01-26-2015 05:19 AM |
Engine Hardware, Gaskets, & Bearings Oh My; All on sale at FR Sport. | FRSport.com | Engine, Exhaust, Bolt-Ons | 0 | 01-10-2014 12:33 PM |
FA20 Le Mans Race Engine | SilverSkyline210 | Engine, Exhaust, Transmission | 11 | 11-17-2013 11:24 PM |
