05-27-2014, 02:26 PM | #491 | |
Drives: '13 SWP BRZ-L
Also, only one of the clamps is in line with the install (rear PCV hose near the transmission), so it really isn't a 'do it while you are at it' kinda thing. So unless you have a super nice installer, it probably will be billed extra time. That being said, it shouldn't be more than 30 minute job by a professional, probably less.
05-27-2014, 05:27 PM | #492 |
Drives: lexus
05-27-2014, 06:56 PM | #493 | |
Drives: 2013 white limited BRZ
05-27-2014, 07:30 PM | #494 | |
Drives: 2014 FRS
I had mine installed yesterday. And this little cricket is a beast now. What spitz said above. My install was was flawless tough. I even let Mike have a lunch brake😬. 8.5hrs between the time the counter space garage door opened and I drove out. We also did camber bolts, front rotors, brake pads all around and stainless steel brake lines. Thanks Mike and David. |
05-27-2014, 09:22 PM | #497 |
Drives: 2014 FRS
Mu club racer pads.
05-28-2014, 02:29 AM | #498 |
Drives: UM86 - 6MT
@CSG David or @CSG Mike I have an OpenFlash Tablet. Is it possible to get the TIY kit initially and run it with the OFT? And then later on down the road I can upgrade to Ecutek?
05-28-2014, 02:31 AM | #499 |
im trying to load the CARB tune and EcuTek tells me that:
a standard tuner license is NOT present in this ECU. Programming will consume a flash license. What am I doing wrong? |
05-28-2014, 02:42 AM | #500 |
Go into EcuTek and check for updates or licenses. It'll ping EcuTek and then ping you back saying your program is connected or whatever. You should be able to load the tune in from there.
The Following User Says Thank You to CSG David For This Useful Post: | gbrz (05-28-2014) |
05-28-2014, 02:45 AM | #501 | |
Call my cell and I can VNC into your laptop from home and program your car for you if need be. |
The Following User Says Thank You to CSG Mike For This Useful Post: | gbrz (05-28-2014) |
05-28-2014, 02:49 AM | #503 |
Damn, that's at least 5 installs that I know of that happened this weekend...
The Following User Says Thank You to CSG Mike For This Useful Post: | *LongFella (05-28-2014) |
05-28-2014, 02:58 AM | #504 |
Oil. Oil everywhere
Must not have tightened... ugh to take off the dam bumper and reinstall again |
The Following User Says Thank You to gbrz For This Useful Post: | driftguy (04-14-2015) |
Similar Threads | ||||
Jackson Racing Rotrex Supercharger System Info and Discussion | Jackson Racing | Forced Induction | 827 | 04-06-2020 04:56 PM |
Jackson Racing Supercharger Press Release and Info | CounterSpace Garage | Forced Induction | 110 | 01-03-2017 09:04 PM |
jackson Racing engine oil cooler - modular to fit the Jackson Racing Supercharger! | CSG Mike | Forced Induction | 24 | 04-27-2016 12:59 PM |
Jackson Racing supercharger | NoppyNop | Forced Induction | 241 | 06-26-2014 03:05 PM |
Jackson Racing Supercharger Pre-Order Sale, $200 off! | Xero-Limit | Forced Induction | 2 | 03-05-2014 04:14 PM |
