Sam Strano
Old 12-30-2013, 10:03 AM   #477
Kido1986
Dodging cones
Kido1986's Avatar
Drives: 2013 BRZ Limited, 93 Z28
Oh, I haven't warped any rotors in so many years I forgot you can lol.
Originally Posted by trevorovert View Post
Originally Posted by mrbillclintong View Post
If you guys spot any riced frs/brz post them here just for laughs no hating please.
Isn't there already a thread like this? It's called aggressive wheels or summat...
C Street Build/Progress Questions about C Street Autocrossing?
Kido1986 is offline   Reply With Quote
Old 12-30-2013, 10:05 AM   #478
NYC BRZ
AutoX Addict
NYC BRZ's Avatar
Drives: 08 Pontiac G8 GT,13 GBS BRZ Limited
Lol yes semi metallic pads beating on stock rotors tends to do that. Especially now that it's cold.
Sent from my SAMSUNG-SGH-I747 using Tapatalk
2013 BRZ Limited- GBS - 6MT -VIN #0937
~~NYR SCCA # 18 C Street R (CSR)~~
"But there’s no mistaking the noise. This car is loud, and not in a particularly nice way. There’s no crisp exhaust note, no induction wheezing. It’s just the sound of petrol exploding in a metal box." - Jeremy Clarkson
NYC BRZ is offline   Reply With Quote
Old 12-30-2013, 10:41 AM   #479
Kido1986
Dodging cones
Kido1986's Avatar
I ran some Carbotechs and the only reason they killed my rotors is I went to bare metal (pads were so loud, I couldnt hear that they were dying). Thats when I bought DBA rotors then realized later they were illegal for this class
Old 12-30-2013, 11:41 AM   #480
Rexpelagi
Drives: 2013 Subaru BRZ
Not saying it can't happen but typically warped rotors don't cause a noise. They will, however, cause pedal pulsation under braking. Pad backing plates often have metal tabs that stick out to contact the rotor when the pads are almost up, and I would think that is more likely. You could also have a rock stuck between the pad and the rotor which will cause a squeal. Then again, it could just be the nature of those pads.
You may have already looked into that but if not just some thoughts.
Kido - do you get a lot of dusting or squeals from the DS2500? I haven't run them on a car in many years and don't remember.
-John L.
2011 BMW M3 - 57 FS
2007 Ford SGT - 57 FS
2013 Subaru BRZ - Sold
Rexpelagi is offline   Reply With Quote
Old 12-30-2013, 12:28 PM   #481
Kido1986
Dodging cones
Kido1986's Avatar
Very minor squeals. They make some noise when the pad is below 70 degrees (first few stops on a cool day) or so but not much. Dust is low side of medium. More than OEM but nowhere near my Carbotechs. It's very livable unless you like your car to look like a show car at all times.
Old 12-30-2013, 12:31 PM   #482
dsgerbc
Drives: BRZ(sold), STI
Pads are squealing cause the grease between those and metal shims got baked. Remove, spray some brake cleaner, lubricate and it should be good.
It is *very* hard to warp a rotor.
dsgerbc is offline   Reply With Quote
Old 12-30-2013, 12:55 PM   #483
Rexpelagi
That's kind of what I remember too - good to know. I've had mixed noise results with HP+'s on other cars but they are always super dusty.
-John L.
2011 BMW M3 - 57 FS
Old 12-30-2013, 01:13 PM   #484
Kido1986
Dodging cones
Kido1986's Avatar
Hawk just isn't worth saving the $30 over a good set of pads IMO. Their pads are too abrasive and dusty for that level of performance. Too much compromise to save $30.
Old 12-30-2013, 03:35 PM   #485
NYC BRZ
AutoX Addict
NYC BRZ's Avatar
Stocks pads are on and squealing is gone. There is a noticeable lip on the stock rotors now from wear. I'll see if I can get subaru to give me my warranty set
Old 12-30-2013, 03:42 PM   #486
Kido1986
Dodging cones
Kido1986's Avatar
I had a thin lip around the edge from where a small portion of rotor had wore away. TO be expected. The lip goes as far out as the rotor did at full thickness.
Old 12-30-2013, 03:44 PM   #487
NYC BRZ
AutoX Addict
NYC BRZ's Avatar
That I understand. Last year I ran the r4s up front and stock rear pads. I loved the feel but I think I'm going to upgrade the rears.
Old 12-30-2013, 04:22 PM   #488
dsgerbc
Measure them first, might still be within spec.
Old 12-30-2013, 04:23 PM   #489
NYC BRZ
AutoX Addict
NYC BRZ's Avatar
I'll grab my calipers from work tomorrow.
Old 12-30-2013, 04:51 PM   #490
Kido1986
Dodging cones
Kido1986's Avatar
I thought rears would be useless. Did nearly a year with just DS up front, stock out back.
Put on a set of DS2500s when the rears were nearly shot. WOW at the difference. I never expected to notice but I really do!
Cinco De Mayo SCCA SOLO Ryeong86 NY / NJ / CT / PA 0 04-23-2013 05:22 PM
Koni Sports in SCCA SOLO Ryeong86 Tracking / Autocross / HPDE / Drifting 4 04-22-2013 12:58 PM
2013 Preliminary SCCA SOLO and PRO SOLO National Schedule Scooby South Tracking / Autocross / HPDE / Drifting 13 12-05-2012 08:08 AM
Houston SCCA Solo #9 - 5 FRS, 1 BRZ hankster Tracking / Autocross / HPDE / Drifting 0 10-09-2012 01:35 PM
SCCA Solo Car Class for the FR-S/BRZ? MrVito Scion FR-S / Toyota 86 GT86 General Forum 31 06-15-2012 10:03 AM
