06-27-2014, 11:37 AM | #4873 |
So elite I'm 1338
Drives: WRB Subaru BRZ
Any news on the 210+ kit? I have searched and haven't found any new information.
The innovate kit is my chosen FI, but i've been thinking about baseball to keep from blowin my load on it because of the 210+ kit. |
06-27-2014, 12:39 PM | #4874 | |
Drives: 2013 WRB BRZ Limited
06-27-2014, 12:44 PM | #4875 |
Drives: 2013 SWP BRZ
can't wait for 8.59. Only think theres a few with it so far.
06-27-2014, 12:57 PM | #4876 |
Drives: GBS Premium
Any plans to release that intake?
06-27-2014, 01:04 PM | #4877 |
Drives: JDL Turbo FRS, 335SC BRZ (ret)
Green lighted and welded up 4 of them yesterday. We will have some pictures next week. They will be powdercoated and use a giant filter in the engine bay. Best for intercooled setups or those running primarily e85.
Though not a cold air intake, the advantages of a full 3" intake and an oversized filter outweigh the benefits of a (restrictive) cold air intake. No bumper removal required. |
06-27-2014, 01:13 PM | #4878 | |
06-27-2014, 01:16 PM | #4879 |
It will need to be scaled for. We'll provide our approximate scaling for other tuners, but AFRs should be double checked since it is a custom part.
The Following User Says Thank You to Xero-Limit For This Useful Post: | mikalem (06-27-2014) |
06-27-2014, 01:16 PM | #4880 | |
Drives: GBS Premium
The Following User Says Thank You to olorin For This Useful Post: | Xero-Limit (06-27-2014) |
06-27-2014, 03:18 PM | #4881 | |
Corner Junkie
Drives: 13 BRZ, 11 STI, 99 RS
The current kit uses a 210 already. So, to me at least, 210+ implies that it uses the same blower. Would Sprintex make a bigger blower and name it the same as a smaller one? I wouldn't believe so.. |
06-27-2014, 04:08 PM | #4882 | |
So elite I'm 1338
I have no idea. I'm trying to find out more information beyond "Sprintex is developing a 210+ and 335 kit." |
06-27-2014, 05:10 PM | #4883 | |
That Guy
Drives: 2013 asphalt FRS MT
06-27-2014, 05:32 PM | #4884 | |
PhoneFlash by EcuTeK
8.59 Revision: We are slowly releasing updates, as we need to customize each persons map, as every person has custom setups and this is a very time consuming process. Intake Options: As for intakes, we have different calibrations for various intakes now including Stock, Airaid, 3" and 2.5", all tested and running well on our new 8.59 tune. Of course you will need custom scaling for the 3" and some 2.5" but we have that taken care of now with some geat customer support. Intake Temp Notes: If you plan on running intakes that may induce more hot air than your standard intakes we have created custom intake temp compensations for ignition and fueling already built into our maps. In certain scenarios such as sitting in traffic, waiting in line at an Autocross or Drag event we have seen temps rise to near 180 degree Fahrenheit (80 C) on some intakes. But having these compensations in place helps to protect the engine from pre-detonation but can lower the torque levels of the vehicle, slowing response and power output until the air has cooled sufficiently. So making sure you have cool ambient air coming into the FA20 engine is key on large or standard sized intakes for consistent and optimal power output. It may be worthwhile on the "warm" air intakes to add some sort of shrouding to the intake in order to keep cool air flowing to it or so that it draws cool air from outside the vehicle. Might be the best of both worlds, larger intake size and cool air. Cheers, William Knose Delicious Tuning |
The Following 2 Users Say Thank You to DeliciousTuning For This Useful Post: | tahdizzle (06-27-2014), whataboutbob (06-27-2014) |
06-27-2014, 06:13 PM | #4885 |
Grip>Slip
All I know is that I had been running my stock axleback because of the rasp. Reinstalled my nameless axleback tonight and it sounds so much better now.
The Following User Says Thank You to xjohnx For This Useful Post: | MINOCIN (06-27-2014) |
06-27-2014, 08:09 PM | #4886 | |
Drives: Asphalt 2013 FR-S
I honestly thought the rasp was due to my headers in combination with the super charger. As though they were just a bad match and not well suited.
Similar Threads | ||||
Innovative ideas to increase interior storage capacity? | swift996 | Cosmetic Modification (Interior/Exterior/Lighting) | 0 | 01-30-2013 10:45 PM |
AVO vs Innovative | diss7 | Forced Induction | 32 | 01-21-2013 06:15 PM |
Not another need to drive topic | Sargy | Mid-Atlantic | 5 | 11-27-2012 12:18 PM |
Technical topic sub-forums | OrbitalEllipses | Site Announcements / Questions / Issues | 1 | 07-17-2012 11:38 PM |
Can you close the topic please? | Standardsuspension | Brakes, Suspension, Chassis | 14 | 06-26-2012 05:14 PM |
