09-20-2018, 01:26 AM | #48525 | |
humfrz |
The Following User Says Thank You to humfrz For This Useful Post: | Sapphireho (09-20-2018) |
09-20-2018, 03:23 AM | #48526 |
Drives: Subaru BRZ
The Following 4 Users Say Thank You to JD001 For This Useful Post: |
09-20-2018, 06:15 AM | #48527 |
Well it is where all the ****s hang out.
The Following 4 Users Say Thank You to Tcoat For This Useful Post: |
09-20-2018, 10:29 AM | #48528 | |
The Dictater
Drives: '13 Red Scion FRS
09-20-2018, 10:34 AM | #48529 | |
helmholtz resonator
Drives: '15 ultramarine
These cars are old. There isn't a problem I can come up with that hasn't been beaten to death on the Lotus board. A shop here in Cal makes a repair kit. I should get it in a day or so. 2006 & Prior S2 Headlight Housing Tab Repair Kit |
The Following 2 Users Say Thank You to Sapphireho For This Useful Post: | humfrz (09-20-2018), Ultramaroon (09-20-2018) |
09-20-2018, 10:43 AM | #48530 |
09-20-2018, 11:01 AM | #48531 | |
helmholtz resonator
You would think that changing the light bulbs would be easy. But nooooo. Jack up front end Remove tires Remove fender liners Remove headlight covers, which conveniently just kind of fall off because the mounting tabs are broken Unclip bulb retaining clip, which is practically impossible since they put the clips in facing down R&R bulb Re-clip, which is harder than getting it unclipped then you try to adjust the beams because one it pointing straight at the ground, the other at the moon, but you run out of adjustment before they are even close, and one of the adjustment screws on your high beam comes out of the housing. Now you can't drive your car because you have no light covers, and a high beam that is just flopping around, so you just want to put the tires back on so you can get it in the garage while you figure out how to repair the light covers and high beam adjuster. Then your jack fails and you can't get your tires back on, so you take your scissor jack out of your twin to jack each side up. Get car in the garage. Simple light bulb change complete. |
09-20-2018, 11:16 AM | #48532 | |
The Following User Says Thank You to Tcoat For This Useful Post: | Sapphireho (09-20-2018) |
09-20-2018, 12:19 PM | #48533 |
chicken tonight
09-20-2018, 12:36 PM | #48534 |
The Following 2 Users Say Thank You to Tcoat For This Useful Post: | Sapphireho (09-20-2018), Ultramaroon (09-20-2018) |
09-20-2018, 01:17 PM | #48535 |
chicken tonight
I'm impressed with clipdat's resourcefulness. I say unleash the beast.
...or turtle.
09-20-2018, 01:35 PM | #48536 |
helmholtz resonator
The Following 4 Users Say Thank You to Sapphireho For This Useful Post: |
09-20-2018, 01:43 PM | #48537 |
chicken tonight
Oh, man, it is ON!
The Following 4 Users Say Thank You to Ultramaroon For This Useful Post: |
09-20-2018, 02:03 PM | #48538 |
Geo Tyrebighter Esq
Drives: '13 scion fr-s
"I gotta rock." -- Charley Brown |
The Following 2 Users Say Thank You to bcj For This Useful Post: | p1l0t (09-20-2018), ScoobsMcGee (09-21-2018) |
Similar Threads | ||||
Language Rant Part Deux | MuseChaser | Off-Topic Lounge [WARNING: NO POLITICS] | 43 | 04-23-2017 07:55 PM |
Random thoughts thread | MrVito | Off-Topic Lounge [WARNING: NO POLITICS] | 37188 | 02-25-2016 10:00 AM |
Random Rubber Part | OoLong | BRZ First-Gen (2012+) -- General Topics | 8 | 01-28-2014 10:31 AM |
Crew Carshow : Part Deux 9/7/13 | saiyajinimports | Great Lakes | 0 | 08-17-2013 05:18 AM |
