08-05-2018, 11:16 AM | #46887 |
Yep you got the order correct. Back when new the convertible was rarer and they cost about the same. Very few wagons survived though since they got driven further and harder.
The Following User Says Thank You to Tcoat For This Useful Post: | humfrz (08-05-2018) |
08-05-2018, 11:18 AM | #46888 |
Just needs adjustment. Unless you have been drifting or driving around with it on.
08-05-2018, 11:24 AM | #46889 |
Geo Tyrebighter Esq
Drives: '13 scion fr-s
Should be a clevis inline that can suck up a bit of cable length.
If that's been turned up to max already, you've been doing a lot of handbrake turns. New cable time.
"I gotta rock." -- Charley Brown |
08-05-2018, 11:30 AM | #46890 |
The Dictater
Drives: '13 Red Scion FRS
I just adjusted the drum brakes in the back. Couple of clicks on each side and it's like new again.
08-05-2018, 12:03 PM | #46891 |
helmholtz resonator
Drives: '15 ultramarine
The Following User Says Thank You to Sapphireho For This Useful Post: | humfrz (08-05-2018) |
08-05-2018, 12:15 PM | #46892 | |
helmholtz resonator
08-05-2018, 12:43 PM | #46893 | |
Pretty busy. Just left a bit ago to get breakfast at Alice’s. So many cars that there’s nowhere left for parking. But definitely some interesting ones. Getting there early was good.
Instagram: @spike.brz
08-05-2018, 02:27 PM | #46894 | ||
Lol no drifting. Usually don’t drive with it on although the first month I owned the car I accidentally had it a couple notches engaged once for about a mile but it’s never been a problem before and that was over a year ago. ¯\_(ツ)_/¯
08-05-2018, 03:16 PM | #46895 |
The Dictater
If you can lift the car and take the wheels off, then you can do it yourself with a flat head screwdriver. You use the screwdriver to turn a little gear in the drum. I'm pretty sure our drums have an access hole so you don't even need to take it off. The tricky bit is turning it the right way and getting both wheels even. Just have to use a bit of trial and error until you are happy with it.
08-05-2018, 03:26 PM | #46896 |
chicken tonight
08-05-2018, 05:07 PM | #46897 | |
humfrz |
The Following User Says Thank You to humfrz For This Useful Post: | Ultramaroon (08-05-2018) |
08-05-2018, 07:01 PM | #46898 | |
chicken tonight
Next we'd wedge up the shoes nice and tight with the adjuster to get them centered. Finally I was to back off until the shoes just barely touched the lowest part of the drum. (They're never perfectly round.) After a quick drive and a couple pulls, you can verify for yourself that this adjustment method is sound for the 86. If you lift up the rear of the car and spin the wheels, the brake shoes will no longer be scrubbing the drums yet you will need at most 3 clicks to secure the vehicle on a moderate hill.
08-05-2018, 07:41 PM | #46899 | |
humfrz |
08-05-2018, 08:11 PM | #46900 | |
chicken tonight
Similar Threads | ||||
Language Rant Part Deux | MuseChaser | Off-Topic Lounge [WARNING: NO POLITICS] | 43 | 04-23-2017 07:55 PM |
Random thoughts thread | MrVito | Off-Topic Lounge [WARNING: NO POLITICS] | 37188 | 02-25-2016 10:00 AM |
Random Rubber Part | OoLong | BRZ First-Gen (2012+) -- General Topics | 8 | 01-28-2014 10:31 AM |
Crew Carshow : Part Deux 9/7/13 | saiyajinimports | Great Lakes | 0 | 08-17-2013 05:18 AM |
