10-01-2014, 08:19 PM | #449 |
@chrisl @thill
Specs still aren't out, they could totally hit those power figures if they throw fuel economy out the window, Toyobaru managed to get 200 horses with D4S, no reason Mazda can't come close with true DI. BUUUT marketing a sports car with >30 COMBINED MPG will likely drive at least a handful of sales. Also the current 2.0L claims 150 ft-lbs. of torque at 4,000 rpm, it will be at least on par with the Toyobaru in terms of torque while sliding in nearly 500 lbs. lighter. The more I think about it, the more I'm excited, especially if Fiat stops screwing around and delivers a companion off the same chassis, a straight swap of the 1.4L MultiAir in the Abarth would be a hoot, more so if they go balls to the wall and toss some MOPAR at it, seems like 25-30 horsepower is available with a tune and mucking with the turbo putting that up into the 190 hp territory. Here's a dynosheet that K&N published for the 2.0L in the Mazda3, for all the talk of delivering a flat torque curve on a Toyobaru... http://www.knfilters.com/dynocharts/69-6033_dyno.pdf |
10-01-2014, 08:47 PM | #450 |
Drives: 2013 DZE/01 (sold for MX5 ND1)
The lower curb weight will improve fuel economy. The engine being mated to RWD and tuned for output and throttle response will hinder it.
The Following User Says Thank You to Deslock For This Useful Post: | abraxis (10-02-2014) |
10-01-2014, 08:55 PM | #451 |
Drives: 86
True that. I guess convertibles also take a hit in mileage when the top is put down? Does the EPA test convertibles with the top up or down?
10-01-2014, 09:06 PM | #452 | |
Drives: '06 AM V8V Coupe
Back in the day of cable throttles, you'd see stuff like the maximum advance on intake cams always activated on Porsche M96 engines for throttle response but nowadays everything is throttle-by-wire and I'd be surprised if they resorted to that kind of method to improve response. With throttle by wire the ECU doesn't have to detect the pedal going down and then shift the cams around, it can open the throttle and change timing at the same time. BMW's solution was to use separate oil pumps to drive the VANOS for better response in the M cars, Toyota's was to use electric motors instead of oil pressure in the higher end Lexus cars. I don't think they actually test the aero, they just take the manufacturer's word for it and enter it into the dyno. The manufacturer tests the drag with top up for obvious reasons. If the EPA actually puts it in a wind tunnel to measure the drag then it would probably test with top up. Last edited by serialk11r; 10-01-2014 at 09:17 PM. |
10-01-2014, 09:21 PM | #453 | |
I forgot to mention that the Miata's gearing (assuming it's shorter) will also hinder its MPG.
10-01-2014, 09:42 PM | #454 | |
Remember, this is the OEM we're talking about. They do their tunes very precisely, and they don't just add fuel everywhere the way some aftermarket tuners will, because they need to meet regulations. You don't add fuel when the engine still has some extra go in it. Throttle by wire lets you control this precisely. |
10-02-2014, 12:40 AM | #455 |
Senior Member/Old Fanboi
Drives: 2000 2ZZ-GE MR2 Spyder HT
I expect Mazda will wring out a few more ponies from the 2.0L for what is, for now, their "halo" model. Even at 155HP the reduced weight and increased HP will make the car faster off the line and out of the corners plus the weight reduction will also aid in braking. The MX-5 will likely give the twins all the competition they want in autox and on the track stock to stock. The question will be whether the Skyactive engine will accept tuning and mods (including FI)as readily as the FA20 to keep the "moar power" boys happy.
So many modders have more cents than sense!
10-02-2014, 01:58 AM | #456 |
Drives: many
10-02-2014, 02:07 AM | #457 | |
Drives: many
The Miata is still going to be a Miata, not a Corvette. |
The Following User Says Thank You to abraxis For This Useful Post: | Atropine (10-02-2014) |
10-02-2014, 02:30 AM | #458 | |
Even if they do the typical 2000s strategy of making everything shorter because sports car, remember that roughly speaking 20% higher cruising rpm = 10% less fuel economy, but if you have 10% less drag it kind of cancels out. |
10-02-2014, 02:51 AM | #459 | |
Drives: 2021 Toyota Supra 2020 4Runner
But what you are saying here is 100% true. Use the tool for the job. I loved my BRZ. I love my Miata. I would love a new Corvette. All are great, but they aren't the same. All 3 are great cars, pick the one you like and respect other peoples choice for getting what they wanted. |
10-02-2014, 03:48 AM | #460 | |
Drives: many
Frankly, I see people calling out the warts on a FRS or BRZ but rave about their Mustang, Vette, Miata, Genesis as the second coming. No. I see FRS and BRZ folk calling out those folks thinking their exhaust fumes don't stink. No. If people would just be more honest both ways, we could cut 85% of the BS posts on forums and get to constructive dialogues. I moderate on other forums so I just have little tolerance for it because it just gets dull, repetitive and unconstructive. Anyway, thanks for getting what I was trying to say. |
10-02-2014, 08:08 AM | #461 | ||
To be clear, I'm not just referring to ECU adjustments and air-fuel mixture. Perhaps I should write tunes/tweaks instead. Quote:
10-02-2014, 09:10 AM | #462 | |
It depends on how the shorter gearing is done. A substantially shorter final drive will ruin the EPA test numbers, but a close ratio gearbox with the same final drive won't because your 1st and 2nd gears will be pretty close to the original, and the main waste of fuel in the EPA city cycle is running the car in 1st gear and 2nd gear too much. Typically for sporty cars you see a close ratio gearbox and often times a shorter final drive as well, sometimes just one, but I think the closer ratios are more likely. Another unknown factor is if they choose to specify shift points. If you officially recommend to shift out of 1st at 2000rpm, then you'll show significant improvement on the EPA test. I think most manufacturers are content to let the manual transmission die off so they don't care about this, but not always. The Ford Mustang and its 1-4 forced skip shift did wonders for its city rating, even though in the real world it probably doesn't actually help for most drivers. |
Similar Threads | ||||
WTB [FL]: Mazda Miata MX-5 03-05 and 06-08, manual transmission | SteelReign | Cars for Sale/Trade | 5 | 06-22-2015 02:01 PM |
2016 mazda miata (MX5) reveal 9 PM EST | Ernie L | Off-Topic Lounge [WARNING: NO POLITICS] | 1 | 09-03-2014 08:41 PM |
FS: Supercharged 1992 Mazda Miata *$4000 OBO* | BRZZZZZZZZZZ | Canada Classifieds | 5 | 08-18-2014 04:44 PM |
The Mazda 2 trully the FWD Miata NA! | Tbomb 25 | Other Vehicles & General Automotive Discussions | 24 | 01-14-2013 09:30 AM |
