03-29-2022, 02:18 PM | #4481 |
CSG hasn't spoken up about how many they would like to stock as of yet, if at all. I have 5 additional over pre-order but they get first pick. Had to order the extra just to make it affordable for everyone. Not currently planning on doing any more runs these. Huge headache for no money.
The Following User Says Thank You to B T For This Useful Post: | aKaGorganZola (03-30-2022) |
03-29-2022, 07:57 PM | #4482 | |
Drives: 13 FRS AT, Edelbrock SC, Tomei EL
I, as well as the other purchasers of your kit I'm sure, appreciate the time/effort you've invested in these. It's very generous of you to share something that improves on the SC Kits performance ! |
The Following User Says Thank You to Brewster For This Useful Post: | B T (03-29-2022) |
03-29-2022, 08:22 PM | #4483 |
Drives: 2021 Supra / 2022 Tundra
Agreed. My remote map kit was great and my car runs so smoothly I can't imagine what it was like before this was an option.
TomR
The Following User Says Thank You to ABQautoxer For This Useful Post: | B T (03-29-2022) |
03-29-2022, 09:52 PM | #4484 |
Good News everyone. CNC parts arrived today. I've got to check them all for fitment and order a set of brass fittings I forgot, but they should ship out soon.
03-30-2022, 08:13 PM | #4485 |
Drives: 14 BSP Edelbrock BRZ
I saw a pic of one of your kits. So much nicer than version 1 that I welded up (poorly) out of aluminum. The 3d printed one didn't work because the plastic didn't survive?
The Following User Says Thank You to toast For This Useful Post: | B T (03-30-2022) |
03-30-2022, 08:17 PM | #4486 |
Thanks Toast, the 3D printed one was never meant to be installed, just fit tested for the CNC model. Went through a couple iterations then sent off for machining.
03-31-2022, 06:41 PM | #4487 |
Well, minor setback, they didn't machine the NPT tap deep enough for a clean fitting install. Going to work on tapping it correctly this weekend. Everything else fits great.
The Following 2 Users Say Thank You to B T For This Useful Post: | aKaGorganZola (04-01-2022), Auto_egr (03-31-2022) |
04-01-2022, 02:10 AM | #4489 |
Drives: 2017 Toyota 86
04-01-2022, 02:53 PM | #4490 |
I got ten orders and had to order an additional 5 just to keep cost low, so I have 5 extra. I've boxed them all up for shipping today. Worked on lengthening the NPT tap hole but marred the surface of test model in the process, so didn't go ahead with the rest. This won't affect performance, but it does cause the thread on the brass fitting to stick out farther than I wanted for aesthetics. Overall, not as happy with this CNC shop as the previous group buy but it'll work without issues. I've also included an extra o-ring in case you have any issue with the one I installed already not sealing. Still waiting on shipping addresses for some of you.
The Following 3 Users Say Thank You to B T For This Useful Post: |
04-04-2022, 04:48 PM | #4491 | |
Drives: 2014 DMG BRZ
Mine's on a A01C, and I'm noticing the same issue. (to be fair - i flashed the car myself... so my fault) https://datazap.me/u/bokehmon/log-16...&data=12-31-44 |
04-04-2022, 10:10 PM | #4492 | |
Howdy
Drives: 2020 BRZ PP
The tuner told me our stock sensor only hits 12.1 and he used the dynapack’s dual wideband sensors to tune richer under WOT. The AFR looks fine when cruising around.
There's a point at 7,000 RPM... where everything fades. The machine becomes weightless. Just disappears. And all that's left is a body moving through space and time. 7,000 RPM. That's where you meet it. You feel it coming. It creeps up on you, close in your ear. Asks you a question. The only question that matters. Who are you?
04-05-2022, 01:18 AM | #4493 |
Drives: BRZ 2015 DGM
finishing up the S/C install, and while bleeding the clutch was able to hear the TOB noise.. its VERY squeky, especially with the hood / manifold out of the way..
some notes: probably wont be adding more power...(maybe...) this is my DD i track 2-3 times a year. thanks all. |
04-05-2022, 01:22 AM | #4494 | |
Drives: brz 2017 hksv2
Anyway that log I see... is full of bugs, as usual in your Country I can t believe people spend like 500 usd or more to get such a bad tune, from a tuner who is obviously not informed at all in our car |
Similar Threads | ||||
Vortech Owner Thread & Setup Questions | reyruiz191 | Forced Induction | 340 | 05-17-2022 12:44 PM |
Edelbrock E-Force Supercharger | itsibarra | Forced Induction | 938 | 07-31-2021 04:48 PM |
Most annoyingly over-asked questions on FT86 forums | mit_peid | Off-Topic Lounge [WARNING: NO POLITICS] | 36 | 01-16-2014 02:48 PM |
Brz Info/Specs (helpful info for questions asked often) | Gaen | BRZ First-Gen (2012+) -- General Topics | 0 | 05-24-2012 10:09 PM |
