03-12-2014, 12:37 AM | #435 |
Fat on Corn Syrup
Thanks Mike!
We'll definitely move to better pads and fluid after this weekend. I'm not sure I'll have time/pads before Saturday morning. I'll read back through the thread to find what pad you and others have already recommended, but how about fluid? We run Motul RBF 600 in our sport bikes. Sent from a secret volcano base using trained sharks |
03-12-2014, 02:52 PM | #436 |
Thanks
Do you think I should get a tune before my first track day? I have a first shipment car, 22500 street miles no problems but the DI issue is in the back of my mind.
Sometimes I feel like I'm punching my car in the face when I trying to get first on cold nights. |
03-16-2014, 11:10 AM | #437 |
The Mechanic
Drives: Civic Turbo,FR-S
what is the optimal operating temperature? i noticed oem is a 190 tstat, personally im use to 180 deg
03-19-2014, 11:57 PM | #438 |
Drives:
Got a track related question? I'll try to answer.
@CSG Mike
Which rear wing(size also), diffuser and front aero do you recommend for downforce improvement for track days? Thank you!! Sent from my iPhone using Tapatalk
2014 Ultramarine Scion FR-S facebook.com/86motorsports Last edited by becauseracecar1; 03-20-2014 at 01:40 AM. |
03-20-2014, 01:38 AM | #439 |
Codename: Stitch
@CSG Mike
I've heard other track day veterans recommend installing an oil catch can, even for a stock NA BRZ. Your thoughts on how necessary it is? (I would avoid adding extra weight/plumbing/complexity to the engine bay if possible)
03-20-2014, 03:21 AM | #440 | |
Drives: Nuisance BRZ
The Following User Says Thank You to car_roll For This Useful Post: | PMok (03-20-2014) |
03-20-2014, 04:01 AM | #441 | |
The Following User Says Thank You to CSG Mike For This Useful Post: | PMok (03-20-2014) |
03-20-2014, 04:01 AM | #442 | |
03-20-2014, 06:38 AM | #443 |
Drives: Subaru BRZ
Question: I bought a new set of 17x9.0 rims for my car. Handling is very important to me as I will be tracking my car this summer. I found a good deal for Advans AD08 tyres, and I know (or at least, I think) the best tyre size would be 245/45/17... because of local laws I need to remain as close as possible to the original size. Would 225/45/17 be that bad for track use?
03-20-2014, 07:20 AM | #444 |
Drives: WRB Subaru BRZ Limited
03-20-2014, 08:15 AM | #445 |
Drives: Scion FRS
Heat Cycle Tires
Do you guys think Heat Cycling Tires makes a difference on Street Performance type tires?
03-20-2014, 08:25 AM | #446 | |
driving smoother faster
Drives: Sold
If you meant selecting an option to have tires heat cycled when purchasing new - if tirerack shows it as an option it can help set up the tire properly and to maintain optimal characteristics longer, otherwise it's not needed if it's not shown as an option. If you meant heat cycling by regular/track use, street (summer) performance tires will usually stiffen and lose grip as they they get more heat cycles. Different compounds react differently to heat cycles but performance (grip) will eventually decrease. Last edited by dp1; 03-20-2014 at 03:40 PM. |
03-20-2014, 08:42 AM | #447 |
The Mechanic
wow if i see that this year im assembling a oil cooler kit
03-20-2014, 08:47 AM | #448 |
Drives: 2013 SWP BRZ
I had oil temps in the 290's and hit 300* at Sebring last summer; UOA afterwards done by Blackstone labs showing everything in terms of the oil properties was hunky dory.
2013 SWP BRZ Build Thread: http://www.ft86club.com/forums/showthread.php?t=38781 |
Similar Threads | ||||
Simple question, hard to find answer... | Mango22 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 5 | 05-16-2013 06:23 PM |
Silly question about protecting track rims | sw20kosh | Tracking / Autocross / HPDE / Drifting | 16 | 04-25-2013 12:34 PM |
Asking the question that I already know the answer to. Are the engines the same? | Bigmaxy | Engine, Exhaust, Transmission | 10 | 01-19-2013 07:47 PM |
Random dog-related question for those who have their BRZ | GMU-BRZ | BRZ First-Gen (2012+) -- General Topics | 11 | 05-31-2012 07:48 AM |
Got my answer - BRZ comes with HID headlights as STD | Z_Rocks | BRZ First-Gen (2012+) -- General Topics | 20 | 01-10-2012 09:54 AM |
