02-10-2017, 08:05 PM | #4439 | |
Drives: 2016 White Pearl BRZ Premium
02-10-2017, 08:38 PM | #4440 |
Drives: 2013 BRZ Limited M/T
The Following User Says Thank You to Bramick For This Useful Post: | Joesurf79 (02-10-2017) |
02-11-2017, 09:43 PM | #4441 | |
Drives: Used to Drive:Grand-Am GS #54 E36M3
Front Spring Rate = 1598#. Front Bar = 38mm with six adjustment holes; bar is set on 4th stiffest hole. So, the front end of this car is extremely stiffly sprung, and it's still lifting the wheel. It was a non-issue as far as driving the car fast. |
02-11-2017, 09:55 PM | #4442 | |
Drives: '22 WRB
The Following User Says Thank You to trippinbillies40 For This Useful Post: | DocWalt (02-11-2017) |
02-11-2017, 10:07 PM | #4443 |
02-12-2017, 01:03 AM | #4444 |
Drives: '22 WRB
Honestly no, sorry I'm genuinely surprised he's lifting a wheel up front outside of jut pounding off of curbs. My car never lifted a wheel on track unless I bounced off of curbs.
That having been said, I agree that I wouldn't worry about it too much. A 20mm front bar on soft and a 16mm rear bar would probably solve the lift. Also, if it's really rolling over that much, you probably need more than 3 degrees of camber up front. 3.2-3.4 probably on that setup. Just a guess though. |
02-12-2017, 10:09 AM | #4445 |
Appreciate all the feedback guys! Looking at the lift on that beemer, I now think that mine might be much ado about nothing. This is the pic with the wheel lift that got me curious.
02-12-2017, 10:51 AM | #4446 |
Drives: '22 WRB
Looks uphill and on camber which will also plant a ton of extra grip and make the vehicle more susceptible to lifting a wheel. I don't think you have anything to worry about!
02-12-2017, 10:59 AM | #4447 |
Drives: 2023 BRZ
Setup on E36s is way different than ours. I wouldn't try to apply too much from those to the BRZ platform.
The Following User Says Thank You to Pat For This Useful Post: | Joesurf79 (02-12-2017) |
02-12-2017, 11:45 AM | #4448 | ||
<end OT> |
The Following User Says Thank You to dradernh For This Useful Post: | Joesurf79 (02-12-2017) |
02-12-2017, 12:34 PM | #4449 | |
Drives: 2017 BRZ
C |
The Following 2 Users Say Thank You to cjd For This Useful Post: | Joesurf79 (02-12-2017), Ultramaroon (02-12-2017) |
02-12-2017, 08:15 PM | #4450 | |
Less worry, more seat time it is. |
03-06-2017, 11:08 PM | #4451 |
Drives: Subaru BRZ Limited
I just bought a set of Maxxis RC-1 to run on dedicated track wheels. I do HPDE and would like to maximize the life and grip of the tires. I've read about a method of initially putting one solid heat cycle in them and then letting them sit for a minimum of 24 hours. To do so I'd sacrifice part of one session and then have to run my street tires for the rest of the weekend.
Other things I've read indicate that it doesn't make much of a difference. What are your thoughts? should I do this single heat cycle method or just run them all weekend? |
03-07-2017, 03:53 AM | #4452 | |
Similar Threads | ||||
Simple question, hard to find answer... | Mango22 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 5 | 05-16-2013 06:23 PM |
Silly question about protecting track rims | sw20kosh | Tracking / Autocross / HPDE / Drifting | 16 | 04-25-2013 12:34 PM |
Asking the question that I already know the answer to. Are the engines the same? | Bigmaxy | Engine, Exhaust, Transmission | 10 | 01-19-2013 07:47 PM |
Random dog-related question for those who have their BRZ | GMU-BRZ | BRZ First-Gen (2012+) -- General Topics | 11 | 05-31-2012 07:48 AM |
Got my answer - BRZ comes with HID headlights as STD | Z_Rocks | BRZ First-Gen (2012+) -- General Topics | 20 | 01-10-2012 09:54 AM |
