07-23-2013, 08:39 AM | #421 | |
I Love custom Turbo kits
Drives: Limited BRZ
The Following User Says Thank You to Sportsguy83 For This Useful Post: | ftc~brz (07-23-2013) |
07-23-2013, 08:43 AM | #422 |
Corner Junkie
Drives: 13 BRZ, 11 STI, 99 RS
07-23-2013, 08:59 AM | #423 | |
Drives: it has 4 wheels and a motor
I wish that SC would be a LOT louder and sooner. |
07-23-2013, 09:05 AM | #424 | |
You describe exactly what the Toyota engineers do in the paper attached to the sticky on the engine forum http://www.ft86club.com/forums/showthread.php?t=3172: 4.4 FINAL INJECTION STRATEGY ADOPTED FOR simultaneous injection.PRODUCTION VEHICLES The final strategy of D-4S system for introduction to production now will be discussed. Simultaneous injection is utilized to optimize combustion at lower engine speeds. The mixture formation using 100% DI at higher engine speeds is sufficiently homogeneous and combustion efficiency is at a level comparable to simultaneous injection due to the piston speeds. For this reason simultaneous injection is not required at higher engine speeds. Another consideration when simultaneous injection is utilized at higher engine speeds, the injector-tip temperature of the DI injector becomes too high promoting injector deposits and degrading the durability of the injector. According to the research [9], a DI injector has issues when the injectortip temperature reaches approximately 150°C. For this reason utilization of simultaneous injection is limited. Figure 16 shows the DI ratio of the utilization area for
2013 FRS Argento Silver 6MT
Mods: Clear fender side lights Tactrix ZA1JB01C 2014 Calib |
07-23-2013, 09:53 AM | #425 |
WUB WUB
Drives: 2013 Firestorm
yup. I went with the Borla UEL. Some people had issues with theirs, I haven't. Just lucky, I guess.
The Following User Says Thank You to wrxgoose For This Useful Post: | ftc~brz (07-23-2013) |
07-23-2013, 12:17 PM | #426 |
Done
Drives: WRB BRZ
07-23-2013, 12:33 PM | #427 |
WUB WUB
Perrin overpipe, catted front pipe, and 3" non-resonated exhaust
07-23-2013, 12:36 PM | #428 |
Drives: 2013 Black FR-S
That is where the base kit should be. What tune are you running? What gas are you running?
07-23-2013, 12:36 PM | #429 |
Done
Drives: WRB BRZ
07-23-2013, 12:43 PM | #430 |
Drives: 2013 SWP BRZ
I put a log of mine in virtual dyno and it reads 218whp/169 tq. I believe Moto-East hit a lot higher torque though on 93.
I will match it up to a data log from NA of mine with the same mods other than the s/c (just an ARK catback exhaust). I'm adding a front pipe and header hopefully within the week |
07-23-2013, 12:44 PM | #431 |
Yes, back in my shop days I dealt with a lot of "bigger is better" talk on the injector front. If you have enough injector for 80-85% duty cycle you are good to go. If you are not approaching this, you have more then enough injector. As has been well established, if you are going to be hitting around 250whp, or a bit more, Look in to doing a pump upgrade. Your stock injectors on the other hand will be just getting in to their sweet spot.
The Following User Says Thank You to mines13 For This Useful Post: | robispec (07-24-2013) |
07-23-2013, 05:15 PM | #432 |
Is anyone running a catch can? I have a guy local who can't use his. I'm guessing it would sit between the line coming from the crankcase and the intake?
2010 Cadillac CTS-V Sedan M6 w/550whp (Build Thread) |
07-23-2013, 05:25 PM | #433 |
Drives: s13<EP3<s14<RSX TYPE-S<WRX<GTI<FR-S
So what is everyones gas mileage like so far? I am averaging around 20 and I am treating the gas peddle like its made out of glass. I think my tune is still pretty rich. I am sure it will continue to improve with I get my next update from @FA20Club.com .
07-23-2013, 05:29 PM | #434 | |
WUB WUB
Similar Threads | ||||
Innovative ideas to increase interior storage capacity? | swift996 | Cosmetic Modification (Interior/Exterior/Lighting) | 0 | 01-30-2013 10:45 PM |
AVO vs Innovative | diss7 | Forced Induction | 32 | 01-21-2013 06:15 PM |
Not another need to drive topic | Sargy | Mid-Atlantic | 5 | 11-27-2012 12:18 PM |
Technical topic sub-forums | OrbitalEllipses | Site Announcements / Questions / Issues | 1 | 07-17-2012 11:38 PM |
Can you close the topic please? | Standardsuspension | Brakes, Suspension, Chassis | 14 | 06-26-2012 05:14 PM |
