#421 |
Drives: 2014 Subaru BRZ
where can I DL the ver 3 tune for stage 2?
#422 |
Drives: 2017 BRZ |Yellow series/Limited|
v3.2 Tunes
#423 |
Drives: 2014 BRZ Limited SWP
#424 |
Drives: 2016 BRZ Limited
Can someone help me determine which tune I should throw on my car (2016 manual)? I just got my OFT Monday. I flashed the v 2.07x stage 1 91 octane tune for the moment.
So, I have 93 available everywhere here. I also just got myself a V1 openflash header (not one of the new V2/3 ones). I would like to know the best tune for now, and the best tune for when I put the header on in a few weeks. I am confused by the following options: 91 vs 93 octane tunes. Should I go 93 if its available here? I see people mentioning no 93 tunes, or just using a 91 anyway? v2.07x vs v3.0x tunes. Should I attempt to get the v3 tunes from Shiv? I emailed Monday morning and still have not received any answers. Stage 2 UEL tunes vs OFH specific tunes. Are these specific tunes only for the v2/3 OFH? Are there any downsides to running this one instead of the generic? Thanks guys, hopefully someone here can help. |
#425 |
BCB75 -- I think you're a bit confused. There is only one available header from Openflash. On the website, OFH refers to the header only; OFH2 refers to the tablet + the header; OFH3 refers to the tablet + the header + overpipe.
Regardless of whether you get the overpipe or not, here's the deal: If you're running the stock header (ie., not the openflash header and/or overpipe), then you can use the STAGE 1 off-the-shelf tunes from the website. If you've installed a non-Openflash header (with or without a new overpipe), you should use the STAGE 2 off-the-shelf tunes. If you've installed the Openflash header (with or without a new overpipe), you should use the Stage 2OFH tunes (v1.01) shown on the website. In all cases, whether you use 91 or 93oct is entirely up to you; latter are a bit more aggressive, so make sure you're in fact using 93 gas in that case. Most of the discussion in this thread is about the new v3 tunes, which are to the best of my knowledge only relevant for 2017 models (which have a different ECU map). |
#426 |
bzdont - see this thread for information on OFH v2/3 release
http://www.ft86club.com/forums/showthread.php?t=100751 I picked up an old one that is from before this update was made. It also seems to be around the same time that the OFH specific tunes were created (which I also think may have been created for the v3 with the integrated OP). I figured there might be enough difference that mine would be considered a "generic UEL" at this point. The package with the tablet can be ordered with the OFH2 or OFH3. So just to confirm, a 93 tune will be more aggressive, and the v3 tunes are only for 2017+ cars? EDIT: Actually found a post from Shiv in that thread stating "Same tune regardless of OFH1, OFH2 or OFH3 " so I should be good with that one. |
| The Following User Says Thank You to BCB75 For This Useful Post: | OrangeGuitar (10-26-2017) |
#427 |
Bzdont - shiv also just sent me a message with v3 tunes for my 2016. Just thought you might want to know they are out.
#428 |
Drives: Toyota 86
Hi there
Looking for the v3 ZA1J___I ROMS(EU 6AT). Specifically the stage 2 uel tune. Does anyone know if these are out yet? I've emailed Shiv 3 times but he has not replied to me at all. Any help will be much appreciated |
#429 | |
With 95 ron you rearly need a customised tune Pm me i can help you out |
| The Following User Says Thank You to steve99 For This Useful Post: | lutfy (10-31-2017) |
#430 |
Drives: 17 86
#431 |
Drives: 17 Series Yellow BRZ
I’ve never driven the earlier year models but it was immediately obvious with my 17 even during the quick test drive. I still bought the car knowing a uel header and tune would fix it. I got a jdl uel and oft after driving the car stock for a couple months and they definitely fixed the torque dip. So it’s still present on a stock 2017.
#432 | |
Drives: 2017 86
Sent from my Pixel 2 XL using Tapatalk |
#433 |
Drives: 2017 manual BRZ
The dip on the 2017s has been narrowed but is slightly deeper.
Sent from my Pixel XL using Tapatalk |
#434 |
I don’t feel it anymore, that’s for sure. The power builds as the rpms increase now just like it should. Acceleration from 2,500 rpm and up it just builds power and I do not feel an obvious dip where it used to be. Before there was a decent amount of low end torque, and then an obvious dip, then it felt like a mild “vtec” kicking in sort of feeling after the dip was over. Now it’s just smooth.
| OpenFlash Tablet: Multiple Data Log files! | Shiv@Openflash | Software Tuning | 95 | 11-09-2017 09:40 AM |
| OpenFlash Tablet: OTS v2.0 Beta (132 new maps, 12 new XMLs) Available for Download | Shiv@Openflash | Software Tuning | 1062 | 08-13-2017 05:13 PM |
| Openflash Tablet v1.31 beta maps (including Stage 2!) now available for download | Shiv@Openflash | Software Tuning | 354 | 02-08-2015 06:23 PM |
| OpenFlash Tablet v1.55b: BIN files added! | Shiv@Openflash | Software Tuning | 525 | 04-09-2014 10:42 PM |
| Now Available: OpenFlash Tablet Datalogging/Datagraphing (BETA Release) | Shiv@Openflash | Software Tuning | 255 | 02-15-2014 05:43 AM |
