07-20-2020, 12:29 PM | #4299 |
Drives: 18' BRZ tS
Looking at a set of ESR RF2 for my BRZ tS lowered on Eibach Sportlines with -2.5 degrees of camber.
I reached out to ESR and they said with18x9.5 +22 they are "pretty sure will fit the Brembos" but that they didn't have confirmation. They also offer 18x9.5 +35. In the same wheels. I like the aggressive wide wheels with poke but would the +22 look absolutely ridiculous? This would be my street set-up. Any autocross days will have the stock Enkeis. Should I roll the dice on the +35? Any info/advice would be appreciated. Looking at 235/40 18 tires to go with the set up
18' BRZ tS 300/500 (CBS)
08-25-2020, 03:34 PM | #4300 | |
Drives: '17 BRZ / CBS + PP
My SSR Comps clear Brembos with no spacer, at ET +48 on an 8.5" wheel. So, 9.5 would put it -13, which would be right on at +35. Spoke design, however, is what it's all about. I wouldn't roll the dice without pics of the ESR wheels from the side, showing spoke "arc"... If it helps, I can post a clearance pic with my wheels so you can eyeball. |
The Following User Says Thank You to LatentWagen For This Useful Post: | TheRichLife (08-29-2020) |
09-01-2020, 02:09 AM | #4301 |
would i need spacers to clear esr sr01 wheels that are 18x9.5 +35 ?
09-01-2020, 05:55 AM | #4302 |
Drives: 2017 BRZ Limited
I want to get some SSR Professor SPX wheels with a staggered fitment. Evasive is recommending standard concave 18x9.5 +35 in the front and super concave (SL) disc 18x9.5 +30 in the rear. Does this sound like it should fit? It sounds a little suspect to me, and I am worried about clearance issues in the rear. But I'd like a second opinion from the experts.
09-01-2020, 02:00 PM | #4303 |
Drives: 2015 BRZ
09-01-2020, 02:05 PM | #4304 | |
Drives: 2015 BRZ
The Following User Says Thank You to Vital For This Useful Post: | djezlee (09-02-2020) |
09-01-2020, 03:25 PM | #4305 |
Drives: 2014 GT86
Vital: in this case suggested wheel diameter and width is same, only different offset. Not exactly staggered in classical sense, kind of lesser evil. While such setup will still have some cons, but less bad then more common staggered different width wheels choice which will add lot of understeer. My own choice would still be same wheels on all four corners, and if fitment matters that much, then one can use on one axle spacers, but for some suggested also may work.
The Following User Says Thank You to churchx For This Useful Post: | djezlee (09-02-2020) |
09-01-2020, 03:52 PM | #4306 | |
Drives: 2015 BRZ
09-01-2020, 09:25 PM | #4307 |
09-02-2020, 01:57 AM | #4308 |
Drives: 2014 GT86
Now on airlift, there might be clearance problems, not more clearance vs stock as with most aftermarket coilovers (which usually have smaller diameter springs then stock). I guess, to be on safe side, i'd probably think of not going to x9.5". Unless widebody, but then very different offsets/wheels anyway.
The Following User Says Thank You to churchx For This Useful Post: | Vital (09-02-2020) |
09-02-2020, 07:31 AM | #4309 |
Drives: 2015 BRZ
Ah in that case, disregard what i said. Unfortunately, i cannot help with air suspension fitment. Here is a thread that might help you: https://www.ft86club.com/forums/showthread.php?t=77588
09-02-2020, 08:18 PM | #4311 | |
09-13-2020, 03:54 AM | #4312 |
Drives: gt86 hachi-roku
wheel if it?
Hey guys, urgently asking you, i already bought new wheels, so the size is 9.5J ET48 front and rear, wheel it fit in front with 245/40/18 in stock car, it wil not scrub or rub smthg? or should i do 235/40/18 and 245/40/18 rear, i cannot fit 35% because of the asphalt in our city...
Tags |
fitment, flush, offset, rays volk te37's, rims, rotas, size, spacers, width |
Similar Threads | ||||
Determining the proper width size of the tire | CyberFormula | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 49 | 05-23-2014 09:11 AM |
Correct tire width for each wheel width | DarrenDriven | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 10 | 08-16-2012 02:03 PM |
TIRE SIZE CALCULATOR | White64Goat | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 6 | 08-15-2012 02:31 AM |
Tire Width vs Wheel Width | Synack | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 40 | 08-12-2012 11:21 PM |
