11-12-2017, 08:54 AM | #4271 | |
Drives: 2017 BRZ
ETA: Just checked out a few pics. Yeah I'd mount it elsewhere. Last edited by gtengr; 11-12-2017 at 09:13 AM. |
11-12-2017, 10:21 AM | #4272 | |
Drives: 2013 FRS / 2013 427 Vert
The recirculating noise my car was making when cruising or decelerating had gotten louder than my 3" exhaust overtime. Figured I would give this valve a try and keep the JR as a spare. Noticeable reduction in recirculation sound, closer to what it sounded like new, and quicker back on boost performance when you are simulating lift for corner then hard back on it for exit. I'm certain that it is not a placebo affect as I have enough hard miles on the car to tell the difference. It may well be the original valve has issues that are gradual rather than all at once.
[SIGPIC][/SIGPIC]
2013 FR-S Asphalt BC Coils/Rev Works UEL header/HKS Front Pipe/Racing Brake BBK/Shorai LW Battery/ACT 6 Puck Clutch/FBM Radiator & Oil Pan/JR Oil Cooler/Jackson Racing High Boost C30/Rev Works Built Motor 2016 Audi TTS APR Tuned |
The Following User Says Thank You to Deep Six For This Useful Post: | mrg666 (11-12-2017) |
11-12-2017, 11:25 AM | #4273 |
pessimistic skeptic
Jackson Racing has extensively tested this system. If there was any oil circulation problem, all JRSC Rotrex units out there should have failed already. Are you making recommendations just looking at pictures against the installation instructions of Jackson Racing?
11-12-2017, 11:29 AM | #4274 | |
pessimistic skeptic
11-12-2017, 12:56 PM | #4275 | |
Drives: 2017 BRZ
Also, I'm amused that you would cite JR's extensive testing of this kit when your very next post is about replacing one of the parts that comes with it due to repeated failures. Yes, the oil reservoir looks to be higher in the pictures and per the other posters reports. I don't know by how much, but if it's easy to adjust or relocate, I would. Why not? |
11-12-2017, 02:08 PM | #4276 |
Went right to the yellow spring
[SIGPIC][/SIGPIC]
11-12-2017, 02:41 PM | #4277 | |
pessimistic skeptic
Do you know if the oil circulation is "natural" or "forced"? If it is forced, it doesn't matter if the reservoir is a little above or below the compressor level. When the engine and compressor are running, there is a very clear temperature delta between the inlet and outlet hoses, showing that the oil circulation is working. So there is no reason to worry about the location of reservoir in the instructions. Plus, for the first prime right after installation, I would prefer having the reservoir higher than the compressor for gravitational help. And, yes, JR recommendation is more important than Rotrex recommendation. They worked directly on our cars. |
11-12-2017, 03:28 PM | #4278 | |
Drives: 2017 BRZ
The operation of the Rotrex oil system is independent of the car it's on. You should read the Rotrex maintenance pdf and count how many times they say not to put the reservoir above the charger, then try to think of a logical reason why those important directions aren't important on an 86. |
11-13-2017, 01:26 PM | #4279 | |
Drives: JR FR-S,
We have been a lead Rotrex partner for over 11 years now and have been building the kits for a while. We are familiar with the units and their design parameters. |
11-13-2017, 01:52 PM | #4280 |
helmholtz resonator
Drives: '15 ultramarine
11-13-2017, 01:59 PM | #4281 | |
Drives: JR FR-S,
Obviously, people want different noises from their car, so aftermarket valves are popular. Also, racing applications and areas above 15psi will require a different valve. We use a name brand, reputable aftermarket valve on one of our race development vehicles. This development vehicle is running 20psi and has very different design parameters. We recommend running a recirculation valve for best transient response and emissions compliance for street vehicles. The most important thing to remember is make sure you run the SOFTEST spring on an "adjustable spring" valve. The vacuum connection should be controlling the valve, not the spring. Too much spring pressure will not allow the engine vacuum to properly pull the valve back. This causes compressor surge and will damage the Rotrex unit. Last edited by Jackson Racing; 11-29-2017 at 07:08 PM. Reason: Typo |
11-13-2017, 02:56 PM | #4283 |
Drives: 2013 scion fr-s
Just finished the install (and the 70 mile break-in) and am wondering if I can get a few "reality checks"...
1) From the ProECU logging of Manifold Absolute Pressure, I'm seeing 2.5 psi at idle between 12.5-18 psi of boost when between 2000-6700 rpm. Is this expected? 2) Oil temprature peaked at 100 C for the test drive. What is the acceptable range for engine oil tempratures? Last edited by q335r49; 11-13-2017 at 08:06 PM. |
11-13-2017, 06:06 PM | #4284 | |
Drives: 2014 BRZ Limited (DGM)
Question: you are pretty adamant that the softest spring be used in the non-JR-supplied recirc valve scenarios, but folks are reporting the best observed results with the stiffer/stiffest springs in their kits. I'm not second guessing your advice -- I'm simply curious why this is? |
Similar Threads | ||||
Jackson Racing Rotrex Supercharger System Info and Discussion | Jackson Racing | Forced Induction | 827 | 04-06-2020 04:56 PM |
Jackson Racing Supercharger Press Release and Info | CounterSpace Garage | Forced Induction | 110 | 01-03-2017 09:04 PM |
jackson Racing engine oil cooler - modular to fit the Jackson Racing Supercharger! | CSG Mike | Forced Induction | 24 | 04-27-2016 12:59 PM |
Jackson Racing supercharger | NoppyNop | Forced Induction | 241 | 06-26-2014 03:05 PM |
Jackson Racing Supercharger Pre-Order Sale, $200 off! | Xero-Limit | Forced Induction | 2 | 03-05-2014 04:14 PM |
