05-07-2014, 09:31 PM | #29 |
Member of the year - 2016
Drives: Scion FRS
Need to see it on a FRS too!
Everyone knows those are the only ones you see on the track ripping it anyways...
05-08-2014, 11:12 AM | #30 |
Drives: 93 MR2 Turbo; 2014 BRZ
The time and money in order to do this would not make it possible for most. You would either need access to a wind tunnel, or very sensitive load sensors with a data logging system.
The Following User Says Thank You to eric6 For This Useful Post: | JohnJuan (05-08-2014) |
05-09-2014, 08:33 AM | #31 |
Drives: Subaru
I saw this and forgot to comment. If there is a race version, the street version will be able to be converted to race version. So there won't be a worry of buying the street version and regretting waiting for the race version.
05-09-2014, 10:35 PM | #32 |
The Mechanic
Drives: Civic Turbo,FR-S
i definitely appreciate the data. i was kinda hoping it would be around $170~ being plastic. heavy ass plastic lol
05-10-2014, 03:50 PM | #33 | |
This material is strong enough to hold up 150 pounds or more, and in fact I stood on the front of my car to prove it. The issue is it attaches to the bumper, which is plastic and bows down. We will remedy this issue with the race version using additional reinforcement that attaches to a more rigid part of the car structure. This reinforcement will then carry the bulk of the load generated by the down force. The street splitter is perfect for auto crosses and people who want an aesthetic upgrade that actually works. I realize this is not the most appealing splitter on the market but I can assure you that no other splitter produces down force similar to this one. If you look at the designs out there and understand the fundamentals behind a splitter, it is fairly easy to tell that most of the other splitters on the market are either purely cosmetic, or mostly cosmetic with a splash of performance. |
05-10-2014, 03:53 PM | #34 | |
Off Topic
05-10-2014, 04:06 PM | #35 |
Drives: 86
I am now more interested in the race version
VOLK LE37 17X7.5, SWIFT Springs, Bilstein B8, HKS intake duct, Cosworth Air Filter, HKS headers, PLM Over Pipe, EVS Down Pipe & Exhaust, FD 4.55, GFB pulleys, Axle-Exchange Drive Shaft, Mishimoto oil cooler, Cusco F&R strut bar, TRD door stabilizer, Innovate SC, Delicious Tuned
The Following User Says Thank You to 8686 For This Useful Post: | TouchMyHonda (06-11-2014) |
05-10-2014, 04:46 PM | #36 |
Wayward Member
Drives: Hot Lava 86
Does it have the extra bumper mounts like the APR one? I can never remember what they're called. The little piston looking things.
05-10-2014, 04:53 PM | #37 |
Drives: Asphalt Scion FR-S
Has this been tested at speed? I've already ordered it but I'm questioning if I should bother installing it before next track day or if it will just end up ripping off
05-10-2014, 06:07 PM | #38 | ||
[ame="https://www.youtube.com/watch?v=kLwSrouI71U&list=UUpVmSjcwyzze1YGEsCuVfXA"]Splitter R&D - YouTube[/ame] Quote:
The race version will be an add on to the street splitter. It is currently in the works. |
05-16-2014, 02:24 AM | #39 |
Received the splitter yesterday, and got around to installing it today. Install is pretty straight forward, the only difficulty I found was getting the 25mm bolts with spacers to thread, a longer bolt would make this easier.
This generates downforce. I removed the foam behind the front bumper some time ago. Took the car out for a drive, got up to 90mph, didn't hit triple digits though, and the top clips on the passenger side next to the headlight started popping out. I'll have to try installing the foam this weekend and see if that helps support the bumper. Tie rods or some other support to the chassis would help. Update: I believe that last time I installed the bumper, I didn't bank the bumper towards the car when tightening the top mounting bolts. I loosened those bolts slightly and lightly pushed the bumper in and retightened. End result is success, hit triple digits and securely mounted. FT86SF Splitter by jdkane527, on Flickr FT86SF Splitter by jdkane527, on Flickr FT86SF Splitter by jdkane527, on Flickr FT86SF Splitter by jdkane527, on Flickr FT86SF Splitter by jdkane527, on Flickr FT86SF Splitter by jdkane527, on Flickr FT86SF Splitter by jdkane527, on Flickr FT86SF Splitter by jdkane527, on Flickr
The Following 7 Users Say Thank You to JDKane527 For This Useful Post: | eric6 (05-16-2014), Fly Guy (05-17-2014), FT-86 SpeedFactory (05-16-2014), jack43 (05-16-2014), plucas (05-18-2014), Pseud0logik (05-16-2014), Teseo (11-09-2014) |
05-16-2014, 11:12 AM | #40 |
Turbo 86
Drives: GT86
the lip looks so BIG
10 - 1 = 0
real math |
The Following 3 Users Say Thank You to calibrz For This Useful Post: |
05-16-2014, 11:39 AM | #41 |
Drives: 86
It is a positive for me Sent from my iPhone using Tapatalk
The Following User Says Thank You to 8686 For This Useful Post: | Teseo (11-09-2014) |
05-16-2014, 01:27 PM | #42 |
Off Topic
It looks to be about an inch thick? Is that right?
Similar Threads | ||||
Just Added APR front splitter and side splitter | Pekingduck | Cosmetic Modification (Interior/Exterior/Lighting) | 42 | 08-31-2016 10:22 AM |
What front splitter? | Takumi788 | Cosmetic Modification (Interior/Exterior/Lighting) | 7 | 04-30-2014 06:20 PM |
Perrin Oil Cooler - Impressions, Pics, and Data | swift996 | Engine, Exhaust, Transmission | 36 | 04-29-2014 09:03 AM |
BRZ Front Splitter | Jive Turkey | Cosmetic Modification (Interior/Exterior/Lighting) | 43 | 01-26-2014 03:29 PM |
Front Air Splitter | sw20kosh | Tracking / Autocross / HPDE / Drifting | 6 | 02-17-2013 05:41 PM |
