Old 04-18-2014, 09:56 AM   #29
Darryljr11
Sideways and Smiling!
Darryljr11's Avatar
Drives: Scion FR-S
13F 13R street for now
D.C. roads are shit! lol may have to go full soft
Darryljr11 is offline   Reply With Quote
Old 06-14-2014, 11:32 PM   #30
dp1
driving smoother faster
Drives: Sold
Ohlins Road & Track - settings (clicks) for street/track/ax
After some more testing on a new car, -10f/-11r is a little bit on the stiff side but not stiff and still comfortable on the street, with very sharp handling. Sweet spot for me is at -13f/-14r for daily driving - increases comfort and still preserves most of the sharp handling on the street. Tried -16f/-17r and while the comfort on the street is even better over good pavement, car gets a little floaty over bigger bumps or wavy roads. This set is amazing IMHO, well worth the money.
dp1 is offline   Reply With Quote
The Following User Says Thank You to dp1 For This Useful Post:
OICU812 (06-15-2014)
Old 06-18-2014, 04:23 PM   #31
dp1
Drives: Sold
Interestingly enough, I tried -18 clicks all around on the street and it's the most comfortable setting yet, with even less floating feel than at -16. Still good handling, just a little less sharp...but it's so easy to firm up for spirited driving while enjoying the comfort for daily commute and alike
CxG (04-22-2016)
Old 08-10-2014, 07:34 PM   #32
Sleepless
Sleepless's Avatar
Drives: 2014 BRZ
Street: 20f/20r
Track: 5f/4r
Lowered 20mm f/r with corner balance
Camber -2.5f/-2.0r
Toe 0f/small to-in r (don't recall exact #)
Sleepless is offline   Reply With Quote
The Following User Says Thank You to Sleepless For This Useful Post:
dp1 (08-10-2014)
Old 10-22-2015, 11:11 AM   #33
rx3
Has anyone run them on racing tires and considered a higher spring rate because of it?
rx3 is offline   Reply With Quote
Old 05-27-2016, 07:13 PM   #34
Efferalgan
Drives: Toyota GT 86
Originally Posted by Racecomp Engineering View Post
One quick thing, don't expect 10 clicks on the front to "equal" 10 clicks in the rear. The front and rear aren't valved exactly the same....yes you'll likely be close to the same number of clicks as that's how the ranges are designed but a 10 in front isn't necessarily a 10 in back. Heh. Ain't that the truth.
- Andy
I just found out that I have 30-31 clicks on both rear dampers WTF??
Efferalgan is offline   Reply With Quote
Old 05-28-2016, 01:20 PM   #35
Dihudaxia
Drives: 86
According to Ohlins, its normal, beyond the first 20 clicks, each other click has little or no impact to the ride.
Usually i dun go that soft. My setting is 14/14
Dihudaxia is offline   Reply With Quote
The Following 2 Users Say Thank You to Dihudaxia For This Useful Post:
Efferalgan (05-29-2016), Greddy86 (05-29-2016)
Old 06-03-2016, 09:13 AM   #36
ajc209
Drives: GT86 Cosworth
I have 400lb/in springs at the back, but I run mine at about 12-15 click on british B roads. Set them too soft and the car is all over the place on bumpy back roads.
On the track I vary from 5-8 clicks
This is on AD08R 235/40/18 tyres.
ajc209 is offline   Reply With Quote
Old 06-03-2016, 11:43 AM   #37
Efferalgan
Thanks! Thank was hugely helpful for the peace of my mind Because fronts have about 25 clicks.
Old 06-21-2016, 12:33 AM   #38
corry29
corry29's Avatar
Hello everyone, for those who have the Ohlins R/T
I just got these installed on my FR-S, the coils were set at its lowest front and rear, and after settle, it seems like it's a 1 finger gap in the front and a 2.5 or 3 finger gap on the rear?
Is that the same for you guys?
corry29 is offline   Reply With Quote
Old 06-21-2016, 01:23 AM   #39
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
From my install thread:
http://www.ft86club.com/forums/showthread.php?t=48679
- The rear suspension allows you to lower the car about 1" at most. IMO if you want to lower the car more, or get a bit more adjustment height-wise, get Ohlins with the Stance rear lower control arm.
- The front suspension allows you about 1.5-1.75" of lowering at most.
The Following User Says Thank You to mav1178 For This Useful Post:
corry29 (06-30-2016)
Old 06-27-2016, 09:36 PM   #40
boomslang
Drives: Toyota
My front gap is about 0.75" from the tire at full lowering.
My rear gap is about 1.125" from the tire at full lowering.
My plan is to change out the rear top hats for Raceseng ones and no rubber top piece...that should gain me 0.3" more lowering to even it all out...at least I hope.
boomslang is offline   Reply With Quote
The Following User Says Thank You to boomslang For This Useful Post:
ohlins road and track shock absorbers CyberFormula Suspension | Chassis | Brakes -- Sponsored by 949 Racing 31 11-11-2014 05:00 AM
FS: Ohlins Road And Track DFV Coilover in Socal mtsui Brakes, Suspension, Chassis 5 03-27-2014 11:02 PM
Ohlins Road & Track Coilovers for sale h4nh Brakes, Suspension, Chassis 17 02-18-2014 11:35 PM
Ohlins Road & Track Coilovers - IN STOCK!!! RallySport Direct Brakes, Suspension, Chassis 7 05-28-2013 04:11 PM
Ohlins Road & Track Subaru BRZ and Scion FR-S HP Autowerks Brakes, Suspension, Chassis 0 04-24-2013 03:27 PM
