Engine, Exhaust, Transmission Discuss the FR-S | 86 | BRZ engine, exhaust and drivetrain. |
11-28-2013, 12:32 AM | #29 |
Drives: FRS, Supra, Colorado D, GLC63
Another thing to lust after! You guys sure do make parts decisions difficult. Great looking product.
11-28-2013, 12:51 AM | #30 | |
That guy
Drives: Ultramarine mt FR-S
Ultramarine mt FR-S
P&L stage 1 turbo Prime Motoring Flex fuel Jr Tuned 506whp @17psi (e73) |
11-28-2013, 09:42 AM | #31 |
you know there's a button for that, right? i'm sure it's easier to just complain than to learn how to work your email client...
11-28-2013, 11:15 AM | #32 |
Drives: 2013 White Out FR-S
Yes correct there is a button for that on each email.
11-28-2013, 11:16 AM | #33 |
11-29-2013, 10:12 AM | #34 |
Drives: White Lancer Evolution X
I know FA20Club doesn't really use the Vortech supercharger but would you know if this plays nicely with the Vortech intercooler/intake/etc?
11-29-2013, 10:29 AM | #35 |
yes, it does. we've installed the Perrin cooler on the Vortech and our Sandwich plate and fittings are identical so it will play nice with the Vortech airbox.
The Following User Says Thank You to FA20Club.com For This Useful Post: | WWEVOX (11-30-2013) |
11-30-2013, 09:56 AM | #36 |
On a system like this, with a non thermostat takeoff plate, could one put a valve on the oil cooler line to stop flow to the oil cooler when it's cold and the oil is not getting up to full temps?
This seems like a good way to ensure the oil gets hot enough on cold days, as long as it doesn't cut off the oil to the engine. |
11-30-2013, 11:26 AM | #37 |
What is the projected pricing on this? and will the sandwhich plate have extra 1/8npt ports on it?
12-01-2013, 07:34 PM | #38 |
You can tap the plate or the spacer for an extra port just like any other not a big deal. The kit is post for sale online on the site for $950.00
01-01-2014, 11:26 AM | #39 |
@FA20Club.com
Even with the non-thermostatic plate, coolant will always be warmer during warmup time and cooler when driven hard than oil. So, what's the point with thermostatic plate?
An idea should be like a skirt, long enough to cover the details and short enough to keep everyone's attention.
01-01-2014, 01:59 PM | #40 | |
Drives: '13 Nissan Frontier (4.0L 6spd 2WD)
With a heat exchanger system the oil will come up to temp faster and stay cooler due to the water coolant coming up to temp faster and then stabilizing at a lower temp to draw heat from the oil. Heat exchangers are the way to go, but the coolant system is the critical part now and needs to be adequate. Stock is not adequate... this type system is much more than adequate, though I'd piece it together myself and use the heat exchanger advantages to get it of the front opening and down low as possible - zero reason to air cool heat exchangers.
Had a '13 FR-S Asphalt 6spd manual (bought new 5/25/12, sold 6/10/20) but needed to let her go... she will be missed.
01-01-2014, 02:34 PM | #41 |
Drives: 2013 BRZ, 2002 WRX
Seriously considering this for use with my Kraftwerks kit. You say it'll fit but it looks like the lines coming off the oil filter header will hit the KW mounting plate.
Are you absolutely sure this will clear the plate, belt and pulleys?
01-01-2014, 03:01 PM | #42 |
Drives: FRS
Any idea if this will work with a TRD intake?
Tags |
fa20club, liquid to liquid, oil cooler |
Similar Threads | ||||
Weird sounds and liquid dripping from car | kam | Issues | Warranty | Recalls / TSB | 21 | 05-07-2014 07:01 PM |
FA20CLUB Oil Cooler Kit Released.... | FA20Club.com | Engine, Exhaust, Transmission | 18 | 09-25-2013 08:36 PM |
Bubbling/knocking (but not liquid) sound aside from chirping | mike_ekim1024 | Issues | Warranty | Recalls / TSB | 22 | 05-05-2013 03:20 PM |
Anyone an Idea what that liquid is? | Killerbee | Scion FR-S / Toyota 86 GT86 General Forum | 13 | 12-10-2012 10:33 PM |
