Engine, Exhaust, Transmission Discuss the FR-S | 86 | BRZ engine, exhaust and drivetrain. |
09-13-2015, 08:34 PM | #29 |
Drives: Toyota
I've got my oil temp sensor in the oil galley port. On the passenger side of the engine, there is another oil access port under the fuel injector cover. I'm using this access port for pressure.
The Following User Says Thank You to boomslang For This Useful Post: | jdnguyen (09-13-2015) |
09-14-2015, 11:01 AM | #30 |
Resident Gear Head
HA! Oil temp and pressure are important in any car. I always run those in my builds as well as coolant temps.
Subaru BRZ/FRS Facebook News and Tech Page
My FB Build page CLICK AND LIKE! Twitter and Instagram @misairubrz |
09-14-2015, 04:00 PM | #31 |
Drives: 86
Will this fit on top of mishimoto oil cooler sandwich adapter to get the temp and pressure gauges working
http://www.rallysportdirect.com/shop...-block-adapter Sent from my 86 using Tapatalk
VOLK LE37 17X7.5, SWIFT Springs, Bilstein B8, HKS intake duct, Cosworth Air Filter, HKS headers, PLM Over Pipe, EVS Down Pipe & Exhaust, FD 4.55, GFB pulleys, Axle-Exchange Drive Shaft, Mishimoto oil cooler, Cusco F&R strut bar, TRD door stabilizer, Innovate SC, Delicious Tuned
09-14-2015, 04:12 PM | #32 |
Not Bаnned Anymore
Drives: Heavily Modified FRS
You guys could also order a @Mishimoto thermostat plate it has 2 sensor ports in addition to ports for the cooler lines.
09-29-2015, 07:51 AM | #33 |
Drives: 2013 BRZ black
@BatStig So I got my TRD sandwich plate in and tried to test fit my Tanabe sensors (pressure and temp) but it looks like they didnt cut enough threads with their 1/8"NPT tap. I can only get maybe one thread started. Did you have the same issue? Looking for a tap right now to go a little deeper....
09-29-2015, 08:47 AM | #34 | |
Some say.....
Drives: 2007 Subaru Impreza 2.5i
09-29-2015, 09:19 AM | #35 | |
Drives: 15 BRZ LTD, 05 FXT
One plate that handles it all!
SOLD: 2015 WRB BRZ Limited ('02 WRX BBS, S-04's, Stoptech Sport pads, MXP SP, AVO drop in filter, Mishimoto Intake tube, decatted header, OFT 93 Stage 2 EL Tune, Kartboy rear shifter bushing, Whiteline transmission and subframe lockout bushings, ST Coilovers, SPC Camber bolts w/smaller crash bolt, SPC LCA's & SPC Toe Arm bushings, Red TOMs, TRD Wing.)
09-29-2015, 09:38 AM | #36 | |
I found a 1/8NPT tap and chased a few more threads down. Solved my problem. Thats definitely a solid choice. I already had the Mocal unit and didnt want to replace. |
09-29-2015, 10:10 AM | #37 |
Not Bаnned Anymore
This will NOT work I thought it would but there is no way for the sensor so fit in without hitting the belt or oil filler cap. I had to install my old greddy sandwitch plate ontop of the mishimoto oil cooler setup. Also just a heads up even with a 200F thermostat the oil will still be over cooled under normal street driving. Under race enviroments it works awesome though!
The Following User Says Thank You to go_a_way1 For This Useful Post: | xkalelx (09-29-2015) |
09-29-2015, 10:16 AM | #38 | |
09-29-2015, 10:22 AM | #39 |
Not Bаnned Anymore
I tried that too but with no luck. You have a belt on one side and the oil filler cap on the other. You would need to stack a few plates but then doing that would leave the sensor over the filler cap as you can't really turn it much and good luck finding those hollow bolts the filter screws on to if you want to make a custom spacer.
09-29-2015, 11:23 AM | #40 | |
Which oil did you run that was overcooled? Once it hits 200, it should cool down from there so if you're not hitting it, it's just a higher volume, yes? My plan was to run a blockoff plate in the colder environments.
09-29-2015, 11:47 AM | #41 | |
Not Bаnned Anymore
0W-20 in about 15*C outside. Thats what I thought but if I drive on the highway for like 5 minutes it will drop to 130F from like 190F Maybe bad thermostat? Should I put the other one back in and see if it does the same thing? Yeah I am planning on blocking the cooler off for the winter |
09-29-2015, 02:39 PM | #42 | |
Another idea, how about a bracket that lets you loosen it, and rotate it up 90 degrees up out of the airflow through the bumper for cooler temps? If not, a plastic cutting board with a few holes drilled in it, and bolts sandwiching it over the cooler!
Similar Threads | ||||
Cyberstork gauges | ANREX | Cosmetic Modification (Interior/Exterior/Lighting) | 53 | 08-11-2016 06:07 PM |
WTB: Gauges | AtlasMick | Engine, Exhaust, Bolt-Ons | 2 | 03-29-2013 12:04 AM |
Ecu and displays/gauges | stockysnail | Engine, Exhaust, Transmission | 7 | 03-02-2013 06:23 PM |
gauges where the radio is? | J-Money | Cosmetic Modification (Interior/Exterior/Lighting) | 7 | 02-05-2013 10:11 PM |
Gauges | CyberFormula | Scion FR-S / Toyota 86 GT86 General Forum | 45 | 07-24-2010 06:26 PM |
