#29 |
Drives: Attitude
#30 |
Can they put together stainless lines too if you pick the barbs and length?
#31 | |
Drives: Scion FR-S
Edit: not bashing perrin at all they have a great product I just have some years in aircraft hydraulics that has shown me were to get the best deals. Sent from my Q10 |
#32 |
Drives: Scion FR-S
[ame="http://m.youtube.com/watch?v=3tjRsbSDA48"]Phenix AN Hose End instalation on Teflon Hose made easy - YouTube[/ame]
Here is a video of how it's done pretty simple stuff. I don't use a screw driver to flare I use a brass pick less chance of damaging the hose. Also rubber hoses have an expiration date these do not. These also handle heat and pressure better. Granted this is a tiny hose be ready to but some muscle on that wrench when you get up to a -8 or -10 line. Sent from my Q10 |
#33 |
Drives: Whiteout 6MT FR-S
I'm intrigued by this discussion... being a total noob, I didn't know these components were available for way cheaper than the kit price. would be nice if someone could put together a DIY, with mounting options on our car.
for example, found one for 350z's here: http://my350z.com/forum/engine-drive...n-a-na-hr.html |
#34 | |
Drives: Scion FR-S
Sent from my Q10 |
#35 |
that would be sweet, looking forward to it! hope the move goes smoothly, had to do that as well not too long ago.
#36 | |
Site Moderator
Drives: Stuff
-Aluminum core -2 Aluminum end-tanks Oil Cooler parts: -Adapter spacer -Thermostat -Lines and fittings (SS or clamp on rubber) -Aluminum core -2 Aluminum end tanks -Mounting solution (ie not built into the car like the radiator) That's basically why. The actual cooler isn't that expensive, the thermostat and other bits bring up the cost quite a bit.
-Dave
Track cars: 2013 Scion FRS, 1998 Acura Integra Type-R, 1993 Honda Civic Hatchback DD: 2005 Acura TSX Tow: 2022 F-450 Toys: 2001 Chevrolet Corvette Z06, 1993 Toyota MR2 Turbo, 1994 Toyota MR2 Turbo, 1991 Mitsubishi Galant VR-4 Parts: 2015 Subaru BRZ Limited, 2005 Acura TSX Projects: 2013 Subaru BRZ Limited track car build FS: 2004 GMC Sierra 2500 LT CCSB 8.1/Allison with 99k miles Last edited by Dave-ROR; 06-22-2013 at 11:24 AM. |
#37 | |
Site Moderator
Drives: Stuff
In the end though, a larger capacity radiator won't have nearly the effect on oil temps as an oil cooler.
-Dave
Track cars: 2013 Scion FRS, 1998 Acura Integra Type-R, 1993 Honda Civic Hatchback DD: 2005 Acura TSX Tow: 2022 F-450 Toys: 2001 Chevrolet Corvette Z06, 1993 Toyota MR2 Turbo, 1994 Toyota MR2 Turbo, 1991 Mitsubishi Galant VR-4 Parts: 2015 Subaru BRZ Limited, 2005 Acura TSX Projects: 2013 Subaru BRZ Limited track car build FS: 2004 GMC Sierra 2500 LT CCSB 8.1/Allison with 99k miles |
#38 |
Site Moderator
Drives: Stuff
I prefer 250 or less, I see 235 on the track with a 19 row mocal cooler in Florida....
-Dave
#39 | |
Site Moderator
Drives: Stuff
Thinner oils run cooler, which reduce the need for a cooler slightly. However, the flip side is that they have less oil pressure which is even worse hot. So you will likely find (once you start measuring pressure) that 0w20 results in low oil pressure on the track (IMO anyways, less than the 10psi per 1,000rpm and it DROPS from 7,000 up...) so switching to 0w30/5w30 etc bumps up pressure as desired, at an increase of oil temps (slight but being at 300 stock...) which can suggest a cooler, which then drops pressures a few PSI. Fun stuff right. ![]() Oh and for winter, just block off (or remove) the cooler.
-Dave
#40 |
Site Moderator
Drives: Stuff
The thermo units are partial bypass generally (and that includes the mocal one people use here), so oil still flows through the cooler, just not full flow. You knew that already, clarifying for others.
-Dave
#41 | |
Drives: Scion FR-S
Sent from my Q10 |
#42 |
Drives: Attitude
| 1.1 vs 1.3 Radiator Cap | JPxM0Dz | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 14 | 01-21-2014 01:21 AM |
| KOYO Radiator In-Stock!!! Free Shipping!!! | Titanmotorsports | Engine, Exhaust, Bolt-Ons | 24 | 07-09-2013 05:55 PM |
| WTB: Stock Radiator | RYU | Engine, Exhaust, Bolt-Ons | 2 | 01-12-2013 11:21 AM |
| Koyo performance radiator in stock at B2autodesigns | b2autodesigns | Engine, Exhaust, Bolt-Ons | 6 | 11-23-2012 12:28 PM |
| Anyone else have a lot of dents on the radiator? | Norcalmav23 | BRZ First-Gen (2012+) — General Topics | 16 | 09-02-2012 11:07 PM |
