Issues | Warranty | Recalls / TSB Problems, issues, recalls, TSBs |
07-17-2023, 02:18 PM | #29 |
Drives: 2020 BRZ/86, 2020 BMW 330i
"B...bUt MaNuAl SaYs.."
07-17-2023, 02:26 PM | #30 |
Anti stance.
07-17-2023, 06:25 PM | #31 | |
chicken tonight
Just because the oil can maintain viscosity at 300 F doesn't necessarily mean it's ok for the rest of the engine to be operated like that.
The Following User Says Thank You to Ultramaroon For This Useful Post: | NoHaveMSG (07-17-2023) |
07-17-2023, 08:32 PM | #32 |
Drives: Crapcan
The Following User Says Thank You to NoHaveMSG For This Useful Post: | Dzmitry (07-20-2023) |
07-17-2023, 09:11 PM | #33 |
chicken tonight
07-17-2023, 09:39 PM | #34 | |
Professional Mechanic
Drives: 2017 86 6MT Oceanic
Any engine I come across with an iffy oil spec that reeks of EPA I disregard. Ford modulars get 5W30, HEMIs get 5W30, the pentatrash 3.6 V6 was born with 5W30 and was later moved to 5W20. You can bet your ass I put 5W30 in it when that engine is in anything heavier than a caravan, like a ram or promaster. And my 86 gets Motul 5W30 in summer. Still gets 0W20 in winter though because I go down to almost -30 degrees celcius. |
07-18-2023, 08:16 AM | #35 | |
Anti stance.
I've run 0w40 daily, year round, in Canadian winters, and on track at Mosport, Cayuga, Grand Bend, Shannonville, Road Atlanta and Road America, no oil cooler, with R-comps, TRD sway bars, and RCE Tarmac 2(coilovers for only 1 summer. BRZ tS dampers and TRD springs from day 1) for over 255,000 KMS. Not once has my car ever had an oil related issue. It's never overheated. You'll not catch me letting the EPA dictate how to protect my engine. It's never gone into limp mode. In fact, the only thing that ever has happened beyond scheduled maintenance and wear items was an OE battery went dead, and two Toyota dealership batteries exploded back to back within weeks of each other. No issue since switching to an Optima Yellow Top 3 years ago. Last edited by Tokay444; 07-18-2023 at 08:26 AM. |
The Following 8 Users Say Thank You to Tokay444 For This Useful Post: | Arthur-A (07-18-2023), MrSkubi (07-26-2023), new2subaru (07-18-2023), nomtimesthree (07-18-2023), RZNT4R (07-18-2023), Teseo (07-18-2023), ZDan (07-18-2023) |
07-18-2023, 08:36 AM | #36 |
Drives: 2013 frs base
Anybody installed and tested Killer B's solution?
07-18-2023, 08:51 AM | #37 |
Drives: 17 Asphalt 86
07-23-2023, 06:36 AM | #38 |
Drives: '23 BRZ
There's this:
07-23-2023, 07:31 AM | #39 |
That's a nice install, and configured like that, accumulator only with a manual valve, is probably pretty cheap and more than enough for the very momentary dips that are being seen.
The Following User Says Thank You to RZNT4R For This Useful Post: | blsfrs (07-23-2023) |
07-23-2023, 10:37 AM | #40 |
What air psi are you starting at?
07-23-2023, 11:48 AM | #41 | |
Drives: '23 BRZ
The Following User Says Thank You to ZDan For This Useful Post: | blsfrs (07-23-2023) |
07-23-2023, 12:27 PM | #42 | |
more precharge wil yield less volume, but less pressure drop as that volume is supplied. The good thing about such a system is it would be easy to precharge at a higher pressure to account for instantaneous pressure drops at a track with short corners, but if you hit a track with a long sweeper, drop the precharge a bit to trade pressure for volume. Someone in the comments even set it up for the best of both worlds: an aux air tank for a lower precharge yielding sustained pressure AND greater oil volume. [edit] The picture looks like a canadian brethen, what with the big "AVERTISSEMENT" sticker on the brake booster. |
Similar Threads | ||||
Engine failure | michael_basden | Member's Car Journals | 5 | 10-06-2018 05:58 PM |
Engine failure | Geex | Issues | Warranty | Recalls / TSB | 19 | 07-01-2018 03:57 PM |
Engine failure! | mackeye | Engine, Exhaust, Transmission | 24 | 01-29-2018 11:48 PM |
direct injector Failure , sand in the engine and on the engine | aagun | Issues | Warranty | Recalls / TSB | 3 | 05-26-2014 02:46 AM |
Will I get a check engine light on if the engine bay has a direct injection failure? | Astroboy | Engine, Exhaust, Transmission | 7 | 03-29-2014 06:16 PM |
