Electronics | Audio | NAV | Infotainment Anything related to in-car electronics, navigation, and infotainment. |
02-11-2021, 10:04 PM | #29 | |
Drives: '20 BRZ tS (15/300) / '09 Scion tC
02-22-2021, 06:00 PM | #30 | |
Drives: brz 2017 hksv2
Those things are under other ECUs and not on ECM and you won t achieve anything swapping it with a JDM ECM |
03-06-2021, 01:04 PM | #31 |
OK, I replaced the body computer with the JDM one, now I have the lock/unlock beep (that can be enabled or disabled).
Other differences from the EU model: follow me home function is no more present, there's an option to slow down the headlight ignition when set to auto, and there's another annoying thing, a repeating beep when put in reverse, that can't be disabled. Something like the one in trucks, but inside the car. This would be funny if I'd not have reverse sensors... Oh, now there's an option that can be enabled in Security tab, but I don't know what it is... Last edited by gpvecchi; 03-06-2021 at 01:39 PM. |
03-06-2021, 06:47 PM | #32 |
has a funny hat
Drives: 2014 BRZ Limited
if your “new" option in the security tab is an alarm, it'll honk and flash the lights if the doors et al. are opened without using the remote to unlock it after being locked with the remote.
To test: lock with remote, unlock with key, open door, all hell breaks loose. I forgot I had enabled this setting before putting my car away for the winter and for some reason I locked the doors (habit probably). Then, I removed the battery from the fob to avoid broadcasting the signal all winter for no reason (also, there had been someone signal jacking fobs and steeling cars in the area). A week later I realized my sunglasses and phone charger were still in the BRZ so I unlocked it with the key and couldn't hear anything for a few days after being in a closed garage with a blaring horn (mild exaggeration, but it was loud). Touching the fob to the start button killed the noise. |
The Following User Says Thank You to pope For This Useful Post: | gpvecchi (03-07-2021) |
03-07-2021, 03:58 AM | #33 |
Just checked, it doesn't act as you said in mine, the only differences I found enabling that security function is the the security led in the dash is fixed and not blinking, and that internal unlock button is disabled.
May somebody please tell me if US cars have this features and if they can be enabled/disabled? Lock unlock beeps Follow me home Reverse beeping Thanks! Last edited by gpvecchi; 03-07-2021 at 09:50 AM. |
03-07-2021, 10:21 AM | #34 | |
Certs You Dont Care About
Drives: 2013 Galaxy Blue BRZ
Lock unlock beeps - Yes Follow me home - Yes Reverse beeping - No But you said you got a JDM module, not US right? |
The Following User Says Thank You to sharpsicle For This Useful Post: | gpvecchi (03-08-2021) |
03-07-2021, 09:33 PM | #35 | |
Drives: 86 GT
edit: beeps do go on and on in reverse, even without reverse sensors Last edited by Compelica; 03-08-2021 at 04:26 AM. |
The Following User Says Thank You to Compelica For This Useful Post: | gpvecchi (03-08-2021) |
03-08-2021, 12:53 AM | #36 | ||
03-08-2021, 04:03 AM | #37 |
Drives: 86 GT
@gpvecchi I have made a mistake - the car does go on beeping when on reverse. I got confused with another car of mine :/
03-08-2021, 05:17 AM | #38 |
Drives: Corolla GT
JDM Facelifted MT
Reverse Beep - yes Lock/Unlock Beep - yes Follow Me Home - no I agree the reverse beep is a nightmare. But it did save me once or twice. Since the reverse is next to first gear it saved me from launching forward when i was in a rush. PS: Its my first car with reverse next to first gear But Im used to it now. |
The Following User Says Thank You to Thefalls For This Useful Post: | Wally86 (03-08-2021) |
03-08-2021, 03:45 PM | #39 |
The beep in reverse in not annoying, it's not noisy. The issue is that I have reverse sensor, and it becomes an orgy of beeps...
Edit: I can't buy the US unit, or my A/C will switch to Fahreneit... Last edited by gpvecchi; 03-08-2021 at 04:33 PM. |
03-09-2021, 08:59 AM | #40 |
What was wrong with keeping it EU? It seems like that's the closest fit for what you want. Sure, it doesn't have the lock/unlock beep, but everything else is correct.
03-09-2021, 04:22 PM | #41 |
Those beeps...
Oh, and it adds alarm, EU models don't have alarm enabled. I managed to enable it with the procedure found on this forum, the EU computer doesn't have it. Now I'm planning to convert reverse sensor to visual notification. |
03-12-2021, 12:50 PM | #42 |
Drives: 86 GT
How does the follow me home function work for the EU BCM modules?
Similar Threads | ||||
Vehicle Finder Setting for the BRZ using Toyota Techstream | AnthonyArcaro | Software Tuning | 0 | 02-29-2016 12:43 PM |
Modding squirrel finder | wbradley | Cosmetic Modification (Interior/Exterior/Lighting) | 6 | 07-10-2013 02:53 AM |
Help! Squirrel finder issue! | Jacob G. | Cosmetic Modification (Interior/Exterior/Lighting) | 13 | 03-01-2013 01:26 PM |
Car Finder feature on Remote | eriktherod | Scion FR-S / Toyota 86 GT86 General Forum | 8 | 06-13-2012 07:23 AM |
