DIY (Do-It-Yourself) Guides For all DIYs. |
#29 | |
The guy w/o an FRS or BRZ
Drives: '23 GR86 Premium 6MT Halo White
Okay, for real now... the tow hook was designed to pull parallel to the ground, with the aid of your rotating wheels. If there were no wheels on the car, I'd question the tow hook's integrity to pull the car for long distances. Think about a twig on a tree. You can pull to your heart's content and it may not come off the tree. But if you apply force in a different direction, you can easily snap it off the tree. Physics doesn't change for tow hooks. I'd stick to the designated jack points ![]() https://www.ft86club.com/forums/showthread.php?t=10111. |
The Following User Says Thank You to ROFL it's Waffle For This Useful Post: | Tcoat (11-27-2019) |
#30 |
Drives: 2019 WRB BRZ PP
As many have previously stated, this is a pretty bad idea. The tow hook will be fine for pulling the car in tension (regular towing of the car), but can only take approximately half the load in shear (lifting the car via the hook). The weight would likely cause damage to the hook/crash bar which would be a very costly repair. You're far better off lifting from the pinch welds, once again as many others have stated. And remember to always use jack stands!
#31 |
Senior gif poster
Drives: 2013 Asphalt FRS
Im not going to re state what many others have said. I will simply say this:
"Stop being so damn lazy" Roll onto ramps/wood what have you, then jack up the front, place stands in front. Jack up the rear (using the JACK POINTS IN THE OWNERS MANUAL) and place stands under the rear and reverse to lower the car to the ground. Now if your at a track/side of road and you can't use the factory jack points for whatever reason you jack up each wheel to remove it as stated by the owners manual, at that point you should be using the emergency jack since it must be an emergency that your not using the proper jack points. |
The Following 2 Users Say Thank You to DandoX For This Useful Post: | ROFL it's Waffle (12-07-2019), Tcoat (12-06-2019) |
#32 |
ProCrastinationConsultant
i jack up the front by the crossmember. saves a ton of time instead of moving the jack side to side.
Jacking points? | bleox | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 36 | 02-19-2016 01:03 AM |
Jacking points | Qwimby2 | BRZ First-Gen (2012+) -- General Topics | 4 | 12-08-2015 09:48 PM |
Jacking a lowered BRZ/FRS? | swift996 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 12 | 03-19-2013 02:04 AM |
Track Tow Hook R&D Thoughts and Comments (Pictures) | NON-VTEC | Scion FR-S / Toyota 86 GT86 General Forum | 24 | 02-06-2013 10:06 AM |
Car Jacking up Points? | J-Money | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 2 | 01-21-2013 02:55 PM |
