Forced Induction Turbo, Supercharger, Methanol, Nitrous |
01-12-2013, 10:48 AM | #29 | |
Add lightness!
Drives: 17' WRX
01-14-2013, 12:23 AM | #30 |
there isnt a racecar in the world thats built to make power at 3000 rpms guys
01-14-2013, 01:36 AM | #31 |
Add lightness!
Drives: 17' WRX
The Following User Says Thank You to industrial For This Useful Post: | Sportsguy83 (01-14-2013) |
01-14-2013, 05:16 AM | #32 |
The thing is that even with the turbo's torque curve and power, most of these turbo kits are at 75% of their torque before 4k rpm. Also i dunno about most people here but when I am in the twisties I keep the car in the 4.5k+ rpm range just to stay in the power of the stock engine...with a turbo you dont have to change how you drive this car since all of us already know that stock power doesn't really come on til after 4k rpm. So what is with all the misguided hate for turbos on this car.
The Following 2 Users Say Thank You to Supermassive For This Useful Post: | PRORICAN (01-14-2013), Sportsguy83 (01-14-2013) |
01-14-2013, 05:58 AM | #33 | |
Drives: '06 AM V8V Coupe
It's too bad that the smaller TVS units are impossible to find. If they don't hurry up, variable speed centrifugal chargers might take off and nix any chance they had, they have to work at taking away market share from turbos anyhow. Truth be told, the 5th gen M45 and M24 are pretty efficient and are actually better suited for low boost than the TVS chargers in some situations (though the TVS still has packaging/mass advantages), someone should try strapping an M45 to the FA20, running the M45 at max speed will give maybe a 25% bump in power everywhere and that would represent a very efficient usage of the supercharger, although you won't be able to just swap pulleys if you're not happy with the power. Last edited by serialk11r; 01-14-2013 at 06:09 AM. |
01-14-2013, 09:09 AM | #34 |
Its not misguided.
Supermassive, youre building it right. your project will be kosher when its done most the guys on here think they can strap on a turbo kit for $4000 and be done youre smart enough to see the big picture, dont give everyone on this forum that credit early boost= smaller turbo, and that seems to be the trend to try and make power down below 4500 rpms, which makes no sense to me at all without fuel upgrades, 9psi is the max, no matter whose kit you buy so its all boost curve vs TQ curve choice, buyers past 10psi, it depends what youre building, and your budget can the motor run 15 psi? yup supermassive is an exception, I wouldnt suggest you emulate him unless you have his experience set, budget and expectations. Not everyone is ok doing what he is doing, so watch in awe, but realize what he is doing isnt gonna be for everybody I put him in with crawford, fully executed build potential is there. not for average joe's budget tho for most folk a 6 psi kit is great for some who want and know how to handle the power overage, they can get to that 9psi spot it will be a very small percentage of folks who exceed the fiscal barriers presented past 9psi |
01-14-2013, 09:30 AM | #35 |
Drives: 13 Whiteout
My speed3 was tuned to hit full boost by 3200 rpm at 21 psi...and tapered to 17 by redline. Where talking K04 here, so lots of torque down low. This was great for a DD....so not really racecar status.
2013 Scion FR-S (Whiteout) GunMetal 16x8+25 Enkei CompE_Cusco OCC_ Kartboy Crank Pulley_Kartboy TMM insert_Koni Yellows_RCE Springs_K&N Drop-In_Eibach FSB_J2 Catless FP_WhiteLine Camber Bolts_NameLess Track Pipe_RBF600_Ferodo DS2500_PTUNING Tuned. Less parking more racing |
01-14-2013, 09:36 AM | #36 |
01-14-2013, 09:49 AM | #37 |
Drives: 13 Whiteout
Ya, bitches love turbo wagons....lol, Im just saying in reguards to OP's post....small turbos are great for real world driving. They may just be blowing hot air up top, but thats where meth comes in, and E85 if ya got it. Lower BAT's and help prevent KR.
01-14-2013, 10:01 AM | #38 |
wagons are hot dont get me wrong, but the turbo at 3000 rpms peaking is a turn off
that tells me alot about what I will get at 6000 rpms anyways, I will digress and brag about our wagon, which I saved up for and lusted for over a few years before buying: 2005 s4 AVANT (wagon) 4,163 cc 4.2 liters V 8 front engine Quattro with 84.5 mm bore, 92.8 mm stroke, 11 compression ratio, quad overhead cam, variable valve timing/camshaft and five valves per cylinder Power: 254 kW , 340 HP SAE @ 7,000 rpm; 302 ft lb , 409 Nm @ 3,500 rpm Top speed 155mph. 0-60 5.4 seconds QTR 13.7 I eat NEW mustangs & hemi chargers and the like at red lights only to have them catch up ask, and I tell them its stock, which is true 100% yes, ms3's are cute cars |
01-14-2013, 10:37 AM | #39 | |
Drives: car
The Following User Says Thank You to arghx7 For This Useful Post: | Sportsguy83 (01-14-2013) |
01-14-2013, 12:19 PM | #40 | |
Kuruma Otaku
I did a rough calculation comparing the moment of inertia between 2 43mm dia cylinders vs 1 60mm dia cylinder. Heights were adjusted so total surface area was the same. The 2 43mm cylinders have only 74% the mass and 38% the rotating inertia of the 1 60mm cylinder. While turbines and compressors are obviously not solid cylinders, the same principle applies to twin vs single turbos. So while you have 50% the exhaust flow per bank you are only pushing against 19% the inertia.
Because titanium. |
01-15-2013, 10:32 AM | #41 | ||
Hot Dog
Drives: quicker than arghx7
My inquiry is not aimed at anyone going to the track or racing. The intent is to offer an option for those that end up being stuck in traffic a majority of the time and want accessible low-end grunt. Quote:
"Wisdom is a not a function of age, but a function of experience."
Just Say No to unqualified aftermarket products. |
01-15-2013, 10:59 AM | #42 |
Lap time enthusiast
Drives: Asphalt '13 FR-S 6MT
The type of turbo you describe you want for this car doesn't match it's personality and design, which is why you probably won't see turbo kits of this type for this car. You want enough torque to avoid having to downshift to pass, which to me seems more like a luxury car trait, not a sports car trait. Yes, it would be nice, but if you're tired of downshifting to pass, maybe you should have chosen the automatic transmission.
The Following User Says Thank You to raul For This Useful Post: | gmookher (01-15-2013) |
Similar Threads | ||||
All TURBO kits compilation thread | subatoy | Forced Induction | 112 | 04-10-2015 09:14 PM |
TSI offers HIDGUY HID kits and LED lighing! $95 kits SHIPPED! We won't be beat! | Lisa@TrueStreetIndustries | Exterior Parts - Lighting | 129 | 01-18-2013 08:57 PM |
E85+boost | subatoy | Forced Induction | 5 | 11-06-2012 11:55 AM |
Price of Boost | Synack | Engine, Exhaust, Transmission | 37 | 07-03-2012 05:39 AM |
Protecting plastic door threshold | BMWDavid | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 0 | 06-19-2012 09:04 PM |
