Old 01-17-2024, 01:26 PM   #29
tomm.brz
Drives: brz 2017 hksv2
A p0420 definitely doesn t stop LTFT
Only certain dtc's i believe
It may or may not, depends on the case
i had a damaged primary o2 sensor which went a lot leaner (its 14.7 would be a 20-21 of real afr when warm) and the ecu wasn't happy of something during the cold start so it delayed LTFT
while LTFT was delayes, fuel trims were limited to "only" -35% or so
when ltft activated suddenly the trims went -80% and the car was extremely lean
Cold start has a "fuel system status" of 1
So if something messes with the cold start conditions and fuel system status stucks at 1 , ltft doesn't start
The Following User Says Thank You to tomm.brz For This Useful Post:
Compelica (01-22-2024)
boosted, ecutek, knock
Air Fuel ratio not hitting target ECUTEK Yetti Software Tuning 5 08-23-2021 08:38 AM
Ecutek showing boost target hitting 19.9? incutebus Software Tuning 4 04-12-2019 12:22 AM
Crickets possibly fuel pressure target? Tromatic Software Tuning 1 12-16-2014 03:58 PM
ECUTek Flex Fuel iketiak Engine, Exhaust, Transmission 1 10-24-2013 06:15 PM
ECUtek Flex Fuel REVOLUTION: World's First Flex Fuel Factory ECU GTR - BRZ soon! Visconti Engine, Exhaust, Transmission 356 05-20-2013 09:36 AM
