Old 02-04-2014, 09:31 AM   #29
Mikepage
Mikepage's Avatar
Drives: Scion FR-S 2013 Raven
Best shifter setup
Originally Posted by mad_sb View Post
and adjust the reverse lock out (if you have any 2nd gear grind issues)
How do you do that?
o= FR-S =o
Mikepage is offline   Reply With Quote
Old 02-04-2014, 08:00 PM   #30
jamesm
Mtec springs, motul fluid (not in yet in my case), weighted flossy shorty knob. Couldn't possibly want it any shorter and the feel is fantastic.
Old 02-04-2014, 08:22 PM   #31
SmsAlSuwaidi
Boosted
SmsAlSuwaidi's Avatar
Drives: Not a supra....yet
Act 6puck w/ light flywheel
Kart boy short shifter
Mtec shift spring
Motul fluid
Still havent got used to it
Old 02-04-2014, 08:56 PM   #32
that_guy
Dances with Cones
that_guy's Avatar
Drives: 2013 Scion FR-S Raven
Originally Posted by TheseColorsDontRun View Post
I have installed a short shifter in every car I've ever owned. This is the only one that I haven't felt the need. The best factory shifter I have ever had. Having said that, I have installed a Whiteline trans bushing insert, Perrin rear shift bushing and have a weighted knob. The best got better. I have no interest in installing a short shifter.
I hear you. This car has a great shifter stock. I have the Energy Suspension rear shifter bushing (not yet installed) and I think that'll about wrap up my shifter mods for this car.
I run a TWM M1 Abram on the lowest setting for street and a TWM 4" knurled competition knob for track. The extra leverage from the competition knob makes shifting a breeze and saves me from looking for the shifter when going for the next gear. It's a grab, throw, and go setup. A shorter shift will not make me a faster driver.
2013 Scion FR-S - Raven
2011 Scion tC - Cement - SOLD
that_guy is offline   Reply With Quote
The Following User Says Thank You to that_guy For This Useful Post:
Mikepage (02-04-2014)
Old 02-04-2014, 09:24 PM   #33
Mikepage
Mikepage's Avatar
Best shifter setup
Exactly that am trying to say
How did you pay for the energy suspension bushing, am looking for this...
o= FR-S =o
Old 02-05-2014, 08:24 AM   #34
that_guy
Dances with Cones
that_guy's Avatar
I bought it from Performance Improvements in Ontario (because I work at one of the stores). It's pretty cheap. They also make the steering rack bushings which I purchased. Not sure I'm going to install them yet, but again, they were cheap, so why not.
The Following 2 Users Say Thank You to that_guy For This Useful Post:
Mikepage (02-05-2014), SirBrass (02-06-2014)
Old 02-05-2014, 08:33 AM   #35
mad_sb
Drives: 2013 Asphalt FR-S
How do you do that?
You just loosen the lockout plate and adjust it like you would if you were installing a short throw shifter. Check out post #6 in @F1point4 how-to for the kartboy
It may or may not help, for me it made more difference than swapping to motul 300 (which made the 2nd gear cruch worse unless the fluid is fully up to temp).
The Following User Says Thank You to mad_sb For This Useful Post:
Old 02-05-2014, 08:46 AM   #36
lickitysplit
Don't care
Drives: 2013 Whiteout FRS
My kartboy rattles at high rpm, it's coming off this weekend. Other mods are kartboy rear stay, kartboy positive shift tranmission bushing, and mtec springs. The rattle was there before I installed either bush, was hoping the bushings would help but had no luck. Tom told me I most likely didnt grease it well enough so I tore everything down, regreased and still have the rattle/buzz so im done with it. Since I installed all parts seperately I'd say leave the stock shifter and change out everything else for best feel and least noise/rattles
lickitysplit is offline   Reply With Quote
Old 02-05-2014, 09:19 AM   #37
Mikepage
Mikepage's Avatar
Do you think this adjustment can fix the 2nd gear grind with the stock shifter?
Am not sure because in my case it's only happen on cold temp when the oil is cold...
It's also a little bit better since I replaced the trany oil by the Redline oil.
o= FR-S =o
Old 02-08-2014, 01:29 PM   #38
Cards2323
Drives: 2014 BRZ Limited-SWP
Is the kartboy reverse lock out plastic or metal? Its hard to see in the pics, if its plastic can it be removed for an after market piece?
Cards2323 is offline   Reply With Quote
Old 02-08-2014, 02:16 PM   #39
mad_sb
What knob are you using?
I found the knock off ebay short shifter (same type of design as the billet pro rattled like hell from 4k and up, it was much worse with my mtec drift shift knob than with the stock knob.
My kartboy barely rattles with the mtec drift and only slightly noticeably with the stock knob. Weighted knobs seem to reduce rattle, i guess because they act like a mass damper.
Old 02-08-2014, 02:17 PM   #40
mad_sb
Mine was the same, as soon as i adjusted the lockout more to the left it got better, much better. If your lockout plate is preventing you from lining up the gate just right it will make it notchy.
Mikepage (02-08-2014)
Old 02-08-2014, 03:30 PM   #41
manonastick
Drives: WRB ZC6
The shifter in my brz is pretty meh compared to the my s2000 shifter feel and they both have the same gearbox. The s2000 is my pinnacle of shifter feel for me. I only had that car for one year and had 100k miles on the original box too. If I can achieve the same feel I wpuld be happy
manonastick is offline   Reply With Quote
Old 02-08-2014, 06:25 PM   #42
gonzo
Drives: frs
Originally Posted by SirBrass View Post
Has anyone tried both the billet pro and the kartboy short shifters? Any noticable difference between the two?
I have the KB SS and like it, but I wonder if the billet feels any different.
I've had the BPS shifter and it has been rattling for over a year now. They keep telling me the fix is "coming soon," but they've been talking about this "fix" BS for a year now.
I wouldn't purchase the BPS again. Not because the rattle bothers me (I barely hear it with the exhaust) but because BPS has given me the run around and promising fixes for a year. At the same time they continue to sell a defective product.
gonzo is offline   Reply With Quote
Manual MT Shifter Boot Swap Onto Automatic AT Shifter Assembly? soulstice Cosmetic Modification (Interior/Exterior/Lighting) 52 01-24-2016 08:20 PM
kartboy short shifter and rear shifter bushing install and review. FR-S UMB FR-S DIY (Do-It-Yourself) Guides 21 10-18-2014 01:41 AM
Anyone have this setup? Gt86_nick Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 23 03-04-2014 05:32 PM
Shifter TSB 03-71-13 v. Perrin Rear Shifter Bushing swansons Issues | Warranty | Recalls / TSB 4 02-02-2014 02:27 PM
Thoughts on a "component" setup with a 3.5" dash and 6.5" door setup? PatrickSAN Electronics | Audio | NAV | Infotainment 22 11-14-2012 02:12 PM
